Netherlands
Online
Tesla Member
In theory there is no difference between theory and practice, however in practice there are many...
« Reply #30 on: March 12, 2012, 04:14:46 pm » |
goes in the right direction: //send data to serial port for debugging/read data at the PC Serial.print("A,"); Serial.println(sensorValue); Serial.print("B,"); Serial.println(speedstartValue); Serial.print("C,"); Serial.println(speedcurveValue); Serial.print("D,"); Serial.println(brakeValue); Serial.print("E,"); Serial.println(brakecurveValue); Serial.print("F,"); Serial.println(sensorMin); Serial.print("G,"); Serial.println(sensorMax); Serial.print("H,"); Serial.println(modelName);
this generates something like A,100 B,120 C,130 etc Your VB application recognizes the char and map this to the right text field. Something like this is needed to parse (VB is too long ago) intPos = InStr(strBuffer, vbCrLf) If intPos <> 0 Then Dim C as Char Dim Value as String
C = strBuffer[0]; 'or is it 1 in VB? Value = Right$(strBuffer, 2) 'skip the separator
Select Case(C) case A: TextSensorValue.Text = Value case B: ... etc End Select EndIf
Logged
The Netherlands
Offline
Full Member
« Reply #31 on: March 13, 2012, 02:36:16 pm » |
Rob, Are those C or other language? Dim C as Char C = strBuffer[0];
Paco
Logged
Never to old to learn and I learn every day
The Netherlands
Offline
Full Member
« Reply #32 on: March 15, 2012, 05:55:19 pm » |
Rob, I managed to distill the value into strValue The code could be simplified? but it works for me. I also have the newString containing the letter and seperator with value. Stuck on the case select. Watched several sample of case select but cant put my finger on it. Paco Private Sub MSComm1_OnComm() Dim boComplete As Boolean Dim intPos As Integer Dim strValue As String Dim strInput As String Dim str() As String Static strBuffer As String Dim lngPos As Long Dim lngPos2 As Long Dim newString As String Dim lngLen As Long
With MSComm1 'test for incoming event Select Case .CommEvent Case comEvReceive ' Something to receive strInput = .Input 'strBuffer = strBuffer & strInput 'Receive it and add to our static Buffer strBuffer = strInput 'Receive it and add to our static Buffer Do ' ' Check if there's a complete record in the Buffer ' NOTE: This code assumes that the sender terminates ' each record with a Carriage Return Line Feed Pair ' If this is not the case then change vbCrLf below ' to whatever the terminator is ' intPos = InStr(strBuffer, vbCrLf) If intPos <> 0 Then
lngPos = InStr(strBuffer, vbCrLf) 'catch position number of first CRLF in the buffer If lngPos > 0 Then newString = Left$(strBuffer, lngPos - 1) 'If the position is larger then 0 remove all rigth fromt the CRLF lngPos2 = InStr(newString, ",") 'catch position number of the comma in the string lngLen = Len(newString) 'measure length of string If lngPos2 > 0 Then strValue = Right$(newString, (lngLen - 2)) 'remove the letter and the : from the string Select Case (newString) 'Case A: TextSensorValue.Text = strValue 'Case B: TextStartSpeedValue.Text = strValue End Select str = Split(strInput, vbTab) 'debug line Text9.Text = strInput 'debug line ' Check if there's anything else in the Buffer ' If intPos + 1 < Len(strBuffer) Then ' ' Yes, move it to the front of the Buffer ' and go round the loop again ' strBuffer = Mid(strBuffer, intPos + 2) Else ' ' Nothing left in the Buffer ' Flush it and signal to exit the loop ' strBuffer = "" boComplete = True End If Else ' ' Haven't got a complete record yet ' exit the loop and wait for the next ' comEvReceive event ' boComplete = True End If
Logged
The Netherlands
Offline
Full Member
« Reply #33 on: March 16, 2012, 03:06:14 am » |
Have been trying to get the select case to work but I did not succeed with the sample showed by rob. Workaround made by if statement. Might be rubbish code but I got it to work. Now all the text boxes are filled with values. Option Explicit
Private Sub MSComm1_OnComm() Dim boComplete As Boolean Dim intPos As Integer Dim strValue As String Dim strInput As String Dim str() As String Static strBuffer As String Dim lngPos As Long Dim lngPos2 As Long Dim newString As String Dim lngLen As Long Dim strCase As String With MSComm1 'test for incoming event Select Case .CommEvent Case comEvReceive ' Something to receive strInput = .Input strBuffer = strBuffer & strInput 'Receive it and add to our static Buffer Do ' ' Check if there's a complete record in the Buffer ' NOTE: This code assumes that the sender terminates ' each record with a Carriage Return Line Feed Pair ' If this is not the case then change vbCrLf below ' to whatever the terminator is ' intPos = InStr(strBuffer, vbCrLf) If intPos <> 0 Then
