Topic: Arduino output for Processing (Read 1 time) previous topic - next topic
RxxK
Hello guys, I gave a small update to the sketch for Processing arduino_output adding a few details and enhancements possible with all the comments. I wanted to make it public here for the magnitude of all those who wish to use or download from here: http://bit.ly/zGeRfb
Code: [Select]
/* Arduino OUTPUT
* Updated 12 Marzo 2012
* By Rei Kurti
*  Program to check the status of the 13-pin of Arduino UNO by PC
    in this case used to control 13 LEDs. the program
    allows you to press 13 buttons each corresponding to an output
    blinking the corresponding LED. Via the serial
    you can view the status of the LEDs.
// Import the processing.serial.*, cc.arduino.* libraries
import processing.serial.*;
import cc.arduino.*;
Arduino arduino;
color stro = color (0, 0, 0);         // color of the contours of the buttons (stroke).
color back = color(222, 222, 222);    // Background color.
color off = color(131, 17, 17);       // Color of the button when you don't press it(fill on).
color on = color(255, 36, 36);        // Color of the button when you press it (fill off).
int[] values = { Arduino.LOW, Arduino.LOW, Arduino.LOW, Arduino.LOW,
Arduino.LOW, Arduino.LOW, Arduino.LOW, Arduino.LOW, Arduino.LOW,
Arduino.LOW, Arduino.LOW, Arduino.LOW, Arduino.LOW, Arduino.LOW };
  size(470, 200);  // Dimensions of the box
  println(Arduino.list());                                    // VIEW ON THE SERIAL THE COM PORT CONNECTED ON PC
  arduino = new Arduino(this, Arduino.list()[1], 57600);      // Setting the COM port you are connected tO
  for (int i = 0; i <= 13; i++)
    arduino.pinMode(i, Arduino.OUTPUT);
  println(" ");                    // VIEW EMPTY SPACE ON THE SERIAL
  println(" START PROGRAM: ");     // VIEW THE WORDS "START PROGRAM" ON THE SERIAL
  println(" -------------- ");     // VIEW DASHES ON THE SERIAL
void draw() {
  background(back);    // Setting the background colour as back --> color(222, 222, 222).
  stroke(stro);        // Setting the contours colour as stro --> color (0, 0, 0).
  for (int i = 0; i <= 13; i++) {     // Var i=0,
    if (values[i] == Arduino.HIGH)    // If the value of i is equivalent to Arduino.HIGH ...
      fill(on);                       // then the button is lit ...
    else                              // if not  ...
      fill(off);                      // then the button is off.
    rect(420 - i * 30, 30, 20, 20);   // draw buttons
  textSize(15);                                               // text size
  fill(#09647C);                                              // text colour
  text("Programma controllo LED a comando :", 28, 20);        // Writes the text in brackets + coordinates (text, x, y)
void mousePressed() {
  int pin = (450 - mouseX) / 30;      // Set variable pin
  if (values[pin] == Arduino.LOW) {
    arduino.digitalWrite(pin, Arduino.HIGH);
    values[pin] = Arduino.HIGH;
    println(" LED "+pin+ " ON ");     // VIEW ON THE SERIAL THAT IS LED ON WHEN PRESSED.
    arduino.digitalWrite(pin, Arduino.LOW);
    values[pin] = Arduino.LOW;
    println(" LED "+pin+ " OFF ");    // VIEW ON THE SERIAL LED OFF THAT IS WHEN PRESSED.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
