Loading...
Pages: [1]   Go Down
Author Topic: how do i set analog value from a http string?  (Read 302 times)
Offline Offline
Newbie
View Profile
Thanks to zoomkat for the help getting me this far
So far i have an "on" and "off" button that controlls an led on pin 4
and a status showing the led status
Then i have a text box with a submit button, when i enter a value say 554 and press submit i get
http://10.1.1.177/?form=554
How do i then assign the value 554 to "int analog"
heres my code
Quote
#include <SPI.h>
#include <Ethernet.h>
int analog ;
 byte    mac[] =     { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };   //physical mac address
 byte    ip[] =      { 10,10,1,145 };                     // ip in lan
 byte    gateway[] = { 123,197,43,36 };                       // the IP of the router or acsesspoint
 byte    subnet[] =  { 255, 255, 255, 0 };                     //subnet mask (i dont think this is neccesary
 Server  server(80);                // server port (change this if you are having a local webserver else than the arduino)
 int     ledPin = 4;                // LED pin
 int     sensorPin = A0;            // analog in 0 for testing
 int     sensorValue = 0;           // integer for the analog sensor
 String  readString = String(30);   // string for fetching data from address
 boolean LEDON = false;             // LED status flag
  Serial.begin (9600);
  Ethernet.begin(mac, ip, gateway, subnet); //start Ethernet
  pinMode(ledPin, OUTPUT); //Set pin 4 to output
  analog = 100;
void loop(){
  Client client = server.available();  // Create a client connection
    if (client) {
      while (client.connected()) {
        if (client.available()) {
          char c = client.read();
        if (readString.length() < 30) { //read char by char HTTP request
           readString += c;  } //store characters to string
        if (c == '\n') { //if HTTP request has ended
       int stringthing = readString.indexOf("="); //here is a key component of where the status is being read by the arduino
          Serial.println (readString);
          if (stringthing > 1){
          if (readString.indexOf ("on")>0) { //led has to be turned ON
              digitalWrite(ledPin, HIGH); // set the LED on
              LEDON = true;
          if (readString.indexOf( "off") >0) {
            //led has to be turned OFF
            digitalWrite(ledPin, LOW); // set the LED OFF
            LEDON = false;
  client.println("HTTP/1.1 200 OK"); //output HTML data starting with standart header
  client.println("Content-Type: text/html");
  client.println();
 client.print("<form method=get name=LED>LED  .<input type='submit' name='Led' value='on'> <input type='submit' name='Led' value='off'>");
//client.println ("<input type=submit value=buton_name>"); //submit button
 client.print("LED status: ");
  if (LEDON == true) {
     client.println("ON");
   else {
    client.println("OFF");
client.print ("</p>");
client.print ("<form name=input action= method= get ><input type= text  name= form  value= 'analog'  /><input type= submit  value= Submit  /></form>");
client.print ( analog );
  client.println("</body></html>");
readString=""; //clearing string for next read
client.stop(); //stopping client
Any help or direction will be much apreciated, cheers, corey
Logged
Brisbane, Australia
Offline Offline
God Member
View Profile
If the value is always the rightmost element in the returned string, since you're using the String type, a function like this will do the trick:
Code:
int valueFromString(String test) { // pass it the String from your result
  int result = 0; // accumulator for value
  int power = 1; // self-explantatory (I hope!)
  // find the substring after the = which contains our value
  test = test.substring(test.lastIndexOf('='));
  // iterate through the substring after the = tallying up the values as we go
  for(int i = test.length()-1; i >= 0; i--) {
    result += (test.charAt(i)-'0') * power;
    power *= 10;
  return result;
Of course this is untested, so normal caveats about warranties apply...but pretty sure unless I've made a typo it should do the trick for you.
Cheers, Geoff
Logged
Offline Offline
Newbie
View Profile
Cheers, Geoff
Thanks geoff ,but i cant get it to work, could you please show me how to incorporate it into my code above.
That would be AWESOME .
I have spent Weeks and Weeks doing all the automation, lcd, ethernet, sd, rct code etc. and this is the last piece of the puzzle and its so frustrating ive been stuck on it for days.
Thanks heaps for your time, corey
Logged
Brisbane, Australia
Offline Offline
God Member
View Profile
Hi Corey
I don't have a lot of time to look at your code, but from what I see you don't differentiate whether the value being returned is from the buttons in the form that turn the LED on/off or the string.  So presuming your example of what returns above is correct, the options are the URL will look like one of these depending on what is done on the form...
http://10.1.1.177/?form=554 (or any other digit) or
http://10.1.1.177/?form=on or
http://10.1.1.177/?form=off
If that's the case, copy the function in my other post into your code, at the end is fine.  Then make this little modification to your existing testing of the string (just one way to do it, there are always many)
Code:
         boolean allDoneNow = false;
          if (stringthing > 1) {
                allDoneNow = true;
                LEDON = true;
              allDoneNow = true;
              LEDON = false;
            if(!allDoneNow)  // it wasn't on or off, but a digit that was returned
              analog = valueFromString(readString);
        } // end if (stringthing > 1)
All I'm doing there with the allDoneNow flag is ensuring that you don't try to populate the analog variable if "on" or "off" was returned as my function isn't written to handle the possibility of being sent a readString that isn't just digits following the =.  If you trust your users never to input anything but digits that's good as it is, but you might want to add checks in valueFromString() to ensure that's all you're getting if it's going to be used by others aside from yourself.
Remember to declare analog as an integer somewhere, because I haven't anywhere here.
Cheers, Geoff
« Last Edit: March 14, 2012, 03:06:48 am by strykeroz » Logged
Offline Offline
Newbie
View Profile
Thanks geoff , i could not get it to work but got this to
if (readString.substring(6,12)== "analog") // checks to make sure analog field submitted
newString =(readString.substring(13,17)); // gets number from string
analog = newString.toInt();              //convert newString into an int analog
Thanks, corey
Logged
Brisbane, Australia
Offline Offline
God Member
View Profile
Kewl, you learn something new every day  smiley
Logged
Pages: [1]   Go Up
Print
Jump to:
