Loading...
Pages: [1]   Go Down
Author Topic: Serial.write(0x00) issue. Solved. Doc change suggestion.  (Read 1449 times)
Offline Offline
Newbie
View Profile
I was quite perplexed when I tried to send a null byte (0x00) over the Serial interface. After reading http://arduino.cc/en/Serial/Write  I tried
Code:
Serial.write(0x00);
and got this error returned..
call of overloaded 'write(int)' is ambiguous
It turns out that I had to do this...
Code:
Serial.write((byte)0x00);
This is something that might be nice to add to the reference docs.
Logged
Left Coast, CA (USA)
Online Online
Brattain Member
Measurement changes behavior
View Profile
Code:
Serial.write(0x00);
Code:
That problem and that solution has been posted before. It showed up with Arduino IDE release 1.0. I'm pretty sure they have a fix that will be released in the next IDE release in a month or so that casting fix should not be needed there after.
Lefty
Logged
SE USA
Offline Offline
Faraday Member
@ssh0le
View Profile
I just ran into this today, so its still not fixed on 1.0.1
Logged
Pages: [1]   Go Up
Print
Jump to:
