Topic: Password Libary with Keypad (Read 896 times) previous topic - next topic
ahd321
Hi all,
im currently doing a password lock project, im having some issues with the code while entering the password, it gives me "invalid password" regardless of the password being right or wrong, anyway here is the code below, any help will be greatly appreciated :)
Thanks...
Code: [Select]
#include <Keypad.h>
#include <Password.h>
const byte ROWS = 4; //four rows
const byte COLS = 3; //three columns
char keys[ROWS][COLS] = {
   {'1','2','3'},
   {'4','5','6'},
   {'7','8','9'},
   {'*','0','#'}
// Connect keypad ROW0, ROW1, ROW2 and ROW3 to these Arduino pins.
byte rowPins[ROWS] = { 9, 8, 7, 6 };
// Connect keypad COL0, COL1 and COL2 to these Arduino pins.
byte colPins[COLS] = { 12, 11, 10 };
// Create the Keypad
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
Password password = Password("1234");
#define ledPin  13
void setup(){
  pinMode(ledPin, OUTPUT);      // sets the digital pin as output
  digitalWrite(ledPin, HIGH);   // sets the LED on
  keypad.addEventListener(keypadEvent); //add an event listener
  keypad.setDebounceTime(250);
void loop(){
  keypad.getKey();
//take care of some special events
void keypadEvent(KeypadEvent eKey){
  switch (eKey){
    case '*': tryPassword(); break;
    case '#': password.reset(); break;
   default:  password.append(eKey);
void tryPassword(){
     Serial.print("Guessing password... ");
     if (password.evaluate()){
Serial.println("VALID PASSWORD "); //
              password.reset(); //resets password after correct entry
     }else{
Serial.println("INVALID PASSWORD ");
         password.reset(); //resets password after INCORRECT entry
kenny_-_
I'm just reading a few lines but maybe it's something in the hardware.
Did you try Serial.print(ekey); for debugging?
ahd321
thanks for the reply,
i have tried doing that aswell, cant seem to figure it out.. do you know if there is a way to have password without using the password libary? if that makes sense?
sorry my programming is not too good.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
