Topic: What is the Arduino Uno Serial buffer size? (Read 75289 times) previous topic - next topic
Blaylock1988
I am reading information from my motorcycle's ECM via serial connection on the Arduino Uno R3. I am supposed to read a 107 byte series, but I am only getting the first 62 bytes. The header in the series says there are supposed to be 100 bytes of info (plus 7 for the header) so I know the ECM is trying to send all of it.
Is the buffer size only 62 bytes? How can I get around this so I can read all 107 bytes and save them into an array?
PaulS
Quote
The buffer size is 64 bytes.
Quote
Generally, the thing to do is read as fast as it arrives. Without seeing your code, we have no idea why you aren't doing this. There is nothing to get around, except to reading before the data is lost.
retrolefty
What is the baud-rate of the serial data you are receiving? That will have a bearing of how fast you must read the data from the serial buffer into your own user defined buffer of the size required to hold the message. But bottom line you should not be reliant on the size of the serial buffer, but rather set a baud-rate such that you can transfer characters fast enough into your own buffer such that no serial buffer over-runs occurs.
Lefty
Blaylock1988
#3
Mar 12, 2012, 06:38 pm Last Edit: Mar 12, 2012, 08:13 pm by Blaylock1988 Reason: 1
The baud rate that the ECM is 9600 sending and receiving, so I am using 9600 for the Arduino as well. Hmmm, maybe the delay I am using is causing part of the problem, but that doesn't help if the buffer is only 64 bytes. I wonder why I am receiving 62 bytes instead...
Here is my code I am using:
Code: [Select]
This program is used for an Arduino to request and retrieve
data from an 07 Buell XB9SX Lightning ECM DDFI-2,
EEPROM Version: BUEIB
Currently the Arduino successfully sends a request code and
receives only 62 bytes of the run-time response, and displays
on the LCD screen and via serial monitor.
Created by Michael Blaylock
// include the library code:
#include <LiquidCrystal.h>
#include <SoftwareSerial.h>
//new serial pins for ECM, 0 and 1 caused interferance from PC
#define rxPin 2
#define txPin 3
// set up a new serial port
SoftwareSerial mySerial =  SoftwareSerial(rxPin, txPin);
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(7, 8, 9, 10, 11, 12);
byte inArray[9]; //request code for real-time data
byte outArray[107]; //real-time data series from ECM
byte long Value;
int First = 0;
void setup(){
  // set up the LCD's number of columns and rows:
  lcd.begin(16, 2);
  // initialize the serial communications:
  // define pin modes for tx, rx:
  pinMode(rxPin, INPUT);
  pinMode(txPin, OUTPUT);
  // baud rate for the ECM is 9600
  mySerial.begin(9600);
  inArray[0]=0x01; //SOH
  inArray[1]=0x00; //Emittend
  inArray[2]=0x42; //Recipient
  inArray[3]=0x02; //Data Size
  inArray[4]=0xFF; //EOH
  inArray[5]=0x02; //SOT
  inArray[6]=0x43; //Data 1 //0x56 = Get version, 0x43 = Get runttime data
  inArray[7]=0x03; //EOT
  inArray[8]=0xFD; //Checksum
  //Stream request data series to ECM as HEX
//print only 1 response to serial monitor to avoid flooding
void display() {
  if(First == 0) {
    for (int i=0; i<107; i++){
      Serial.println(outArray[i],HEX);
    First = 1;
  lcd.setCursor(0,0);
  for (int i = 0; i<9; i+=1){
    mySerial.write(inArray[i]);
    lcd.print(inArray[i],HEX); //print sent HEX code
  // when characters arrive over the serial port...
  if (mySerial.available()) {
    // wait a bit for the entire message to arrive
    delay(100);
    lcd.setCursor(0, 1);
    // read all the available characters
    while (mySerial.available() > 0) {
      // listen for new serial coming in:
        outArray[i] = mySerial.read();
      //save specific bytes as useful variables
      //concatenate 2 byte RPM data
      unsigned Value = outArray[31] << 8 | outArray[30];
      //byte Value = outArray[90];
      lcd.setCursor(0,1);
      lcd.print("temp: ");
      lcd.print((Value*0.18-40)/2);
      //lcd.print(" ");
      //lcd.print(outArray[28],HEX);
      //lcd.print(outArray[29],HEX);
      display();
dxw00d
Code: [Select]
        outArray = mySerial.read();
outArray is not an element of an array.
Blaylock1988
Should I have:
Code: [Select]
outArray[i] = mySerial.read();?
I found the formatting I have been using from another thread on the forums.
dxw00d
Code: [Select]
Given the location of that line, it would make sense.
PaulS
Quote
It doesn't help. But look at this:
Code: [Select]
Suppose 8 bytes have arrived. The while condition will be true, so you read all 107 of the 8 bytes. Does that really seem like a good idea?
Code: [Select]
#define rxPin 2
#define txPin 3
Good.
Code: [Select]
Give complete control of the pins to SoftwareSerial.
Code: [Select]
Then, muck with them, anyway. Not a good idea.
AWOL
It's a side effect of not using CODE TAGS when posting code.
Note the italics that appeared.
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
I speak for myself, not Arduino.
dxw00d
I missed that. The whole thing is a quote, so it's all in italics.
Blaylock1988
#10
Mar 12, 2012, 08:08 pm Last Edit: Mar 12, 2012, 08:14 pm by Blaylock1988 Reason: 1
Code: [Select]
I fixed it as code in my post.
I was using the same code and was sending the wrong checksum so the ECM was sending me a 10 byte error. It was reading that fine but the rest of the outArray was empty with 0xFF.
So I guess what is happening is it is writing mySerial.read() to outArray 107 times? If I tell it to write mySerial.read() to outArray i location, wouldn't it be trying to write the entire buffer to that one location, or will it write the very first byte in the buffer to the i location in the outArray?
PaulS
Quote
Time to go read the documentation on the Serial.read() function. It does not read "the entire buffer" at once. It reads one byte at a time. So, it would only write one byte to outArra[ i ].
Of course, that isn't you real problem.
Blaylock1988
ok so doing outArray[ i ] = mySerial.read() should fix my problem?
It sounds like I was unintentionally writing the entire buffer at once, when I should be writing the first incoming byte of the buffer to outArray[ i ].
The ECM is supposed to send out 107 bytes every time unless it is sending out an error message.
Blaylock1988
#13
Mar 16, 2012, 03:33 am Last Edit: Mar 16, 2012, 04:11 am by Blaylock1988 Reason: 1
I changed it to outArray[ i ] = mySerial.read() and the problem still persists.
I tested it and it says that the buffer is overflowing.
It looks like when you use the mySerial.read() function, it doesn't clear out the previous values that were read, so the buffer fills up to 64 and no more values come in.
How can I clear each byte that has already been read from the buffer so that It does not overflow?
EDIT: So I rearragned the location of the mySerial.read() and some other things and I was able to read 67 of the 107 bytes. Am I just not reading fast enough? I am using the correct baud for my ECM. I'll post the revised code, I just need to clean it up so you guys can make sense of it.
nickgammon
A suitable method is described here:
http://www.gammon.com.au/serial
Code: [Select]
    delay(100);
You don't need any delays if you follow my method.
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
