Topic: artnet to dmx project. memory issues? (Read 4975 times) previous topic - next topic
gaggenau
the project:
my goal is to use a arduino UNO to make a artnet node. this will convert artnet to dmx.
hardware: Arduino UNO with a ethernet shield and a proto shield with sn75176 ic connected to digital pin 3 for dmx out.
IDE: arduino 1.0
libraries used: DmxSimple, SPI, Ethernet, EthernetUdp.
Link to DmxSimple Library: http://code.google.com/p/tinkerit/wiki/DmxSimple
The Dmx Simple Library is modified to work with arduino 1.0
The code is 99% made by Christoph Guillermet
original code can be downloaded from here:
http://vvvv.org/contribution/artnet-arduino-set-v2
I have added the dmx out feature to the code and adapted it for Arduino 1.0.
to my problem! This code sort of works. It is working for about 10 seconds of changeing values and then i freezes.
Im guessing this has to do with some sort of memmorie issue. im also guessing it has to do with the DmxSimple library bacuse the original sketch does not have this issues.
Things i have tried: Instead of receiving all of the 512 dmx channels i have tried to limit this to just one. but same thing happens but after ca 25 seconds instead of 10.
so does some one have clue how i can solve this ?
The Code
Code: [Select]
ARTNET RECEIVER V2
This SCRIPT allows you to use arduino with ethernet shield or wifi shield and recieve artnet data. Up to you to use channels as you want.
If you have implemented ameliorations to this sketch, please, contribute by sending back modifications, ameliorations, derivative sketch. It will be a pleasure
to let them accessible to community
For VVVV patchers, please think to put a mainloop node in your patch: minimum frame rate is 40fps with bulbs. But do not go too much higher ( max 100 fps).
This sketch is part of white cat lighting board suite: /http://www.le-chat-noir-numerique.fr
wich is sending data to many different types of devices, and includes a direct communication in serial also with arduino likes devices
you may find whitecat interresting because its theatre based logic ( cuelist and automations) AND live oriented ( masters, midi, etc)
(c)Christoph Guillermet
karistouf@yahoo.fr
#include <DmxSimple.h>
#include <SPI.h>         // needed for Arduino versions later than 0018
#include <Ethernet.h>
#include <EthernetUdp.h>          // UDP library from: bjoern@cs.stanford.edu 12/30/2008
#define short_get_high_byte(x) ((HIGH_BYTE & x) >> 8)
#define short_get_low_byte(x)  (LOW_BYTE & x)
#define bytes_to_short(h,l) ( ((h << 8) & 0xff00) | (l & 0x00FF) );
//MAC and IP of the ethernet shield
//MAC adress of the ethershield is stamped down the shield
//to translate it from hexa decimal to decimal, use: http://www.frankdevelopper.com/outils/convertisseur.php
//HARDWARE
byte mac[] = {  144, 162, 218, 00, 16, 96  };//the mac adress of ethernet shield or uno shield board
IPAddress  ip(192,168,0,60 );// the IP adress of your device, that should be in same universe of the network you are using, here: 192.168.1.x
// the next two variables are set when a packet is received
byte remoteIp[4];        // holds received packet's originating IP
unsigned int remotePort; // holds received packet's originating port
//customisation: edit this if you want for example read and copy only 4 or 6 channels from channel 12 or 48 or whatever.
const int number_of_channels=512; //512 for 512 channels
const int channel_position=1; // 1 if you want to read from channel 1
// buffers
char packetBuffer[UDP_TX_PACKET_MAX_SIZE]; //buffer to store incoming data
byte buffer_dmx[number_of_channels+channel_position]; //buffer to store filetered DMX data
// art net parameters
unsigned int localPort = 6454;      // artnet UDP port is by default 6454
const int art_net_header_size=17;
const int max_packet_size=576;
char ArtNetHead[8]="Art-Net";
char OpHbyteReceive=0;
char OpLbyteReceive=0;
short is_artnet_version_1=0;
short is_artnet_version_2=0;
short seq_artnet=0;
short artnet_physical=0;
short incoming_universe=0;
boolean is_opcode_is_dmx=0;
boolean is_opcode_is_artpoll=0;
boolean match_artnet=1;
short Opcode=0;
EthernetUDP Udp;
  //déclaration des ports PWM
  //ici une diode pour test
  pinMode(3, OUTPUT);  //check with leds + resistance in pwm, this will not work with pins 10 and 11, used by RJ45 shield
  // démarrage ethernet et serveur UDP
  Ethernet.begin(mac,ip);
  Udp.begin(localPort);
   int packetSize = Udp.parsePacket();
  if( packetSize>art_net_header_size && packetSize<=max_packet_size)//check size to avoid unneeded checks
    Udp.read(packetBuffer,UDP_TX_PACKET_MAX_SIZE);
    //read header
     match_artnet=1;//valeur de stockage
     for (int i=0;i<7;i++)
      if(char(packetBuffer[i])!=ArtNetHead[i])
      {match_artnet=0;break;}//if not corresponding, this is not an artnet packet, so we stop reading
     if (match_artnet==1)//if its an artnet header
          /*artnet protocole revision, not really needed
          is_artnet_version_1=packetBuffer[10];
          is_artnet_version_2=packetBuffer[11];*/
          /*sequence of data, to avoid lost packets on routeurs
          seq_artnet=packetBuffer[12];*/
          /*physical port of  dmx N°
          //artnet_physical=packetBuffer[13];*/
     //operator code enables to know wich type of message Art-Net it is
     Opcode=bytes_to_short(packetBuffer[9],packetBuffer[8]);
     if(Opcode==0x5000)//if opcode is DMX type
       is_opcode_is_dmx=1;is_opcode_is_artpoll=0;
     else if(Opcode==0x2000)//if opcode is artpoll
     is_opcode_is_artpoll=1;is_opcode_is_dmx=0;
     //( we should normally reply to it, giving ip adress of the device)
     if(  is_opcode_is_dmx=1)//if its DMX data we will read it now
     //if you need to filter DMX universes, uncomment next line to have the universe rceived
     //incoming_universe= bytes_to_short(packetBuffer[15],packetBuffer[14])
     //getting data from a channel position, on a precise amount of channels, this to avoid to much operation if you need only 4 channels for example
     for(int i=channel_position-1;i< number_of_channels;i++)//channel position
     buffer_dmx[i]= byte(packetBuffer[i+17]);
     DmxSimple.write(i,buffer_dmx[i]);
     }//end of sniffing
PaulS
Code: [Select]
There's a 1/4 of your memory, if you have other than a Mega.
Quote
Doesn't really look like that...
gaggenau
Quote
Quote
To change the amount of channels, i have used this part of the code:
Code: [Select]
and i dont think it is the part you suggest, that i have problems in beacuse that is from the original artnet reciving code and that one works.
mrboni
I get this problem too and it seems like maybe the w5100 buffer is getting too full and not clearing properly (uneducated guess)
I get the same problem when using the UDPsendReceiveString sketch that comes with the ethernet library.  If I send udp packets one at a time the arduino reports back correctly but if I send a constant stream of artnet data (I think 538 bytes per packet and usually at a rate of 40-60 pps) the arduino freezes (or probably just the w5100 freezes)
As artnet is a realtime communication all I need is to read one packet from the buffer every time the arduino's loop passes round, therefore I have no use for buffered packets apart from the one I want to read that cycle.
I tried flushing with Udp.flush but that didn't seem to work.
It's spinning out with even smaller packets too.
I've tried 2 units.  And I don't know if it's just me but it seems to get worse over time.
rafaelmizrahi
I had the same problem, reported here
http://arduino.cc/forum/index.php/topic,85824.msg836739.html
what is the size of your UDP_TX_PACKET_MAX_SIZE
Its defined in the Udp.h or EthernetUdp.h , depending on which arduino version you are using.
I am asking, because sometime people tinker with this value.
Try to change your code from
into
char packetBuffer[512];
// packetBuffer[512] is working for me on Uno, but you should aim using the value originally which was 2048
ENDE
I guys, I did not understand if you resolved the problems, did you ??
And where I can find assembly instructions  ??
Thank You !!
mrboni
The fix for me was to use an arduino mega
rafaelmizrahi
#7
Sep 04, 2012, 11:38 am Last Edit: Sep 04, 2012, 11:40 am by rafaelmizrahi Reason: 1
indeed mrboni. I also previously switched to Mega+Ethernet shield and my program started to work properly.
but, than, I changed the UDP_PACKET_MAX_SIZE from 2048 to 576, which is artnet max packet size , and the program is now running properly using Uno+Ethernet
(sorry for not posting the code. the development is still in progress.)
ENDE
Hi mrboni, i'm sorry but I'm not so expert about ARDUINO, can you explain me more what you've done... I'm trying to build something like this:
proximity sensor-->-->control lighting software-->-->lighting fixtures
I have a software, I have a dmx OUT hardware, but I need to understand how to make comunicate the sensor with a software.
I know that I have to convert the sensor signal into dmx; I think that the right way is to use an artnet to dmx device, is that you use right for this ?
if yes, can you tell me exactly what kind of hardware I need and how to assemble it ... than I will think about the ARDUINO code...
THANK YOU VERY MUCH !!!!!
theantnest
I know this is a very old topic. Did this project ever get finished? I am new to Arduino, and am interested to learn about Artnet and DMX implementations before I move into something more complex.
Cricky
Apologies for trying to drag up such an old topic but I'm hoping to get a bit of help with a project i'm attempting.
I want to make an ArtNet node based on an Arduino Nano and an ENC28J60 Ethernet module (both of these chosen for a nice compact unit) and this seems to be the most promising code example i've came across online.
Would it be possible to modify this project to work with my hardware? ...and would i also need to use an older version of the Arduino IDE?
I'm guessing i'd need to use different a different library for the ENC28J60 (such as the Ethercard library?).
Could anybody direct me in the steps i'd need to take to do this? I'm not asking for someone completely to do it for me, i would like to pick up a bit of knowledge on the subject while i'm at it.
Thanks!
mcnobby
My words exactly Cricky....
http://www.youtube.com/user/Recovered
http://www.smartshow.lighting
Cricky
#12
Mar 24, 2016, 10:56 am Last Edit: Mar 24, 2016, 02:42 pm by Cricky
Have you got anywhere with this yet mcnobby?
I think i might have found some things that might come in handy for porting this over to the ethercard library...
Migrating from EtherShield to EtherCard library:
http://blog.thiseldo.co.uk/?p=623
Art-Net user guide:
http://www.artisticlicence.com/WebSiteMaster/User%20Guides/art-net.pdf
Here is a project using OSC to control DMX via Art-Net that could be handy:
http://oschub.asia/weblog/?p=165
I'm a complete n00b with this stuff so i'm learning as i go (i hope). This started off as a simple DMX over USB project but has now grown into an attempt at an Art-Net node which is more than i bargained for!
mcnobby
Hi Cricky, yes I have moved along quite nicely
I am currently using a UNO and Ethernet Shield using some standard libs
But I have written an HTML interface to configure your ArtNet in a browser (see pic)
I have also written some assembler to take the ArtNet (DMX) data direct to WS2812 LEDs (not using Neopixel or FastLed Libraries)
There are some severe memory limitations, but I think I can get 2 universes decoded and output without any trouble
Migrating to the ENC29J60 may cause some more problems too, but we shall see when I get there
I am hoping to make some very small ArtNet/sACN to WS2812 adaptors using a NANO and the Tiny ENC28J60 Nano Ethernet shield
Cricky
#14
Apr 03, 2016, 12:49 am Last Edit: Apr 03, 2016, 01:32 am by Cricky
That's cool! Liking the web interface.
I had another go at this one last night. I took the project from the original post and tried replacing the ethernet.h library with the UIPEthernet library since you don't need to change anything in the code to use it. I had a few compile errors then fixed them but not its not compiling due to lack of memory. I'm getting this:
Sketch uses 17,014 bytes (55%) of program storage space. Maximum is 30,720 bytes.
Global variables use 2,712 bytes (132%) of dynamic memory, leaving -664 bytes for local variables. Maximum is 2,048 bytes.
I've changed the line
Code: [Select]
 to
Code: [Select]
char packetBuffer[576];
I've also went into the UIPUdp.h library file and changed it in there too. It's named differently though...See below:
Code: [Select]
#define UIP_UDP_MAXDATALEN 1500
#define UIP_UDP_PHYH_LEN UIP_LLH_LEN+UIP_IPUDPH_LEN
#define UIP_UDP_MAXPACKETSIZE 576 //edited for ARTNET program
//#define UIP_UDP_MAXPACKETSIZE UIP_UDP_MAXDATALEN+UIP_UDP_PHYH_LEN
And when i checked the normal, unedited stock ethernet.h file, UDP_TX_PACKET_MAX_SIZE was 24. Something seems weird....
Any ideas what might be going on here?
I'll post my code below. Its near enough the same as above but i'll post it either way:
Code: [Select]
ARTNET RECEIVER V2
karistouf@yahoo.fr
#include <UIPEthernet.h>
#include <UIPUdp.h>
//HARDWARE
IPAddress  ip(192,168,0,20 );// the IP adress of your device, that should be in same universe of the network you are using, here: 192.168.1.x
// buffers
char packetBuffer[UIP_UDP_MAXPACKETSIZE]; //buffer to store incoming data
short seq_artnet=0;
short Opcode=0;
EthernetUDP Udp;
  // pin 3 commonly used for DMX
  DmxSimple.usePin(3);
  // start ethernet and udp server
    Udp.read(packetBuffer,UIP_UDP_MAXPACKETSIZE);
    //read header
     }//end of sniffing
*Edit - I've changed the number of channels from 512 to 48 (just a random low value) and it compiles now! Obviously i'd like a full universe though but this seems like progress!
Ignore the above, i realised i'd also changed the udp max tx buffer size to 24 too when it compiled....
