Topic: ATMEL 93c46 (Read 8438 times) previous topic - next topic
raees
hey
        i wanted to work with all the microwire eeprom available,till now 93c56 and 93c66 is done,but
having trouble with 93c46.
Code: [Select]
//difining pins for eeprom
int CLOCK =4;
int DATA_OUT =3;
int DATA_IN = 2;
int CHIP_SEL =5;
int high = 0,low =0;     //high and low address
byte dataword[]={"hello world!"};    //data to send in eeprom
byte READ  = 0b1100;                //read instruction
byte WRITE = 0b1010;               //write instruction
byte EWEN  = 0b10011;         //erase write enable instruction
void setup(){
  pinMode(CLOCK ,OUTPUT);
  pinMode(DATA_OUT ,OUTPUT);
  pinMode(DATA_IN ,INPUT);
  pinMode(CHIP_SEL ,OUTPUT);
  digitalWrite(CHIP_SEL ,LOW);
  digitalWrite(CHIP_SEL ,HIGH);
  shiftOut(DATA_OUT,CLOCK,MSBFIRST,EWEN);     //sending EWEN instruction
  delay(10);
  for(int i=0;i<=13;i++)
    shiftOut(DATA_OUT,CLOCK,MSBFIRST,WRITE); //sending WRITE instruction
    shiftOut(DATA_OUT,CLOCK,MSBFIRST,low);   //sending low address
    shiftOut(DATA_OUT,CLOCK,MSBFIRST,dataword[i]); //sendind data
    delay(100);
    low++;       //incrementing low address
  low=0;
  for (int i=0;i<=13;i++)
    shiftOut(DATA_OUT,CLOCK,MSBFIRST,READ); //sending READ instruction
    byte incoming = shiftIn(DATA_IN,CLOCK,MSBFIRST); //sendind data
    Serial.println(char(incoming));
  while(1);
this code works for 93c56 and 93c66 ,but when i plug 93c46 it doesn't write and read properly.
so anyone can tell me what changes should i do in order to make this code work for 93c46.
have a great day all
thanks
PaulS
I voted for 93c56. Hope that helps.
raees
but how did i make this code work for AT93c46 any one guys
thanks
gelfling6
I can't remember where I obtained it from, but there is a project out on the net, using the MEGA-2560, using higher digital pins instead of analog pins like everyone else has..     I'm going to try mixing the two, feeding the code from here , and hopefully, it'll work with the MEGA.
I've been pulling a LOT of 93C46's from various old network cards.. the problem with the project I found, it is writing immediately to the chip, which I don't want it to do.. I want to read the data contained on the EEPROM..
raint
Hi. I know this is really old topic. But there was very limited information about this chip online, so i want to update it for future readers.
I got it to work. So excited.
I based my code on your's. However made shiftout and shiftin my in my own functions since I wanted to understand spi better.  Also used string and chars to switch bits, because I'm more comfortable with them.
Code: [Select]
//defining pins for eeprom
int CLOCK =9;
int DATA_OUT =10;
int DATA_IN = 11;
int CHIP_SEL =8;
void setup(){
void sendSer(String s){
  digitalWrite(CHIP_SEL,HIGH);
  int len = s.length();
  for (int i=0;i<len;i++){
    char c = s.charAt(i);
    if (c=='0')
      digitalWrite(DATA_OUT, LOW);
      digitalWrite(DATA_OUT, HIGH);
    digitalWrite(CLOCK,HIGH);
    digitalWrite(CLOCK,LOW);
    //needs little delay to work
    delay(10);
void recvSer(String s){
    char c = digitalRead(DATA_IN);
    Serial.print(c==LOW ? "0" : "1");
void loop(){
  digitalWrite(CHIP_SEL, HIGH);
  sendSer("00000100"); //sending EWEN instruction
  sendSer("1100000"); //
  digitalWrite(CHIP_SEL,LOW);
  sendSer("00000101"); //sending WRITE instruction
  sendSer("0000001"); //sending Address
  sendSer("10001101"); //sending data
  sendSer("00000110"); //sending READ instruction
  //dummy zero that is sent at start of read
  //receiving data... zeros is just to specify count.
  //no meaning in them... output is to serial
  recvSer("00000000");
  while(1);
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
