Author Topic: Im so close but, help! ethernet control  (Read 420 times)
Hi there , after hundreds of google searches a cant find a simple straight forward answer to my problem.
I am making a home automation controller , have written al the code for that and all is good, then i thought it would be great to have controll over internet so i now have a freetronics etherten board it has the wiznet chip etc so practically an arduino board with an arduino ethernet shield all in one.
I have successfully been able to do a few of the examples in the ethernet librarys.
I want the arduino to be the server etc , i dont want to have it interfacing with this that and the next thing.
I have included the code of basically the server example below but with a button , could someone please show me how to change the code so when that button is pressed in the browser, maybe changes the state of an led conected to pin 4 of the arduino.
Then i think i would be able to figure the rest out.
Any help will be greatly apreciated.
cheers , corey
#include <SPI.h>
#include <Ethernet.h>
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte ip[] = { 192,168,1, 177 };
Server server(80);
  Ethernet.begin(mac, ip);
  server.begin();
  // listen for incoming clients
  Client client = server.available();
  if (client) {
    // an http request ends with a blank line
    boolean currentLineIsBlank = true;
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        if (c == '\n' && currentLineIsBlank) {
          // send a standard http response header
          client.println();
          // output the value of each analog input pin
          for (int analogChannel = 0; analogChannel < 6; analogChannel++) {
            client.print("analog input ");
            client.print(analogChannel);
            client.print(" is ");
            client.print(analogRead(analogChannel));
            client.println("<br />");
          client.print("<device-name-or-id><input type=submit name='<device-name-or-id>' value='Toggle' ></form>"); // this is the button i want to change the state of led
          break;
        if (c == '\n') {
          // you're starting a new line
        else if (c != '\r') {
          // you've gotten a character on the current line
          currentLineIsBlank = false;
    // give the web browser time to receive the data
    delay(1);
    // close the connection:
    client.stop();
Something to try.
//zoomkat 12-8-11
//simple button GET with iframe code
//for use with IDE 1.0
//open serial monitor to see what the arduino receives
//use the \ slash to escape the " in the html
//address will look like http://192.168.1.102:84 when submited
//for use with W5100 based ethernet shields
#include <SPI.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
byte ip[] = { 192, 168, 1, 102 }; // ip in lan
byte gateway[] = { 192, 168, 1, 1 }; // internet access via router
byte subnet[] = { 255, 255, 255, 0 }; //subnet mask
EthernetServer server(84); //server port
String readString;
void setup(){
  pinMode(4, OUTPUT); //pin selected to control
  //start Ethernet
  server.begin();
  //enable serial data print
  Serial.println("server LED test 1.0"); // so I can keep track of what is loaded
void loop(){
  // Create a client connection
  if (client) {
        //read char by char HTTP request
        if (readString.length() < 100) {
          //store characters to string
          readString += c;
          //Serial.print(c);
        //if HTTP request has ended
        if (c == '\n') {
          Serial.println(readString); //print to serial monitor for debuging
          //now output HTML data header
             if(readString.indexOf('?') >=0) { //don't send new page
               client.println("HTTP/1.1 204 Zoomkat");
               client.println();
               client.println();
             else {
          client.println("HTTP/1.1 200 OK"); //send new page
          client.println();
          client.println("<HTML>");
          client.println("<HEAD>");
          client.println("<TITLE>Arduino GET test page</TITLE>");
          client.println("</HEAD>");
          client.println("<BODY>");
          client.println("<H1>Zoomkat's simple Arduino button</H1>");
          client.println("<a href=\"/?on\" target=\"inlineframe\">ON</a>");
          client.println("<a href=\"/?off\" target=\"inlineframe\">OFF</a>");
          //client.println("<IFRAME name=inlineframe src=\"res://D:/WINDOWS/dnserror.htm\" width=1 height=1\">");
          client.println("<IFRAME name=inlineframe style=\"display:none\" >");
          client.println("</IFRAME>");
          client.println("</BODY>");
          client.println("</HTML>");
          delay(1);
          //stopping client
          client.stop();
          ///////////////////// control arduino pin
          if(readString.indexOf("on") >0)//checks for on
            digitalWrite(4, HIGH);    // set pin 4 high
            Serial.println("Led On");
          if(readString.indexOf("off") >0)//checks for off
            digitalWrite(4, LOW);    // set pin 4 low
            Serial.println("Led Off");
          //clearing string for next read
          readString="";
put in key search words,
AWESOME , thanks zoomkat
Something to try.
