Topic: What parts/mapping for pressurized power? (Read 906 times) previous topic - next topic
JungleMist
Mar 12, 2012, 05:20 am Last Edit: Mar 12, 2012, 06:09 am by JungleMist Reason: 1
I'm going to build a manual water pump, equipped with color changing LEDs, and a matching harmonic output (speakers playing sounds) to the pressure. I want the LEDs to change color & the pre-recorded sounds vary, as the pressure changes in the pump.
What parts would I need? And what mapping would be necessary to read the pressure?
Also important, it has to be hand powered = no external power sources...
Any help is good help...
TNX!  :smiley-eek:
winner10920
That sounds pretty interesting, I've never seen such a device before tho so it'll be a little hard tonfigure out
Most devices like the ones on sink have a battery, although you could get a little generator that could power the device when water is flowing
However leds and mostly speaker draw a decent amount and I think that will be hard to achieve without a battery somewhere
Idk if there a way to generate power from just pressure, but probably the generating device will also be your sensor on pressure
Grumpy_Mike
You need a wave shield for the sound generation bit.
How will that work? I can't see a way other than solar power charging a battery.
winner10920
Especially because everything I know about power generation requires a change in something,  a constant pressure can't create power but a release of pressure can but I doubt you'd want to release the pressure from the pump for it to tell you that your pressure is going down
JungleMist
Good point, I think solar might be the way to go [for constant power]. thnx
