Author Topic: RGB LED color change using serial communication  (Read 551 times)
Aalborg, Denmark
Hi
I wanna make a sketch that when I write certain frases to it via the serial monitor will make an RGB LED light up in certain ways.
I would like to be able to write the RGB code and get the according color (ex: 255 0 0 for red).
Besides that I would like to be able to write "pulse" or something like that and the colors just morphes/changes through the spectrum.
I've found several different tutorial/guides etc. but I can't seem to find one that I can get to work.
So what I'm looking for is:
1) Either the code that would make this work
2) A guide that works
3) A tutorial/guide to writing sketches that use serial communication
UK
Perhaps if you could post one of them, we could help you make it work.
Or, break the problem down into "how do I reliably transfer triplets of numbers across a serial link?" and the other simpler bit, then do a search for "PaulS SOP EOP" and see where that leads.
Aalborg, Denmark
I tried this one:
http://www.homebuiltrovs.com/rovforum/viewtopic.php?f=15&t=97
But only with only code for one of the RGB LED legs. I think the problem there was something with this line:
default:
      // any other key pressed will turn the lights off..
      for (int thisPin = 2; thisPin < 6; thisPin++) {
        digitalWrite(thisPin, LOW);
In that code, I don't really get how to change the:
// initialize the LED pins:
        pinMode(thisPin, OUTPUT);
To only the RGB LED pins (which are on three non-continous pins for PWM purpose (3,5,6 on an UNO))
I've got this one working now for the pulsating color:
http://www.mbeckler.org/microcontrollers/rgb_led/
The "problem" here is I don't quite understand the update section and the color_morph.
Edit: I figured out the update section and color_morph. So the question now is primarily about the serial communication.
« Last Edit: March 12, 2012, 11:36:10 am by lokefar » Logged
Manchester (England England)
Online Online
Solder is electric glue
The problem here is that you don't understand even the most basic fundamentals of how code works. Like trying to teach a man with no legs to run.
The solution if for you to do some of the tutorials in the learning section, learning how to turn a digital pin on and off and driving a PWM pin.
http://arduino.cc/hu/Tutorial/HomePage
Aalborg, Denmark
Ignore the question. Figured it all out a different way around.
