Pages: [1] 2   Go Down
Author Topic: Arduino Ethernet no network connection(toolchain problem on amd64 linux)  (Read 2000 times)
Hello,
I just received my Arduino Ethernet and tried some example sketches. Most of them worked, but all Ethernet related examples refused to work. To track down the problem I use the following sketch:
 * Prints a message on serial console
#include <SPI.h>
#include <Ethernet.h>
// Enter a MAC address for your controller below.
// Newer Ethernet shields have a MAC address printed on a sticker on the shield
byte mac[] = {  0x90, 0xA2, 0xDA, 0x00, 0xF0, 0x59 };
//EthernetClient client;
  // start the serial library:
  // print your local IP address:
  Serial.println("Hello I'm your arduino");
  Serial.println("Trying to get an IP Address...");
This sketch works until I activate the line
by removing the comment.
The sketch doesn't work anymore (no serial output).
Any help is appreciated.
Greetings
Anaxi
« Last Edit: March 09, 2012, 04:17:08 pm by Anaximander » Logged
Austin, TX
CMiYC
How does the client object get an IP address?
www.cmiyc.com - A guide to being an Enginerd
It should get one by dhcp. But it doesn't matter because as soon as I use any ethernet related feature (notice I just want to instantiate client object) the program stops to work at all.
Austin, TX
CMiYC
Try giving a static IP and see if the behavior changes.
Changed sketch to look like this:
#include <SPI.h>
IPAddress ip(192,168,10,22);
  Ethernet.begin(mac,ip);
Still no answer via serial console.
Edit1:
I narrowed the problem down to the wz5100 functions. As soon as one of Ethernetserver or Ethernetclient is used, the arduino stops working. If I only use Ethernet.begin(mac, ip) I can at least ping the arduino.
Edit2:
Problem seems to be the toolchain on my amd64 linux box. On my windows machine everythings ok now.
This is sad. I tried avr-gcc-4.5.3 and avr-gcc-4.3.6 both without success.
Does anybody know which combination of avr-gcc / avr-libc is working on amd64 linux ?
« Last Edit: March 09, 2012, 04:20:46 pm by Anaximander » Logged
This problem got me for the last 3 days, i found a fix tho, i dont think it has anythign to do with 64bit, it is ubuntu 11.10 itself.
Here is the fix for arduino-1.0:
Open /libraries/Ethernet/utility/w5100.h from you arduino installation.
Find: (around line 268)
#define __SOCKET_REGISTER16(name, address)                   \
  static void write##name(SOCKET _s, uint16_t _data) {       \
    writeSn(_s, address,   _data >> 8);                      \
    writeSn(_s, address+1, _data & 0xFF);                    \
  static uint16_t read##name(SOCKET _s) {                    \
    uint16_t res = readSn(_s, address);                      \
    res = (res << 8) + readSn(_s, address + 1);              \
    return res;                                              \
Replace with:
    uint16_t res2 = readSn(_s,address + 1); \
    res = res << 8; \
    res2 = res2 & 0xFF; \
    res = res | res2; \
    return res;                                              \
Verified working with Ubuntu 11.10 64bit and Arduino-1.0 with ethernet shield
I changed those lines but unfortunately it doesn't help.
I also tried the "blink" example this morning and found out it doesn't work on linux, too.
Can you post me your toolchain versions (avr-gcc, avr-libc) ?
Thanks
Update
Oh well, I think I bought a hell lot of problems with these µController things.
First the blink example can be "fixed" as described here https://wiki.archlinux.org/index.php/Arduino#delay.28.29_function_doesn.27t_work
Seems that the avr-toolchain is awfully broken. Not only avr-gcc and avr-libc also binutils is affected.
Now on to find out which combination works correctly
Any help is greatly appreciated
« Last Edit: March 10, 2012, 03:08:34 am by Anaximander » Logged
Miramar Beach, Florida
avr-gcc v4.5.3 and avr-libc v1.7.1 (with patch) works with a 32 bit version of Ubuntu.
Which flavor of Linux are you using?
edit: avr-libc versions prior to 1.7.1 will have serial and/or delay problems.
avr-libc v1.7.1 or v1.8.0 (also requires a patch) are best.
« Last Edit: March 10, 2012, 07:42:43 am by SurferTim » Logged
I'm using Gentoo on AMD64
avr-gcc-4.5.3
avr-libc 1.7.1-2
also i found the patch info here:
http://code.google.com/p/arduino/issues/detail?id=605
Unfortunately it still doesn't work.
I'm using a.t.m:
*  cross-avr/avr-libc
      Latest version installed: 1.7.1
*  cross-avr/gcc
      Latest version installed: 4.4.6-r1
*  cross-avr/binutils
      Latest version installed: 2.19.1-r1
Ethernet still not working...
Update:
Tested:
*  cross-avr/gcc
      Latest version installed: 4.5.3-r2
« Last Edit: March 10, 2012, 04:12:17 pm by Anaximander » Logged
I was facing a similar problem here, but I am using a 32 bits workstation. To fix the issue I followed the steps of Reply #5 but it wasn't enough, so I have updated all the Ethernet utilities sources [1] and now it is working. I will do more tests but looks like it is fixed for me. I hope it can help you too.
Regards
[1] https://github.com/arduino/Arduino/tree/master/libraries/Ethernet/utility
Thank you all for your help.
I replaced the Ethernet/utility folder content with the files from github, but still no ethernet  smiley-sad
Still no luck with Ethernet.
Regards
Have you tried it with or without DHCP? I am still unable to connect to the internet using static IP, but I can connect to the internet with DHCP. I can ping the Arduino interface using both modes but can't access the internet with an static IP. I have tried passing the gateway and the subnet too, without success.
Pages: [1] 2   Go Up
