Topic: Digital input frecuency?? (Read 2720 times) previous topic - next topic
nahuelv
Hi, my name is Nahuel and I want to make a proyect. I have digital pulses of 50microsec of duration that came from a detector. It's not regular pulses, the only thing that I know is that the signal will be in high for 50micosec but could be 100 pulses in 1s or 3 pulses in 1s. I wan't to make a counter that say's the number of pulses in one second. I don't know how fast is the digital read, how many samples it takes?
Thanks and sorry for my English
MarkT
About 4 to 5 us per call to digitalRead I think.  If you need faster then direct port manipulation is available...
CrossRoads
Take a look at the pulseIn() function also, may do what you need already.
nahuelv
YEEEEAHHHH, Thank's CrossRoads   :)
retrolefty
Not sure that will work. He already knows the width (50usec) of the pulses, he wants to know how many pulses occur in a fixed timed sampling period.
Lefty
CrossRoads
So combine it with other stuff, maybe like this:
Code: [Select]
if ( digitalRead (startPin) == 0 ){
startTime = micros();
timeRunning = 1;
if (timeRunning == 1 & (micros() < (startTime + duration) ){
if ( pulseIn(pin, HIGH)){
pulsecount = pulsecount +1;
if (timeRunning == 1 & (micros() > (startTime + duration) ){
timeRunning = 0;
serial.print ("number of pulses ");
serial.print ln (pulsecount);
serial.print ("frequency = ");
float frequency = duration/pulsecount;
serial.println (frequency);
pulsecount = 0;
ribbery45
It is assumed that the time measured is small enough that the capacitance, COFFSET, provides a
valid voltage to the A/D Converter.
