Topic: Ethernet + Virtual Wire Issues (Read 2999 times) previous topic - next topic
gnusso
Hi all,
I'm try to use a virtual wire with arduino shield:
virtual wire :
- tx pin: 12
- rx pin: 11
When I compile the sketches I received this issues:
Servo/Servo.cpp.o: In function `__vector_11':
/Applications/Arduino.app/Contents/Resources/Java/libraries/Servo/Servo.cpp:103: multiple definition of `__vector_11'
VirtualWire/VirtualWire.cpp.o:/Applications/Arduino.app/Contents/Resources/Java/libraries/VirtualWire/VirtualWire.cpp:416: first defined here
My understanding is that there is a issues with the pin 11 I've tried to check "servo.cpp" and "VirtualWire.cpp" but I didn't found nothing,
is there someone  that know how to fix that ?
thanks in advance ,
Gnusso
PaulS
The Ethernet shield is an SPI device. It uses pins 11, 12, and 13 for SPI purposes. It uses pins 4 and 10 as slave select pins. None of those pins is available for your application to use.
gnusso
thanks very much for your reply,
from your stand point is there the possibility to modify the tx and rx of Virtualwire library ?
-regards-
Andrea
PaulS
The VirtualWire library has two methods, vw_set_tx_pin and vw_set_rx_pin, that allow you to use any pins you want. The defaults are 12 and 11, but you can change them by calling these functions. You also need to call vw_set_ptt_pin to get off pin 10.
gnusso
Great, I've tried to call the setup but I didn't call the last one that you have said ... now I try and I'll let you know ;-)
Andrea
gnusso
Hi again,
I've tried to modify the code followint your suggestion maybe im wrong something ? following the code ... I've called the function after vw_setup ...
#include <VirtualWire.h>
#include <SPI.h>
#include <Ethernet.h>
#include <Servo.h>
Servo myservo;  // create servo object to control a servo
byte mac[] = { 0x90, 0xA2, 0xDA, 0x00, 0x8D, 0x64 }; //physical mac address
byte ip[] = { 192, 168, 1, 102 }; // ip in lan
byte gateway[] = { 192, 168, 1, 1 }; // internet access via router
byte subnet[] = { 255, 255, 255, 0 }; //subnet mask
EthernetServer server(84); //server port
String readString;
void setup(){
 vw_setup(1200);
 vw_set_tx_pin(2);
 vw_set_rx_pin(3);
 vw_set_ptt_pin(5);
 pinMode(8, OUTPUT); //pin selected to control
 //start Ethernet
 server.begin();
 myservo.write(90); //set initial servo position if desired
 myservo.attach(7);  //the pin for the servo co
 //enable serial data print
 Serial.println("server LED test 1.0"); // so I can keep track of what is loaded
void loop(){
 // Create a client connection
 if (client) {
   while (client.connected()) {
     if (client.available()) {
       char c = client.read();
       //read char by char HTTP request
       if (readString.length() < 100) {
         //store characters to string
         readString += c;
         //Serial.print(c);
       //if HTTP request has ended
       if (c == '\n') {
         Serial.println(readString); //print to serial monitor for debuging
         client.println("HTTP/1.1 200 OK"); //send new page
         client.println();
         client.println("<HTML>");
         client.println("<HEAD>");
         client.println("<TITLE>Arduino GET test page</TITLE>");
         client.println("</HEAD>");
         client.println("<BODY>");
         client.println("<H1>Test Button</H1>");
         client.println("<a href=\"/?on\"\">ON</a>");
         client.println("<a href=\"/?off\"\">OFF</a>");
         client.println("</BODY>");
         client.println("</HTML>");
         delay(1);
         //stopping client
         client.stop();
         ///////////////////// control arduino pin
         if(readString.indexOf("on") >0)//checks for on
           myservo.write(40);
           char msg[1];
           msg[0] = '1';
           vw_send((uint8_t *)msg, strlen(msg));  // invia la lettera a
           Serial.println("Led On");
         if(readString.indexOf("off") >0)//checks for off
           myservo.write(140);
           digitalWrite(8, LOW);    // set pin 8 low
           Serial.println("Led Off");
         //clearing string for next read
         readString="";
The exact error is this:
warm regards
Andrea
gnusso
Hi All,
the problem is that ... looking Servo.cpp: (line 103) and VirtualWire.cpp (line 416) that function SIGNAL (TIMER1_COMPA_vect) is present in both ...
Then I've change the function in VirtualWire.cpp putting SIGNAL (TIMER6_COMPA_vect) because the other one arrive until 5 ... in compile mode there is no problem ... but I've note that the serial monitor is not working anymore ...due the fact putting back like initial the serial monitor can works ...
How I can do to remove the issues and continue to work ?? SIGNAL (TIMER1_COMPA_vect)  maybe is call in other parte that I didn't know ... I can try to modify to the servo.cpp part ?
Thanks for the support,
Andrea
jdkrafft
#7
Jan 12, 2017, 09:02 am Last Edit: Jan 12, 2017, 10:05 am by jdkrafft
I noticed that i had to start the Ethernet AFTER the Virtual Wire to make it work.  Otherwise the ethernet gets an IP but can't connect...
  // Setup 433 radio
  // vw_set_ptt_inverted(true);
  //pinMode(13, OUTPUT);
  //digitalWrite(13, LOW);
  vw_setup(2000);
  vw_set_rx_pin(6); // Ehternet uses 4,10,11,12,13 because it's an SPI-device.
  vw_set_tx_pin(7);
  vw_set_ptt_pin(8);
  vw_rx_start();
  Serial.println("Receiver(433) started!");
 // ---- Setup ethernet
  Ethernet.begin(mac);
  Serial.print("Current IP: ");
  Serial.println(Ethernet.localIP());
After i made that change it was able to use both devices at the same time!
