Topic: error, and check my code? avrdude: stk500_getsync(): not in sync: resp=0x30 (Read 1 time) previous topic - next topic
thebfs
i get this error when uploading code nano 328
Code: [Select]
also here is the code is their any problems with it?
Code: [Select]
// Constants:
// Outputs:
const int whitePin = 13;
const int bluePin = 12;
const int redPin = 11;
// Inputs:
const int blueButton = 6;
const int redButton = 5;
// Variables:
// Read: (has something physicaly attached)
int blueState = LOW;
int redState = LOW;
// Made: (has nothing physicaly attached)
int blueCount = 0;
int redCount = 0;
int blueCountTotal = 0;
int redCountTotal = 0;
  // initialize the pins outputs:
  pinMode(whitePin, OUTPUT);
  pinMode(bluePin, OUTPUT);
  pinMode(redPin, OUTPUT);
  // initialize the pins inputs:
  pinMode(blueButton, INPUT);
  pinMode(redButton, INPUT);
void loop(){
  blueState = (digitalRead, blueButton);
  redState = (digitalRead, redButton);
  Serial.println("Blue State: ");
  Serial.println(blueState);
  delay(700);
  Serial.println("Red State: ");
  Serial.println(redState);
  delay(700);
  //00000000000000000000000
  while(blueState == 1){
    blueCount++;
    redCount--;
    blueCountTotal++;
    if(blueCount >= 30){
      blueCount = 30;
    if(blueCount <= 0){
      blueCount = 0;
    if(redCount >= 30){
      redCount = 30;
    if(redCount <= 0){
      redCount = 0;
    analogWrite(bluePin, 1000);
    analogWrite(redPin, 1000);
    // serial debug
    Serial.println("Blue Count Total: ");
    Serial.println(blueCountTotal);
    delay(700);
    Serial.println("Red Count Total: ");
    Serial.println(redCountTotal);
    delay(700);
    Serial.println("Blue Count: ");
    Serial.println(blueCount);
    delay(700);
    Serial.println("Red Count: ");
    Serial.println(redCount);
    delay(700);
    delay(700);
    delay(700);
  //000000000000000000000000
  while(redState == HIGH){
   redCount++;
   blueCount--;
   redCountTotal++;
   if(redCount >= 30){
     redCount = 30;
   if(redCount <= 0){
     redCount = 0;
     blueCount = 30;
   if(blueCount <= 0){
     blueCount = 0;
i want to controll the brightnees of the leds by how long a button is pressed.
one fades, adn the other lights
also can you have negative numbers so i could change my code to the buttons adding or subtracting, and if it is negative one lights with a certain brightness(depending on how negative)
and vice versa for positive?
woody_unreal
this maybe off track for your error .. but usally see the "sync" errors for om put not being set ,,, or just a simple unplug the Ardunio, close software, and start back up. Have you tryed those steps yeat :) ?
Often wrong port seleted :)
woody_unreal
I uploaded you Sketch without error,, but i didnt breadboard the rest..... so not sure of the other problems
raymadigan
When do you get the error?
When you are downloading?  Or running your sketch?
thebfs
thanks i found out i selected wrong board, mega i needed nano. it works.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
