Pages: [1] 2   Go Down
Author Topic: record data from potentiometer & playback to servo  (Read 1064 times)
Hello everyone. First of all, I'm new at this and this is an amazing technology and supporting community!  smiley
For the last month I've been reading stuff and working on my 1st project and the amount of info given here is great.
Now for my question (I've looked around but wasn't able to find answers):
Using the Knob sketch I'm building a Follow Focus for my camera.
what I'm trying to figure out is how be able to add a "Record" function to the code.
What I mean is to have the ability to to push a button telling to Arduino to record my potentiometer data
(as I move it, the servo of course moves and changes the focus on my camera),
than "stop" the recording and play it back causing the servo to repeat (once)
the movement and timing of my "focus pulling".
I would appreciate any advice, or if someone could point me to a relevant link.
New Jersey
Look at arrays. As a precursor, write a sketch with an array initialized with some potentiometer values. Iterate through them to make the servo move to different positions. Don't forget to allow some time between each or the servo will appear to immediately go to the last value.
Then you need to adapt that code to take potentiometer values and store them in the array when you set a switch to tell it to. Be careful - it will be easy to overflow the bounds of the Arduino's memory if you don't check your array bounds.
Does the playback have to be at the same speed that you did it? If so, it's going to be a little more complicated.
Hey wildbill, thanks for the reply.
Indeed I want the playback to be at the same speed as the real event...
This seems too complicated for my stage at this  smiley-red
As for the first part of your answer, is there a sample of a sketch that utilizes the technique you mentioned?
I'm a real noob at this...
New Jersey
Here's the knob sketch so adjusted:
#include <Servo.h>
Servo myservo;  // create servo object to control a servo
int potpin = 0;  // analog pin used to connect the potentiometer
int val;    // variable to read the value from the analog pin
int potvalues[10]={100,900,200,800,1000,50,900,500,0,1023};
myservo.attach(9);  // attaches the servo on pin 9 to the servo object
//  val = analogRead(potpin);                 // reads the value of the potentiometer (value between 0 and 1023) - left in so you can see what replaced it
for(int i=0;i<10;i++)
  val = map(potvalues[i], 0, 1023, 0, 179);  // scale it to use it with the servo (value between 0 and 180)
  myservo.write(val);                        // sets the servo position according to the scaled value
  delay(200);                                // wait for the servo to get there
delay(3000);                                 // wait before starting the sequence again
Compiled, not tested. It illustrates the principle, but it isn't very good code. The use of all those manifest constants, particularly 10, is a sin. The use of delay too, is handy here, but not recommended generally.
wildbill thanks a lot!
Will read, understand, try and reply!
 smiley-wink
My project is slowly progressing (actually I should say I'M slowly progressing...) and my 3 questions are:
1. Is it possible to store the pot data into an array while at the same time send it over to the servo? This way I can both see what I'm doing and "record" the info for later retrieval.
2. In this project I'm expanding on the Knob sketch, adding the array in order to record. I want to be able to begin , stop and playback this recording using buttons. This means putting some "If" structures into the main loop of the sketch. Will this make my reading from the pot and writing to the servo slower (because the code will check to see if the button is pressed)? Should I use another structure? Is Interrupt better suited for this?
3. By other structure I mean maybe 2 loops that can be switched between by a button. Is that even possible?
Thanks
« Last Edit: March 16, 2012, 04:11:41 am by Soffer » Logged
update:
1. Yes I can.
2&3 - would still appreciate a pointer or two.
 smiley
New Jersey
2. Not appreciably. The Arduino is lightning fast compared to any actions you're taking, so it'll take finite time to execute the extra steps, but you won't notice. Interrupts? No.
3. Not sure what you mean. You can have multiple different functions called from loop & vary which are called based on button presses. You can't have multiple functions called loop though.
Hey. I guess phase 1 is done. I'm able to control, record, play in reverse and play in original order.
Now it's controlled through serial monitor and my next phase is to control it with 4 switches.
I'm attaching the code and would appreciate remarks. Remember - I'm a complete noob, so please don't be too hard on me..
Edit - code attached as should be in my next post...
« Last Edit: March 19, 2012, 05:55:28 am by Soffer » Logged
Gosport, UK
Can you modify your post to use [code] tags, instead of [quote]. It looks like you aren't using array indexing to store the servo position, but that could well be because the [i] is being converted to an italic tag.
whoops, let me try again...
 smiley-red
// Controlling a servo position using a potentiometer (variable resistor)
// with the option of recording the movement, playing it in reverse and in original order.
// Adi Soffer 19.3.12
#include <Servo.h>
   char buffer [5];              //variable to hold keystrokes
   int servoPos[300];           //create array 300 values for servo position
   int incomingByte;            //declare variable to hold incoming letter
     Serial.flush();
     myservo.attach(3);           // attaches the servo on pin 3 to the servo object
  void loop ()
   if (Serial.available( ) > 0)
       incomingByte = Serial.read ( );
       if (incomingByte == 'F')
          Serial.println ("Free mode");
          while (incomingByte == 'F')
          val = analogRead (potpin);
          val = map(val, 0, 1023, 0, 179);
          myservo.write (val);
          delay (10);
          if (Serial.available ( ) > 0)
            if (incomingByte == 'R')
              Serial.println ("Record inside");                  // if so - prints record inside for checkup
              delay(15);
              for (int i=0;i<299;i++)                              //for loop to store 300 values of pot
              val = map(val, 0, 1023, 0, 179);                // scale it to use it with the servo (value between 0 and 180)
              servoPos [i]=val;                                     // stores val in array "servoPos
              delay(15);                                              // waits for the servo to get there
              Serial.println(val);                                   // print values for checking
           else if (incomingByte == 'H')
            Serial.println ("Home inside");
            //delay(15);
            for (int i=299;i>0;i--)
              myservo.write (servoPos[i]);           //reads values from array in reverse to servo
              delay(15);
              Serial.println (servoPos[i]);
           else if (incomingByte = 'P')
             Serial.println ("Playback inside");       // if so prints for checkup
             //delay(15);
               myservo.write (servoPos[i]);          //reads values from array in original order to servo
               delay (15);
          else if (incomingByte == 'R')                // checks if input was capital R
            Serial.println ("Record");                   // if so - prints record
            delay(15);
            Serial.println ("Home");
            //delay(15);
              delay(15);
             Serial.println ("Playback");
             //delay(15);
               delay (15);
« Last Edit: March 19, 2012, 03:56:32 am by Soffer » Logged
If you're not living on the Edge, you're taking up too much space!
I have a similar problem.  I'm trying to get the data from 3-D animation software into the Sketch to move the servos.  I have the output movement working, but the process of loading it is tedious.  Maybe I should try pots?  I want the movement to look natural like a human body moving.
If you fall... I'll be there for you!
-Floor
Skype Brighteyes3333
(262) 696-9619
sbright33, that sounds extremely interesting, and quite close to my field of interest  smiley
Are you using arrays to store the values from the software?
And here again is the code, more organised, using functions...
#include <Servo.h>
     Serial.flush();
  void loop ()
          delay (10);
             recordFunction ( );
           reverseFunction ( );
             playBackFunction ( );
           recordFunction ( );
void playBackFunction ( )
          Serial.println ("Playback Function");
             delay (15);
 void reverseFunction ( )
          Serial.println ("Home function");
             delay(15);
void recordFunction ( )
   Serial.println ("Record function");                    // if so - prints record
            delay(15);
@Soffer- Yes, but we have not determined which software to use for motion easing.  Is there one you like best?  Can it export these values to a text file?
-Floor
(262) 696-9619
Pages: [1] 2   Go Up
