I was just typing in a small, simple, sketch to help with a forum issue.
IDE 1.0. Mac version.
This sketch:
#include <iterator>
#include <string>
#include <pnew.cpp>
void setup ()
std::string foo = "Hello, world";
Serial.begin (115200);
Serial.println (foo.c_str ());
void loop () {}
Now, and this has happened before a few times suddenly the screen goes mostly blank, like this:
The cursor is down at the end (where I was typing) so I up-arrow a bit, and see this:
Up-arrow a bit more and see this:
No changes, just moving the cursor around.
Right now, as I type this, the window looks like the top screen dump, but I was able to hit copy, and paste the sketch into this message. So clearly the text is there, but it is not displaying it.
Oh yes, and in the error window at the bottom all this stuff appears:
java.lang.ArrayIndexOutOfBoundsException: 69
at processing.app.syntax.SyntaxUtilities.paintSyntaxLine(SyntaxUtilities.java:151)
at processing.app.syntax.TextAreaPainter.paintSyntaxLine(TextAreaPainter.java:644)
at processing.app.syntax.TextAreaPainter.paintLine(TextAreaPainter.java:603)
at processing.app.syntax.TextAreaPainter.paint(TextAreaPainter.java:415)
at javax.swing.JComponent.paintChildren(JComponent.java:862)
at javax.swing.JComponent.paint(JComponent.java:1038)
at javax.swing.JSplitPane.paintChildren(JSplitPane.java:1030)
at javax.swing.JLayeredPane.paint(JLayeredPane.java:567)
at javax.swing.JComponent._paintImmediately(JComponent.java:5098)
at javax.swing.JComponent.paintImmediately(JComponent.java:4882)
at javax.swing.RepaintManager.paintDirtyRegions(RepaintManager.java:812)
at javax.swing.RepaintManager.paintDirtyRegions(RepaintManager.java:714)
at javax.swing.RepaintManager.prePaintDirtyRegions(RepaintManager.java:694)
at javax.swing.RepaintManager.access$700(RepaintManager.java:41)
at javax.swing.RepaintManager$ProcessingRunnable.run(RepaintManager.java:1672)
at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:209)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:677)
at java.awt.EventQueue.access$000(EventQueue.java:85)
at java.awt.EventQueue$1.run(EventQueue.java:638)
at java.awt.EventQueue$1.run(EventQueue.java:636)
at java.security.AccessController.doPrivileged(Native Method)
at java.security.AccessControlContext$1.doIntersectionPrivilege(AccessControlContext.java:87)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:647)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:296)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:211)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:201)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:196)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:188)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:122)
Error repainting line range {0,47}:
