Topic: Temperature Fan Control PWM Arduino Help! (Read 9482 times) previous topic - next topic
Uni_man
hi guys
i`m trying to control the fan speed with a temperature sensor, display the temperature and fan speed on dedicated LCD.
i have wired up every thing correctly.
managed to display temp on LCD as well as serial monitor.
managed to switch the fan on and off.
but when it comes to control speed bit in programming i get stuck and the fan doesnt move....
here is my code.
#include <LiquidCrystal.h>
int pin = 0;                // analog pin
int tempc = 0,tempf=0;      // temperature variables
int samples[8];             // variables to make a better precision
int maxi = -100,mini = 100; // to start max/min temperature
int i;
int TIP122pin = 3;
int fanspeed = 0;
LiquidCrystal lcd(7, 8, 9, 10, 11, 12); // Customize for your connections.
  Serial.begin(9600);       // start serial communication
  lcd.begin(16,2);          // set up the LCD's number of columns and rows
  pinMode(TIP122pin, OUTPUT); // Set pin for output to control TIP122 Base pin
  analogWrite(TIP122pin, 255); // control the fan speed by changing values from 0 to 255
tempc = 0;
for(i = 0;i<=7;i++){         // gets 8 samples of temperature
  samples[i] = ( 5.0 * analogRead(pin) * 100.0 ) / 1024.0;
  tempc = tempc + samples[i];
tempc = tempc/8.0;               // better precision
tempf = (tempc * 9)/ 5 + 32;     // converts to fahrenheit
if(tempc > maxi) {maxi = tempc;} // set max temperature
if(tempc < mini) {mini = tempc;} // set min temperature
if ( tempc < 40 && tempc > 10 ) {
    fanspeed = tempc + 50;
    analogWrite(3,fanspeed);
    else if ( tempc < 10 ) {
    fanspeed = 0;
   else{
     analogWrite(3,255);
Serial.print(tempc,DEC); // serial print for debugging all serial.print commands
Serial.print(" Celsius, ");
Serial.print(tempf,DEC);
Serial.print(" fahrenheit -> ");
Serial.print(maxi,DEC);
Serial.print(" Max, ");
Serial.print(mini,DEC);
Serial.println(" Min");
lcd.setCursor(0, 0);  // set the cursor to (0,0)
lcd.print(tempc,DEC);  // print temp in C and F on the first row of the lcd
lcd.print(" C, ");
lcd.print(tempf,DEC);
lcd.print(" F");
lcd.setCursor(0, 1);  // set the cursor to (16,1)
lcd.print(maxi,DEC);   // Print max temp and min temp on the second row of lcd
lcd.print("  Max, ");
lcd.print(mini,DEC);
lcd.println(" Min.");
delay(1000);                   // delay before loop
please help this is really wasting my time......... :0 :0 :0 :0 :0 :0 :0
dxw00d
You are Serial.printing the value of tempc. Do the results look right?
Add some debugging prints to the fan speed if statements to see which parts are being executed.
PaulS
Why are you storing the temperatures in an array, during the averaging process? The array is completely unnecessary.
This is hard to read.
if(tempc > 10 && tempc < 40)
is much closer to how people decide to do things. The compiler doesn't care, but it's easier to maintain understandable code.
What, exactly, is connected to pin 3? What kind of fan are you using?
Dr_Ugi
#3
Mar 12, 2012, 12:50 pm Last Edit: Mar 12, 2012, 12:52 pm by Dr_Ugi Reason: 1
You are doing floating point maths (using 8.0) on an integer variable.  I haven't checked but I reckon this may be your issue.
Try defining tempc as a float & see if it works any better.
Better might be:
tempc=tempc>>3;
or for closer rounding:
tempc=((tempc+4)>>3)
Also, why not put a delay at then end of the setup function just to check that the fan runs OK at full speed before moving into the loop.  If it doesn't then it sounds like a hardware issue.
Uni_man
yes temperature measurements are right, thanks you
Uni_man
thank you
the base of the TIP-122 darlington transistor with 1k resistor driving 12v fan.
dxw00d
What about debugging prints to trace the path through the code?
Uni_man
Better might be:
tempc=tempc>>3;
thanks for the hint but temperature statements works fine and i have changed the value 8.0 to 8 this is just dividing the 8 samples by 8 its just to get better measurements.
Uni_man
im about to do it now and see where the problem is because the fan is not moving at all but when i set it high it switch on so its just fan statements and the serial.print is the best hint i didnt even think of it.
Uni_man
i still can not get it  here is the updated code;
int i;
int TIP122pin = 3;
int fanspeed = 0;
int fanStemp = 0;
  delay(200);
tempc = 0;
tempc = tempc/8;               // better precision
if ( tempc > 10 && tempc < 40 ) {
    fanStemp = tempc + 50;
    fanspeed = fanStemp + 100;
    Serial.print("Fan started at temp+50+100 speed\n");
    Serial.print(fanspeed,DEC);
    Serial.print("\n");
    delay(100);
    fanspeed = 0;
    Serial.print("Fan off\n");
    delay(100);
   else{
     analogWrite(3,255);
     Serial.print("Fan started at full speed\n");
     delay(100);
lcd.print(" C, ");
lcd.print(" F");
i got the fan working and running but on 5v but i can not see the speed change am i using the right function [ analogWrite(3, fanspeed) ] why not [ digitalWrite(3,fanspeed) ] what is the difference i know the voltage may be one of the problems but still at least i should see a change when i change the added value of 100 in the fanspeed to 0 !!!  probable the connection ?? iam connecting Arduino Pin 3 (PWM) with TIP-122 Base (B) pin through 1k resistor.5V fan connect to the TIP-122 Collector (C). And the Emitter (E) pin connect to the Ground. i dont understand the statements are executed the way i want it on the serial print but ????
PaulS
digitalWrite() turns the pin HIGH or LOW, one time. analogWrite() starts the pin toggling on and off, so that it's on amount is the ratio specified.
Ditch the complicated code. Write a sketch that calls analogWrite() with various values, from 0 to 200, with a 2 second delay between changes. If the fan speed does not change, the fan is not meant to be variable speed.
Uni_man
int fanstart = 0;    // start fan speed at 0
int fadeAmount = 20;    // how many points to fade the LED by
void setup()  {
  // declare pin 3 to be an output:
  pinMode(3, OUTPUT);
void loop()  {
  // set the speed of pin 3:
  analogWrite(3, fanstart);
  // change the speed for next time through the loop:
  fanstart = fanstart + fadeAmount;
  // reverse the direction of the fading at the ends of the fade:
  if (fanstart == 0 || fanstart == 255) {
    fadeAmount = -fadeAmount ;
  // wait for 30 milliseconds to see the dimming effect
  delay(30);
nothing happens the fan runs on one speed !
Connections are the same
wildbill
This will never be true:
fanstart == 255
You're incrementing in steps of 20. Write something much simpler - just hard code a few values and put a decent delay between them.
Uni_man
damn XD XD it wasn't working properly because of the connections the problem solved thanks all for suggestions.
