Topic: IR receiver , unusual remote DVD control (Read 1 time) previous topic - next topic
United121
Hello ,
i have problem with my IR receiver . I'm trying to construct project which can control motor through remote DVD control . I found this libraby for IR remote http://www.arcfn.com/2009/08/multi-protocol-infrared-remote-library.html but I'm trying to "tune" with my remote DVD control. I found similar type of it ( i have Philips DVP5140 but the remote control of Philips DVP-5982 looks like equally ). But the bigest problem with library is that when I try to send signals to IR receiver (connect with arduino) I receive zero ("0") ( I receive this for all remote control which I have :
I have this IR receiver http://catalog.osram-os.com/catalogue/catalogue.do?favOid=00000002000246c8001c0023&act=showBookmark
Code: [Select]
* IRremote: IRrecvDemo - demonstrates receiving IR codes with IRrecv
* An IR detector/demodulator must be connected to the input RECV_PIN.
* Version 0.1 July, 2009
* Copyright 2009 Ken Shirriff
* http://arcfn.com
#include <IRremote.h>
int RECV_PIN = 11;
IRrecv irrecv(RECV_PIN);
decode_results results;
  irrecv.enableIRIn(); // Start the receiver
  if (irrecv.decode(&results)) {
    Serial.println(results.value, HEX);
    irrecv.resume(); // Receive the next value
and it doesnt matter what i press :
Greetings from Czech republic and sorry for my english. Thank you in advance.
johnwasser
If the IRRemote library doesn't recognize the encoding scheme it will provide only the raw pulse times.  Here is an article about using unknown remotes:
http://www.arcfn.com/2010/01/using-arbitrary-remotes-with-arduino.html
Send Bitcoin tips to: 1L3CTDoTgrXNA5WyF77uWqt4gUdye9mezN
Send Litecoin tips to : LVtpaq6JgJAZwvnVq3ftVeHafWkcpmuR1e
United121
I tried it , but the result is interesting for me :
I recived different values but I pressed only ONE button. That means what ?
United121
And when I use different remote control I received first value diferent but when I keep button pressed I receive the same value for rest of value :
johnwasser
Some remotes send the same code repeatedly.  Some send a "repeat" code to indicate that the same button is held down.  You write your code to do what you want with the information you get.
United121
I did it and I have some "number of button" and I also know which button was pressed .
Code: [Select]
unsigned long hash = decodeHash(&results);
    Serial.print(hash); //additions for control
    if(hash == 3398190446) // this is number for button 1
      digitalWrite(3,HIGH);
    }else if ( hash == 3717434288 ) // this is number for button 2
     else {
        digitalWrite(3,LOW);
But I need know how I can recongnize that the button is still pressed (the problem is that then remote control send different "number" and I dont know how I "keep the light on"). Can you suggest any solution.
I also have PIC related web domain.
United121
I am sorry but I dont understand what you write . Can you explain it a bit ?
United121
Can somebody help me ? I have spent with it almost 3 hours and I'm exhausted . I work towards this one :
Code: [Select]
    Serial.print(hash);
    if(hash != 1253111734){
      volba = hash;
    if(hash == 1253111734 && volba == 3398190446){
      }else if(hash == 1253111734 && volba == 3717434288){
    irrecv.resume();
but I still don't know where I should place digitalWrite(3,LOW) . I tried a few possibilities but no one work as I want . Idea is simply = when the button is pushed - LED turn on and when the button is not pushed - LED off .
johnwasser
Unfortunately the remote doesn't send a message for "The button is not pushed".  Perhaps you should restart a timer each time you get the "Button is pressed" message and, if the time runs out, turn off the LED.
Code: [Select]
unsigned long LastTimeButtonWasPressed;
    if (received a button pressed message)
            turn on LED;
            buttonIsPressed = true;
            LastTimeButtonWasPressed = millis();
    if (buttonIsPressed && millis() - LastTimeButtonWasPressed > 100)
         turn off LED;
         buttonIsPressed = false;
United121
WOW it works. Although when the LED should turn on then LED blinks but it doesn't matter ( it may be caused complexity of code ). For my purpose is it sufficient , at least I think.Thank you for your time and your very important advice .
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
