Loading...
Pages: [1]   Go Down
Author Topic: why my motors not running in this program.  (Read 447 times)
Offline Offline
Newbie
View Profile
int kp = 50;
int ki = 5 ;
int kd = 5;
int integral = 0;
int d = 0;
int output;
int preverr = 0;
int err = 0;
int change;
int count = 0;
int right_speed,left_speed;
int mod_err;
void setup ()
  pinMode(2,INPUT);
  pinMode(3,INPUT);
pinMode(4,INPUT);
  pinMode(5,INPUT);
  pinMode(6,INPUT);
  pinMode(10,OUTPUT);
  pinMode(11,OUTPUT);
  right_speed = 0;
  left_speed = 0;
void loop ()
  while(1)
    analogWrite(10,left_speed);
    analogWrite(11,right_speed);
  count++;
  00100 = 0
  00110 = 1  01100 = -1
  00010 = 2  01000 = -2
  00011 = 3  11000 = -3
  00001 = 4  10000 = -4
     00000 = 5/-5 depending on preverr */
     if((!digitalRead(2))&&(!digitalRead(3))&&(digitalRead(4))&&(!digitalRead(5))&&(!digitalRead(6)))
       err = 0;
      integral = 0;
  else if((!digitalRead(2))&&(!digitalRead(3))&&(digitalRead(4))&&(digitalRead(5))&&(!digitalRead(6)))
      err = 1;
   else if((!digitalRead(2))&&(!digitalRead(3))&&(!digitalRead(4))&&(digitalRead(5))&&(!digitalRead(6)))
      err = 2;
    else if((!digitalRead(2))&&(!digitalRead(3))&&(!digitalRead(4))&&(digitalRead(5))&&(digitalRead(6)))
      err = 3;
    else if((!digitalRead(2))&&(!digitalRead(3))&&(!digitalRead(4))&&(!digitalRead(5))&&(digitalRead(6)))
      err = 4;
    else if((!digitalRead(2))&&(!digitalRead(3))&&(!digitalRead(4))&&(!digitalRead(5))&&(!digitalRead(6)))
      if (preverr = 0)
      {err = 0;}
      else if(preverr > 0)
      {err = 5;}
      else if (preverr < 0)
      {err = -5;}
    else if((!digitalRead(2))&&(digitalRead(3))&&(digitalRead(4))&&(!digitalRead(5))&&(!digitalRead(6)))
      err = -1;
   else if((!digitalRead(2))&&(digitalRead(3))&&(!digitalRead(4))&&(!digitalRead(5))&&(!digitalRead(6)))
      err = -2;
    else if((digitalRead(2))&&(digitalRead(3))&&(!digitalRead(4))&&(!digitalRead(5))&&(!digitalRead(6)))
      err = -3;
    else if((digitalRead(2))&&(!digitalRead(3))&&(!digitalRead(4))&&(!digitalRead(5))&&(!digitalRead(6)))
      err = -4;
    change = err - preverr;
    if(err > 0)
    if ( change < 0 )
     d= 1/count;
     count = 0;
    else if (change > 0)
      d = -(1/count);
     count = 0;
    else if(err < 0)
    if ( change > 0 )
     d= 1/count;
     count = 0;
    else if (change < 0)
      d = -(1/count);
     count = 0;
    if (change == 0){d=0;}
    if (err>0)mod_err = err;
    else mod_err = -err;
    integral = integral + mod_err;
    output = 255-(kp*mod_err + ki*integral - kd*d);
    MotorControl(output,err);
    preverr = err;
void MotorControl(int output,int err)
  int k;
  k = output;
  if(k<0){k=0;}
  else if(k>255){k = 255; }
  if ( err = 0)
    right_speed = 255;
    left_speed = 255;
    if ( err > 0 )
      left_speed = 255;
      right_speed = k;
    else if (err < 0)
      right_speed = 255;
     left_speed = k;
  }Serial.println(k);
Logged
Offline Offline
Newbie
View Profile
my board is Arduino Duemilanove w/ atmega168
Logged
Gosport, UK
Offline Offline
Faraday Member
View Profile
I don't know why, but edit your post and put code tags around the sketch using the '#' button.
Why do you do this?
Code:
void loop ()
  while(1)
What function does an infinite loop inside an infinite loop serve?
You're using ints, so what does d equal when count > 1?
Code:
    d= 1/count;
What is attached to the pins you are reading?
I suggest you add more debugging prints, and see what is happening while the code is running - I would at least want to know what values err was taking.
« Last Edit: March 11, 2012, 01:24:30 pm by dxw00d » Logged
Global Moderator
UK
Online Online
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
Suggest combining the reads into a single integer and a switch/case.
Have a look at bitWrite if you're not used to binary arithmetic.
But code tags, mmm yeah, code tags.
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
Pages: [1]   Go Up
Print
Jump to:
