Both options sound good to me. Here's the code, stolen from various sources and cobbled together.
First half:
#include <OneWire.h>
#include <DallasTemperature.h>
#include <SD.h>
#include <Ethernet.h>
#include <SPI.h>
#include <Wire.h>
#include <Time.h>
//SD INTERFACE ##############################
//- uses pin 4 on ethernet shield
const int chipSelect = 4;
//RELAY SETUP #########################
const int R01 = 7; // Relay for main CH Pump
const int R02 = 8; // Relay for Wood Burner Pump
const int R03 = 9; // Relay for Solar Thermal HW Pump
int R01Status; //for holding relay status to change into text
int R02Status; //for holding relay status to change into text
int R03Status; //for holding relay status to change into text
// 1 WIRE####################################
#define ONE_WIRE_BUS 3 //microlan on pin 3
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature sensors(&oneWire);
// Assign 1 wire addresses
DeviceAddress T01 = { 0x28, 0xAD, 0x34, 0x80, 0x03, 0x00, 0x00, 0xAE }; //Outside temp
DeviceAddress T02 = { 0x28, 0x58, 0x61, 0x80, 0x03, 0x00, 0x00, 0x70 }; //Hallway temp
//DeviceAddress T03 = { 0x28, 0x82, 0xAF, 0x80, 0x03, 0x00, 0x00, 0xFB }; //future
DeviceAddress T04 = { 0x28, 0x80, 0x7E, 0xAA, 0x03, 0x00, 0x00, 0x6D }; //Esse Centraliser temp
DeviceAddress T05 = { 0x28, 0xD0, 0x8E, 0xAA, 0x03, 0x00, 0x00, 0xE5 }; //Wood Burner Flow temp
DeviceAddress T06 = { 0x28, 0x6E, 0xA8, 0xAA, 0x03, 0x00, 0x00, 0x95 }; //Wood Burner Return temp
DeviceAddress T07 = { 0x28, 0x8E, 0x72, 0xAA, 0x03, 0x00, 0x00, 0x5F }; //HW Tank Top temp
DeviceAddress T08 = { 0x28, 0x21, 0x8A, 0xA9, 0x03, 0x00, 0x00, 0x37 }; //HW Tank Mid temp
DeviceAddress T09 = { 0x28, 0xFD, 0x79, 0xAA, 0x03, 0x00, 0x00, 0xEE }; //HW Tank Bottom temp
//DeviceAddress T10 = { 0x28, 0x70, 0x89, 0xAA, 0x03, 0x00, 0x00, 0xE8 }; //Solar Thermal collector temp
//DeviceAddress T11 = { 0x28, 0x8B, 0x86, 0xAA, 0x03, 0x00, 0x00, 0x0D }; //future
//DeviceAddress T12 = { 0x28, 0x80, 0xAA, 0xAA, 0x03, 0x00, 0x00, 0x2C }; //future
//DeviceAddress T13 = { 0x28, 0xA5, 0xA1, 0xAA, 0x03, 0x00, 0x00, 0x01 }; //future
//DeviceAddress T14 = { 0x28, 0x75, 0xA6, 0xAA, 0x03, 0x00, 0x00, 0x94 }; //future
//DeviceAddress T15 = { 0x28, 0x02, 0x9F, 0xAA, 0x03, 0x00, 0x00, 0xFE }; //future
//DeviceAddress T16 = { 0x28, 0xC2, 0x8F, 0xAA, 0x03, 0x00, 0x00, 0x1D }; //future
//DeviceAddress T17 = { 0x28, 0x0F, 0xA7, 0xAA, 0x03, 0x00, 0x00, 0x0E }; //future
//DeviceAddress T18 = { 0x28, 0x46, 0x7A, 0xAA, 0x03, 0x00, 0x00, 0x5F }; //future
// ETHERNET #######################################
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //ethernet shield MAC address
byte ip[] = { 192,168,0,77 }; // Ethernet IP local IP address
Server server(80); // Ethernet port numnber
//LIQUID CRYSTAL
LiquidCrystal_I2C lcd(0x27,16,2); //16 x 2 LCD definition
const int buttonPin = 2; //defines button pin to switch on LCD display
int buttonState = 0; // holder for the button pressed or not
void setup(void)
//RELAY Startup
pinMode(R01, OUTPUT);
digitalWrite (R01, HIGH); //to avoid relay firing on startup make sure set to high here
pinMode(R02, OUTPUT);
digitalWrite (R02, HIGH); //to avoid relay firing on startup make sure set to high here
//START ETHERNET
Ethernet.begin(mac, ip);
server.begin();
//START 1 WIRE LIBRARY#########
sensors.begin();
// set the resolution to 10 bit
sensors.setResolution(T01, 10);
sensors.setResolution(T02, 10);
//sensors.setResolution(T03, 10);
sensors.setResolution(T04, 10);
sensors.setResolution(T05, 10);
sensors.setResolution(T06, 10);
sensors.setResolution(T07, 10);
sensors.setResolution(T08, 10);
sensors.setResolution(T11, 10);
//sensors.setResolution(T10, 10);
//ENTER TIME #########################
setTime(12,0,0,10,3,12); // set time to noon Jan 1 2011
//START CARD ###
Serial.print("Initializing SD card...");
pinMode(10, OUTPUT);
if (!SD.begin(chipSelect)) {
Serial.println("Card failed, or not present");
return;
Serial.println("card initialized.");
//LCD STARTUP ######
pinMode(buttonPin, INPUT);
lcd.init();
//SETUP TIME for serial print#################################################
void digitalClockDisplay(){
// digital clock display of the time
Serial.print(hour());
printDigits(minute());
printDigits(second());
Serial.print(" ");
Serial.print(day());
Serial.print(" ");
Serial.print(month());
Serial.print(" ");
Serial.print(year());
void printDigits(int digits){
Serial.print(":");
if(digits < 10)
Serial.print('0');
Serial.print(digits);
// VOID LOOP ###################################################
void loop(void)
//THERMOSTATS ###############
//turn main CH pump on and off based on centraliser temp
{if ((sensors.getTempC(T04)) > 52 && (digitalRead(R01) == 1)) digitalWrite (R01, LOW); //CH pump starts when centraliser temp > 52
else if ((sensors.getTempC(T04)) < 49 && (digitalRead(R01) == 0)) digitalWrite (R01, HIGH); //if relay energised and drops below 50 turn off
//turn on WBS pump when WBS feed up to temperature
{if ((sensors.getTempC(T05)) > 75 && (digitalRead(R02) == 0)) digitalWrite (R02, LOW); //pump on if > temperature and pump is off
else if ((sensors.getTempC(T05)) < 73 && (digitalRead(R02) == 0)) digitalWrite (8, HIGH); //pump off if < temp and pump was on
//SERIAL OUTPUT DATA #######
delay(2000);
digitalClockDisplay();
Serial.print(", ");
sensors.requestTemperatures();
Serial.print("Outside Temp: ");
Serial.print(sensors.getTempC(T01));
Serial.print(", ");
Serial.print("Inside Temp: ");
Serial.print(sensors.getTempC(T02));
//etc etc for other readings
// SD CARD OUTPUT DATA ########
File dataFile = SD.open("Test.txt", FILE_WRITE);
