Loading...
Pages: [1]   Go Down
Author Topic: I need a Timer# library, does one exist  (Read 700 times)
Buena Vista, CO
Offline Offline
Full Member
Arduino rocks
View Profile
I have an Arduino 2560 with a series of sensors.
I want to transmit the values of these sensors
via a rf module ( APC220 ), at approximately
every 10 seconds. I have written a function to do this
when called. I want to use timer 4 to call this function.
The more I search  on the web, the more confused I get.
The timer2 library makes it easy but seems only for timer 2
which as I understand the example, does not extend
to near enough time. Is there a generic timer library
which allows you to use any timer? I looked at the code for timer2
and this is way past my meager knowledge. I would such a library
would be useful to many.
Jim
Logged
8000ft above the average
Netherlands
Offline Offline
Tesla Member
In theory there is no difference between theory and practice, however in practice there are many...
View Profile
This code sends the value of 4 sensors every 10 seconds
Code:
unsigned long lastTime = 0;
  Serial.println("Start...");
  if (millis() - lastTime > 10000UL)  // UL means unsigned long
    lastTime += 10000UL;
    float sensor1 = readSensor1();
    float sensor2 = readSensor2();
    float sensor3 = readSensor3();
    float sensor4 = readSensor4();
    Serial.println(sensor1);
    Serial.println(sensor2);
    Serial.println(sensor3);
    Serial.println(sensor4);
    SendRF(sensor1);
    SendRF(sensor2);
    SendRF(sensor3);
    SendRF(sensor4);
  // here you can do something else in theory
void SendRF(float value)
  // no idea how :)
float readSensor1()
  // you know this too
Logged
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
Pages: [1]   Go Up
Print
Jump to:
