Topic: Button Output on TFT Screen (Read 1 time) previous topic - next topic
Scallywag
Hi everyone,  I'm working with the button example.  I'm trying to figure out when I press the button, it will write the word "ON" on the screen.
Kinda has me stumped right now.  Thanks for any info.
PaulS
Quote
Me, too. Hard to tell from your code where the problem is, or from your problem description what is working and what is not working.
nickgammon
Hi!
Quote
What button example?
Please post technical questions on the forum, not by personal message. Thanks!
More info:
http://www.gammon.com.au/electronics
Scallywag
The button example on 0022.  I got it outputted to the screen. Here's how I slightly modified the code to get it out on the screen, now the problem I have is when I press the button and "ON" appears on the screen, I don't know how to get "ON" off the screen and return to the "OFF" state.
#include <TFT.h>
  Button
Turns on and off a light emitting diode(LED) connected to digital
pin 7, when pressing a pushbutton attached to pin 2.
The circuit:
* LED attached from pin 13 to ground
* pushbutton attached to pin 2 from +5V
* 10K resistor attached to pin 2 from ground
* Note: on most Arduinos there is already an LED on the board
attached to pin 13.
created 2005
by DojoDave <http://www.0j0.org>
modified 28 Oct 2010
by Tom Igoe
This example code is in the public domain.
http://www.arduino.cc/en/Tutorial/Button
// constants won't change. They're used here to
// set pin numbers:
const int buttonPin = 2;     // the number of the pushbutton pin
const int TftPin =  7;      // the number of the LED pin
// variables will change:
int buttonState = 0;         // variable for reading the pushbutton status
  Tft.init();
  // initialize the LED pin as an output:
  pinMode(TftPin, OUTPUT);
  // initialize the pushbutton pin as an input:
  pinMode(buttonPin, INPUT);
void loop(){
  // read the state of the pushbutton value:
  buttonState = digitalRead(buttonPin);
delay(100);
  // check if the pushbutton is pressed.
  // if it is, the buttonState is HIGH:
  if (buttonState == HIGH) {
      Tft.drawString("ON",35,200,2,BLUE);
    Tft.drawString("OFF",55,150,2,RED);
dxw00d
Try doing this:
Code: [Select]
      Tft.drawString("ON",35,200,2,BLUE); but using the background colour instead of BLUE.
Scallywag
Thanks, that got it.  I used the return function in front of it and it worked like a charm.  Thanks everyone for the advice