//zoomkat 12-8-11
#include <SPI.h>
String readString;
void setup(){
  //start Ethernet
  server.begin();
void loop(){
  if (client) {
          readString += c;
          //Serial.print(c);
        if (c == '\n') {
               client.println();
               client.println();
             else {
          client.println();
          delay(1);
          //stopping client
          client.stop();
          readString="";
Thanks heaps , got that working ,
How do i change it so they are buttons?, ones that say "on"  and "off" on them
Thanks, corey
For button code, a google search for "button html tutorial" will supply info. Below is some test code that uses buttons. The code makes arduino pin 4 high/low, as well as move a servo between two positions.
//zoomkat 3-1-12
//simple button GET for pin and servo control
#include <SPI.h>
#include <Servo.h>
Servo myservo;  // create servo object to control a servo
String readString;
void setup(){
  //start Ethernet
  server.begin();
  myservo.write(90); //set initial servo position if desired
  myservo.attach(7);  //the pin for the servo co
void loop(){
  if (client) {
          readString += c;
          //Serial.print(c);
        if (c == '\n') {
          client.println();
          client.println("<br><input type=\"button\" value=\"ON\" onmousedown=\"location.href ('/?on');\"/>");
          client.println("<input type=\"button\" value=\"OFF\" onmousedown=\"location.href ('/?off');\"/>");
          delay(1);
          //stopping client
          client.stop();
            myservo.write(40);
            myservo.write(140);
          readString="";
Thanks again zoomkat , one more question? please
i  also have a text input field when i put number in like 1233 i get something like http://1.11.2.2.2/?form=1233
How do i the asign say "int analog" the value 1233.
Much apreciated , corey
Heres my test code
#include <SPI.h>
int analog ;
 byte    ip[] =      { 10,1,1,177 };                     // ip in lan
 byte    gateway[] = { 124,197,43,38 };                       // the IP of the router or acsesspoint
 byte    subnet[] =  { 255, 255, 255, 0 };                     //subnet mask (i dont think this is neccesary
 Server  server(80);                // server port (change this if you are having a local webserver else than the arduino)
 int     ledPin = 4;                // LED pin
 int     sensorPin = A0;            // analog in 0 for testing
 int     sensorValue = 0;           // integer for the analog sensor
 String  readString = String(30);   // string for fetching data from address
 boolean LEDON = false;             // LED status flag
  Serial.begin (9600);
  Ethernet.begin(mac, ip, gateway, subnet); //start Ethernet
  pinMode(ledPin, OUTPUT); //Set pin 4 to output
  analog = 100;
void loop(){
  Client client = server.available();  // Create a client connection
    if (client) {
        if (readString.length() < 30) { //read char by char HTTP request
           readString += c;  } //store characters to string
        if (c == '\n') { //if HTTP request has ended
       int stringthing = readString.indexOf("="); //here is a key component of where the status is being read by the arduino
          Serial.println (readString);
          if (stringthing > 1){
          if (readString.indexOf ("on")>0) { //led has to be turned ON
              digitalWrite(ledPin, HIGH); // set the LED on
              LEDON = true;
          if (readString.indexOf( "off") >0) {
            //led has to be turned OFF
            digitalWrite(ledPin, LOW); // set the LED OFF
            LEDON = false;
  client.println("HTTP/1.1 200 OK"); //output HTML data starting with standart header
  client.println();
 client.print("<form method=get name=LED>LED  .<input type='submit' name='Led' value='on'> <input type='submit' name='Led' value='off'>");
 client.print("LED status: ");
  if (LEDON == true) {
     client.println("ON");
   else {
    client.println("OFF");
client.print ("</p>");
client.print ("<form name=input action= method= get ><input type= text  name= form  value= 'analog'  /><input type= submit  value= Submit  /></form>");
client.print ( analog );
  client.println("</body></html>");
readString=""; //clearing string for next read
client.stop(); //stopping client
Below is one way to convert a readString like 1233 to a number.
int n = readString.toInt();  //convert readString into a number
Thanks zoomkat , but i cant seem to get it to work?
I tried putting in my code as
analog =  = readString.toInt();  //convert readString into a number
when i first load it it says analog is 30 but then no matter what i enter it says its value is 0
Any ideas? , thanks heaps, corey
Any ideas?
Yes, you need to do some study on your own to figure out why the below are totally different things:
[/quote]
Sorry that was a typo here, not im my code its of course
analog =  readString.toInt();
So thats not the problem , thanks for your patience
Thanks to all
This is what i came up with
if (readString.substring(6,12)== "analog") // checks to make sure analog field submitted
newString =(readString.substring(13,17)); // gets number from string
analog = newString.toInt();              //convert newString into an int analog
works great   smiley
