Topic: GameCube Controller + Arduino (My First Project) (Read 3511 times) previous topic - next topic
hunter2379
HI! I'm new here and new to arduino and circuits overall. My first project is to interface the arduino with a gamecube controller.
I have found gamecube pinouts on google and have striped the gamecube controller wires. Then I soldered them to jumpers so I can connect everything easier. My current problem is that the arduino returns only 0's.
Current Pinout:
Yellow             5V power supply (used by rumble motor).
Red                   DATA line: bi-directional data to/from console, pull-up to 3.43V
Green & White   Ground.
Blue    1            3.3V logic supply
The red cable is connected to the digital pin 2 on the arduino.
This is my current code:
Code: [Select]
const int dataPin =  2;
pinMode(dataPin, INPUT);
  int sensorValue = digitalRead(dataPin);
  Serial.println(sensorValue);
As I said, I only see 0's in the serial monitor. Any help is appreciated. Thank you!
PaulS
Quote
What else is connected to the Arduino?
hunter2379
Thats it. whats the pull-up to 3.43v anyways?
PaulS
Quote
Where is this connected? Why is this connected?
Quote
hunter2379
Yellow is connected to the 5v on the arduino.
Blue is connected to the 3.3v on the arduino.
PaulS
Quote
2 out of 3 ain't bad. Sounds like a Meatloaf song.
hunter2379
uk350
You maybe get only 0 if you havent pull-up resistor to keep dataline high state.
Connect resistor between red and blue wire. value for resistor can be 10 kohm or something like that.
hunter2379
[/quote]
What I just tried was red(Data) to bread board row 1.
blue(3.3v) to bread board row 2.
Then jumperA on row 1 to pin 2. So Red>bread board>pin2
Then resistor from row 1 to row 2. So the resistor is linking data row with 3.3v from controller.
Is this correct????
hunter2379
Ok glad it's correct. My program still shows only 0's though. Someone had said that I needed to slow down the input. If this is correct would anyone show me how?