lngPos = InStr(strBuffer, vbCrLf) 'catch position number of first CRLF in the buffer If lngPos > 0 Then newString = Left$(strBuffer, lngPos - 1) 'If the position is larger then 0 remove all rigth fromt the CRLF lngPos2 = InStr(newString, ",") 'catch position number of the comma in the string lngLen = Len(newString) 'measure length of string If lngPos2 > 0 Then strValue = Right$(newString, (lngLen - 2)) 'remove the letter and the : from the string strCase = Left$(newString, 1) If strCase = "A" Then TextSensorValue.Text = strValue If strCase = "B" Then TextStartSpeedValue.Text = strValue If strCase = "C" Then TextSpeedCurveValue.Text = strValue If strCase = "D" Then TextBrakeValue.Text = strValue If strCase = "E" Then TextBrakeCurveValue.Text = strValue If strCase = "F" Then TextSensorMinValue.Text = strValue If strCase = "G" Then TextSensorMaxValue.Text = strValue If strCase = "H" Then TextModelNumberValue.Text = strValue ' Check if there's anything else in the Buffer ' If intPos + 1 < Len(strBuffer) Then ' ' Yes, move it to the front of the Buffer ' and go round the loop again ' strBuffer = Mid(strBuffer, intPos + 2) Else ' ' Nothing left in the Buffer ' Flush it and signal to exit the loop ' strBuffer = "" boComplete = True End If Else ' ' Haven't got a complete record yet ' exit the loop and wait for the next ' comEvReceive event ' boComplete = True End If Loop Until boComplete = True End Select End With 'MSComm1
End Sub
« Last Edit: March 16, 2012, 04:26:50 am by backbone »
Logged
Seattle, WA USA
Offline
Brattain Member
Seattle, WA USA
« Reply #34 on: March 16, 2012, 11:33:43 am » |
lngPos = InStr(strBuffer, vbCrLf) 'catch position number of first CRLF in the buffer If lngPos > 0 Then newString = Left$(strBuffer, lngPos - 1) 'If the position is larger then 0 remove all rigth fromt the CRLF lngPos2 = InStr(newString, ",") 'catch position number of the comma in the string lngLen = Len(newString) 'measure length of string If lngPos2 > 0 Then strValue = Right$(newString, (lngLen - 2)) 'remove the letter and the : from the string You never modify newString to remove the comma and the stuff that follows it, so newString will still contain something like "A,24" which is not 'A'. The code in the next post DOES create a new variable that is the stuff before the comma, so a switch/case would work.
Logged
The Netherlands
Offline
Full Member
« Reply #35 on: March 16, 2012, 12:12:58 pm » |
Paul, Thanks for reading and once again for the lessons sofar. Now I reread again I had a typo and an explanation ommision in that last 2 code lines. lngPos = InStr(strBuffer, vbCrLf) 'catch position number of first CRLF in the buffer If lngPos > 0 Then newString = Left$(strBuffer, lngPos - 1) 'If the position is larger then 0 remove all rigth fromt the CRLF lngPos2 = InStr(newString, ",") 'catch position number of the comma in the string lngLen = Len(newString) 'measure length of string If lngPos2 > 0 Then strValue = Right$(newString, (lngLen - 2)) 'remove the letter and the "," from the string strCase = Left$(newString, 1) 'leave the data only in this string Ran into an other issue for which I am looking for simple if statement trapping for the first few loops the buffer is filled. As the value in strCase now sometimes are not only byte values (from 0 to 255) but like "A,0B1" for the first loops I like to make a if statement that checks if ther are only byte values in strValue otherwise skip. something like this: If ((strValue <0) and (>255)) Then strValue = vbNullString Else 'RUN code end if But the check for 0 to 255 should be in BYTE mode? Paco
Logged
Seattle, WA USA
Offline
Brattain Member
Seattle, WA USA
« Reply #36 on: March 16, 2012, 12:22:03 pm » |
If ((strValue <0) and (>255)) Then Something is missing here, and something is wrong. If the missing piece is strValue in the parentheses after the and, then the statement would be: If ((strValue <0) and (strValue >255)) Then There are not two many values that are less than 0 and greater than 255 at the same time.
Logged
The Netherlands
Offline
Full Member
« Reply #37 on: March 16, 2012, 12:28:57 pm » |
Paul again my fault. Your correct. If ((strValue <0) and (strValue >255)) Then I kow it is not correct in code but did not know how to describe it in code . So in words what I tried to accomplish: If the value inside strValue is not a chrachter from 0 to 255 and nothing else like comma, letters or other charchaters then......... Paco
Logged
Netherlands
Online
Tesla Member
« Reply #38 on: March 17, 2012, 12:01:52 pm » |
you can describe what it is
If (strValue = X )
or
if ((strValue <0) OR (strValue >255)) Then ..
IIRC strValue can never be smaller than 0 in VB but I'm not sure my knowledge of VB is rather ...eh... basic
Logged
The Netherlands
Offline
Full Member
« Reply #39 on: March 26, 2012, 01:38:53 pm » |
Had some help from an other VB forum to get things done. The VB code is below. Now need to work on the code to send the data back to the UNO if it is changed in the PC control panel. So the display on the UNO displays the same data as the PC control panel and vice versa. Private Sub MSComm1_OnComm() Static strBuffer As String Static boSync As Boolean Dim strData As String Dim strRec As String Dim intPos As Integer Dim boComplete As Boolean With MSComm1 Select Case .CommEvent Case comEvReceive strData = .Input strBuffer = strBuffer & strData Do intPos = InStr(strBuffer, vbCrLf) If intPos > 0 Then strRec = Mid$(strBuffer, 1, intPos - 1) ' ' Have we synchronised yet ? ' If Not boSync Then ' ' Ignore everything until a "A" record is received ' Once it has been, then set the synchronised flag ' and start processing ' If Mid$(strRec, 1, 1) = "A" Then boSync = True Call ProcessRecord(strRec) End If Else ' ' We are synchronised so process the data received ' Call ProcessRecord(strRec) Label12.Caption = "Syncronized" Label12.ForeColor = vbBlack End If If Len(strBuffer) > intPos + 1 Then strBuffer = Mid(strBuffer, intPos + 2) Else strBuffer = "" boComplete = True End If Else boComplete = True End If Loop Until boComplete = True End Select End With End Sub
Private Sub ProcessRecord(strRec As String) ' ' StrRec is expected to be: ' Single Alphabetic character between A and K (inclusive, excluding I) ' followed by a comma ' followed by a number between 0 and 255 (inclusive) ' eg ' A,120 ' Dim strParts() As String Dim strValue As String Dim intI As Integer Dim boError As Boolean intI = 1 ' ' Ignore null records ' If strRec <> vbNullString Then strParts = Split(strRec, ",") ' ' Check that there's two values ' If UBound(strParts) = 1 Then ' ' Check that the second value is numeric ' Do If Mid$(strParts(1), intI, 1) < "0" Or Mid$(strParts(1), intI, 1) > "9" Then boError = True Else intI = intI + 1 End If Loop Until boError Or intI > Len(strParts(1)) If Not boError Then ' ' Second value is numeric check it's in the correct range ' If CInt(strParts(1)) >= 0 And CInt(strParts(1)) <= 1024 Then strValue = strParts(1) ' ' Set the appropriate TextBox to the value sent ' Select Case strParts(0) Case "A" TextSensorValue.Text = strValue Case "B" TextStartSpeedValue.Text = strValue Case "C" TextSpeedCurveValue.Text = strValue Case "D" TextBrakeValue.Text = strValue Case "E" TextBrakeCurveValue.Text = strValue Case "F" TextSensorMinValue.Text = strValue Case "G" TextSensorMaxValue.Text = strValue Case "H" TextModelNumberValue.Text = strValue Case "J" TextSpeedValue.Text = strValue Case "K" TextDeathBandValue.Text = strValue Case Else ' ' Unrecognised Letter ' Debug.Print "Invalid Code Received: " & strRec, , "Process Record" End Select Else ' ' Value is out of range ' Debug.Print "Value Received is out of range: " & strRec, , "Process Record" End If Else ' ' Value is non-numeric ' Debug.Print "Non-Numeric Value Received: " & strRec, , "Process Record" End If Else ' ' Less than or more than two items in the data ' 'MsgBox "Invalid Record Format: " & strRec, , "Process Record" Debug.Print "Invalid Record Format: " & strRec, , "Process Record" End If End If 'send the data to a progressbar ARProgressBar1.Value = TextSpeedValue.Text ARProgressBar2.Value = TextStartSpeedValue.Text ARProgressBar3.Value = TextSpeedCurveValue.Text ARProgressBar4.Value = TextBrakeValue.Text ARProgressBar5.Value = TextBrakeCurveValue.Text ARProgressBar6.Value = TextSensorValue.Text End Sub
« Last Edit: March 26, 2012, 01:41:33 pm by backbone »
Logged
Netherlands
Online
Tesla Member
« Reply #40 on: March 26, 2012, 02:33:42 pm » |
Thanks for posting this working code !
Logged
