Author Topic: error detecting rfid tags  (Read 364 times)
sir  im new to arduino my project is using RFID
when tag is shown in rfid it transmits tag information via xbee
on arduino serial data received via xbee
But when tag is shown on reader it produces output like this "16703301<CR><LF>"
i cant predetermine this in aurdino program my code is
#include <LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
String readString;
         lcd.begin(16, 2);
        lcd.setCursor(0, 1);
        while (Serial.available()) {
        delay(10);
        char c = Serial.read();
        if (c == ',') {break;}
        readString += c; }
      if (readString.length() >0) {
      Serial.println(readString);
       if(readString == 16703301) // Here i can determine tag no only
          Serial.print("hello");
          lcd.print("hello");
        else if(readString == 16705890)
          Serial.print("HI");
          lcd.print("hi");
          Serial.print("enterno");
          lcd.print("enter no");
        readString="";
Moderator edit: CODE TAGS
so when tag is shown it cant execute if loop it displays enter no:
can anyone help to fix this
im using 125KHZ RFID Reader
« Last Edit: March 09, 2012, 02:44:12 am by AWOL » Logged
Massachusetts, USA
String readString;
You should probably be comparing String to a character string, not an integer constant:
       if(readString == "16703301")
sir i tried tht it works when i send data via serial monitor
but when this transmitted via xbee 16703301<CR><LF> it displaying serial data as 16703301 and showing enter no
RFID Reader sends 16703301<CR><LF> this data via xbee
if i connect receiver xbee to pc and opened RS232 analyzer in tht it displays 16703301<CR><LF> this data correctly.
BUT in aurdino
String readString;
         lcd.begin(16, 2);
        //expect a string like wer,qwe rty,123 456,hyre kjhg,
        //or like hello world,who are you?,bye!,
        delay(10);  //small delay to allow input buffer to fill
        char c = Serial.read();  //gets one byte from serial buffer
        if (c == ',') {break;}  //breaks out of capture loop to print readstring
        readString += c; } //makes the string readString
      Serial.println(readString); //prints string to serial port out
       if(readString =="16703301<CR><LF>")
          lcd.print("hello");
          Serial.print("HI");
          lcd.print("hi");
        readString=""; //clears variable for new input
Moderator edit: CODE TAGS again.
and showing this no only 16703301
wht can i do pls help me sir
« Last Edit: March 09, 2012, 02:44:56 am by AWOL » Logged
UK
Online Online
"16703301<CR><LF>"
Is that really what is transmitted?
Or is it
"16703301\r\n"
When posting code, please use the # icon on the editor's toolbar to give a code box - it avoids all sorts of potential code corruption and misinterpretation.
« Last Edit: March 09, 2012, 02:54:59 am by AWOL » Logged
sir i write this program to check rfid output when i declared as char it displays card no as 16703310
but when i declare as string it displays the rfid output as 49545548515148491310
String  incoming = 0;
  lcd.begin(16, 2);
  lcd.print("ARMCET");
  if (Serial . available() > 0) {
                incoming =  Serial.read();
                //Serial.println( "I received: ");
                lcd.println( incoming  );
                Serial.print(incoming );
« Last Edit: March 09, 2012, 04:03:01 am by vsathish » Logged
UK
Online Online
49 54 55 48 51 51 48 49 13 10
ASCII - look up the codes.
What happened to the code tags?
And stop calling everyone "sir" .
« Last Edit: March 09, 2012, 02:55:40 am by AWOL » Logged
16703301<CR><LF> only sir the got in RS232 analyzer
UK
Online Online
I don't understand your last post.
i cant understand this sir im new to aurdino code tags means
UK
Online Online
Put your code between the [ code ]  [ / code ] tags which appear.
Stop calling me "sir" - I am not (yet) a Knight of the Realm.
first i checked the serial input of aurdino thts y i wrote this program
  lcd.begin(16, 2);
in this when i declared as char it shows the card no as 16703301 but when i change the decleration as string it shows card no as 49545548515148491310
in the below prg i declered as string only #include <LiquidCrystal.h>
String readString;
         lcd.begin(16, 2);
       if(readString =="16703301<CR><LF>")// here i changed to "49545548515148491310" but when card shown it is not executing this loop
          lcd.print("hello");
          Serial.print("HI");
          lcd.print("hi");
« Last Edit: March 09, 2012, 04:05:28 am by vsathish » Logged
UK
Online Online
Right, go back to you last post.
Click on "modify".
Highlight all the code, then click on the # icon on the toolbar, then click "save".
Then we can talk.
I've already explained that bit - look up the decimal values of the ASCII codes for the digits 16703301
« Last Edit: March 09, 2012, 03:33:52 am by AWOL » Logged
