Topic: split a long in bytes (Read 7486 times) previous topic - next topic
lloyddean
"mikroC PRO for PIC is a full-featured ANSI C compiler for PIC devices from Microchip®."
Should
nickgammon
Well bit of a nerve asking about a PIC on an arduino forum, but never mind.  :)
Yes but Mike, maybe the people on the PIC forum are all young. :)
Grumpy_Mike
yes probbly just like you know who!
takao21106
Your advice is rather bazaar, I have noted in other threads you hand out bad or irrelevant advice.
I also sometimes contributed to a solution, here, and on other forums.
I agree my original reply was a quick judgement and I removed sentences/replies
that are not contributing to a solution and/or irrelevant to the thread topic.
Unions and typecasts (see my reply) are archieving a similar thing, in the end.
I used assembler for some years not only for MCUs, and currently I move away from it,
because the poor maintainability. I am here on the forum basically also to learn from others.
There is one assembler source about 1 megabyte which I browsed some months ago the largest I wrote is only 300k unfortunately it is lost. Isn't one great feature of C the portability, you can understand Atmel sources, or PIC sources, even if you don't use it currently?
Remember these are mainly beginners and are easly confused.
I'd second that, people out there are surprisingly intelligent at times, while over time, not all of them will become programmers or even professional users.
They'd use the advice that is most appreciate to them, and more or less ignore the others.
lefstin
#34
Mar 13, 2012, 03:27 am Last Edit: Mar 13, 2012, 03:33 am by Professor Chaos Reason: 1
piece =( eeprom_byte4 << 24) | (eeprom_byte3 << 16) | (eeprom_byte2 << 8) | eeprom_byte1;
Mike, isn't there an issue with that code?  Namely, that the two highest bytes will be lost because the compiler will treat eeprom_byte4 << 24 and eeprom_byte3 << 16 as int expressions without an explicit cast?
E.g., the following code:
  unsigned long foo;
 byte bar = 255;
 foo = ( bar << 24) | (bar << 16);
 Serial.println(foo,DEC);
 foo = ((unsigned long)bar << 24) | ((unsigned long)bar << 16);
Produces output of:
4294901760
.... showing that the bits are lost without the cast.
Groove
Can anyone explain the code in reply #8, please?
Per Arduino ad Astra
nickgammon
No, because it is Complete Nonsense.
nickgammon
if((phase>>1)==0)led_data=led_numbers&0x000f;
What is phase? Why is it shifted right 1 bit? I guess we will never know.
dxw00d
It's not just me then. Good.
Grumpy_Mike
It depends on how these variables were defined. If they were defined as longs then there will be no problem.
If they were defined as bytes or ints I would expect the compiler to automatically promote them to longs because the left hand side is a long. However I know that some compilers do this while others do not. Good point have you tried it?
nickgammon
   if((phase>>1)==1)led_data=((led_numbers&0x00f0) > > 4);
   if((phase>>1)==2)led_data=((led_numbers&0x0f00) > > 8);
   if((phase>>1)==3)led_data=((led_numbers&0xf000) > > 12);
Well it leads to this:
sketch_mar13a:8: error: expected primary-expression before '>' token
sketch_mar13a:9: error: expected primary-expression before '>' token
sketch_mar13a:10: error: expected primary-expression before '>' token
Now do you understand?
hugo007
unsigned long foo;
  byte bar = 255;
I confirm it realy need the cast
Thanks Professor Chaos for the tip
Debian,Mint,Ubuntu
Arduino Mega 2560
Arduino Nano
Arduino Duemilanove
MAC OS Montain Lion
Raspberry PI Model B
Groove
Well, yes, obviously, but even if it had been ">>" and not "> >", what is it supposed to do?
Grumpy_Mike
Well it was in response to the question of splitting a long into bytes,
What it is supposed to do and what it actually does are two different matters
correcting the shift what it does do is:-
   // the variable phase will decide which nibble (not byte) is extracted from the long variable led_numbers
  // so if phase is equal to 0 or 1 it will do this first line
   if((phase>>1)==0)led_data=led_numbers&0x000f; // put the least significant nibble into led_data
  // if phase is equal to 2 or 3 it will do this next line
   if((phase>>1)==1)led_data=((led_numbers&0x00f0) >> 4); // put the next most significant nibble into led_data
   // if phase is equal to 4 or 5 it will do this next line
   if((phase>>1)==2)led_data=((led_numbers&0x0f00) >> 8); // put the next most significant nibble into led_data
  // if phase is equal to 6 or 7 it will do this next line
   if((phase>>1)==3)led_data=((led_numbers&0xf000) >> 12); // put the next most significant nibble into led_data
So depending on the value of phase it will extract a nibble from variable. Not quite what was asked for.
