Topic: Processing + Suse11.4 (Read 849 times) previous topic - next topic
Snoops
Hallo,
irgendwie bekomme ich Processing um die Arduino Werte zu visualisieren unter Suse11.4 nicht zum laufen. Ich habe die Datei processing-1.5.1.tgz in /usr/processing-1.5.1/ entpackt aber wenn ich die shell per doppelklickstarten will bekomme ich folgende Fehlermeldung "Für den Dateityp Shell-Skript (application/x-shellscript) ist keine spezielle Anwendung festgelegt."
Was mache ich da jetzt falsch?
Gruß
Snoops
madworm
Warum so kompliziert?
http://software.opensuse.org/search?q=processing&baseproject=openSUSE%3A11.4&lang=de
Snoops
Danke für den Tipp, aber schon tritt das nächste Problem beim installieren auf...  :(
Was ist hier das Problem?
linux-m7jo:/tmp # rpm -i processing-1.5.1-1.1.x86_64.rpm
warning: processing-1.5.1-1.1.x86_64.rpm: Header V3 DSA/SHA1 Signature, key ID c0951497: NOKEY
error: Failed dependencies:
        libCg.so is needed by processing-1.5.1-1.1.x86_64
        libCg.so()(64bit) is needed by processing-1.5.1-1.1.x86_64
        libCg.so(VERSION) is needed by processing-1.5.1-1.1.x86_64
        libCg.so(VERSION)(64bit) is needed by processing-1.5.1-1.1.x86_64
        libCgGL.so is needed by processing-1.5.1-1.1.x86_64
        libCgGL.so()(64bit) is needed by processing-1.5.1-1.1.x86_64
        libCgGL.so(VERSION) is needed by processing-1.5.1-1.1.x86_64
        libCgGL.so(VERSION)(64bit) is needed by processing-1.5.1-1.1.x86_64
        libawt.so is needed by processing-1.5.1-1.1.x86_64
        libjava.so is needed by processing-1.5.1-1.1.x86_64
        libjava.so(SUNWprivate_1.1) is needed by processing-1.5.1-1.1.x86_64
        libjawt.so is needed by processing-1.5.1-1.1.x86_64
        libjli.so is needed by processing-1.5.1-1.1.x86_64
        libjli.so(SUNWprivate_1.1) is needed by processing-1.5.1-1.1.x86_64
        libjvm.so is needed by processing-1.5.1-1.1.x86_64
        libjvm.so(SUNWprivate_1.1) is needed by processing-1.5.1-1.1.x86_64
        libmawt.so is needed by processing-1.5.1-1.1.x86_64
        libmawt.so(SUNWprivate_1.1) is needed by processing-1.5.1-1.1.x86_64
        libnet.so is needed by processing-1.5.1-1.1.x86_64
        libnet.so(SUNWprivate_1.1) is needed by processing-1.5.1-1.1.x86_64
        libodbc.so is needed by processing-1.5.1-1.1.x86_64
        libodbcinst.so is needed by processing-1.5.1-1.1.x86_64
        libverify.so is needed by processing-1.5.1-1.1.x86_64
        libverify.so(SUNWprivate_1.1) is needed by processing-1.5.1-1.1.x86_64
mkl0815
Dein Problem ist, das das RPM Paket Abhängigkeiten zu anderen Paketen hat. Versuch mal das Paket nicht runterzuladen und per rpm zu installieren, sondern aus einem YaST Repository zu installieren. Dann werden auch die Abhängigkeiten aufgelöst.
madworm
Oder einfach auf "1-Klick-Installation" druecken, und YaST machen lassen.
Snoops
Alles klar, kaum macht man es richtig mit "1-Klick-Installation" gehts auch  :)
Danke für den Support...
