Topic: Interfacing Arduino with Pololu JRK21v3 help please! (Read 2106 times) previous topic - next topic
Evz
Mar 07, 2012, 10:44 pm Last Edit: Mar 07, 2012, 10:49 pm by Evz Reason: 1
hello!
I'm trying to interface my arduino due with the jrk21v3 using the following code (software serial):
#include <SoftwareSerial.h>
SoftwareSerial mySerial(2,3); // 2 - tx, 3 - rx
int target = 2500;  // this is the target speed  that I want for the jrk motor controller.
byte serialBytes[2]; // declare an array for the speed command
  // set the data rate for the SoftwareSerial port
  mySerial.begin(9600);
  serialBytes[0] =  0xC0 + ( target & 0x1F); // Command byte holds the lower 5 bits of target.
  serialBytes[1] =  (target >> 5) & 0x7F;   // Data byte holds the upper 7 bits of target.
  //0xAA, device number, 0x40 + target low 5 bits, target high 7 bits
  //Send a Pololu Protocol command
  mySerial.write(0xAA);     //start byte
  mySerial.write(0x0B);     //device id
  mySerial.write(0x40);     //command number
  mySerial.write(serialBytes[0]); //speed
  mySerial.write(serialBytes[1]); //speed
which is similar to the code from this thread: http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1283904250
and my jrk is configured to:
serial input, UART detect baud rate, device number 11,no CRC, with analog feedback.
when i use to USB to my computer, i can control the motor no problem, but then i connect the arduino to the JRK, the jrk does not respond to the arduinos serial command
could anyone help out? (unfortunately this is for a school project :( )
Thanks!
styler93gsx
SoftwareSerial mySerial(10, 11); // RX, TX
  if (mySerial.available())
    Serial.write(mySerial.read());
    mySerial.println("11, 700");
This is what I have right now my jrk 21v3 moves and but doesn't move correctly I have mine set to at 9600 though. Have used the code off of pololus websight and it only makes jrk kind of freeks out it it moves a little then it stops then it moves and then stops every time a new loops starts.  I have tested this by adding a delay from 500 to 1000 to 5000 and the start and stops with this delap.  Why the pololu doesn't keeop moving is what I'm trying to figure out right now.
Chagrin
That's eight bytes. 1/1/,/ /7/0/0 and a carriage return, or 0x31, 0x31, 0x2C, 0x20, 0x37, 0x30, 0x30, 0x0A which are the hexadecimal values for those ascii characters.
You probably want:
mySerial.print(11);
mySerial.print(700);
That would be three bytes, 0x0B, 0x02, 0xBC (although I'm not suggesting that that is a valid command for the JRK -- I have no idea). Don't forget that "println" adds a carriage return character at the end of the string as opposed to "print" which does not.
styler93gsx
You were defiantly right although at the time I didn't know what all that meant all I knew was that my JRK was moving, it was responding.  This is what I have now with the help of a friend of mine.  Use it if you like.  As of right now this works with the use or a pot tapped in to the analog AO right now it moves but its kind of jerky.  Maybe someone else can help figure this out. Please post your code if you figure something out.
int AN0pin = A0;
SoftwareSerial mySerial(7, 8); // RX, TX
  //while (!Serial) {
   // ; // wait for serial port to connect. Needed for Leonardo only
  //Serial.println("11, 341");
  //mySerial.begin(9600);
    loop();
void loop() // run over and over
  char Command[10]={0xAA,11,0x45,0xAF};
  int RawA2D;
  RawA2D=analogRead(AN0pin);
  while(1){
    Command[2]=0xC0 + ((char)RawA2D & 0x1F);
    Command[3]=(char)((RawA2D>>5) & 0x7F);
    Serial.write(Command[2]);
    Serial.write(Command[3]);
    mySerial.write(Command[0]);
    mySerial.write(Command[1]);
    mySerial.write(Command[2]);
    mySerial.write(Command[3]);
Chagrin
Just need to smooth out your analogRead() somehow.
  static int lastRawA2D;
  int RawA2D;
  while(1){
    if (analogRead(AN0pin) > lastRawA2D) {
      RawA2D += 1;
    } else if (analogRead(AN0pin) < lastRawA2D) {
      RawA2D -= 1;
    lastRawA2D = RawA2D;
