Topic: Controlling RGB LED over serial (Read 1 time) previous topic - next topic
lokefar
Hi
I'm trying to control an common anode RGB led using this code:
Code: [Select]
const int RED = 6;
const int GREEN = 5;
const int BLUE = 3;
int REDvalue = 0;
  pinMode(RED, OUTPUT);
  pinMode(GREEN, OUTPUT);
  pinMode(BLUE, OUTPUT);
void loop(){
  if (Serial.available() > 0) {
    int REDvalue = Serial.read();
    switch (REDvalue) {
      case 'a':
        digitalWrite(RED, LOW);
    default:
    for (int RED = 6; ;) {
      digitalWrite(RED, HIGH);
But when I write a in the serial monitor and press send nothing happens.
johnwasser
Did you select "No line ending" in Serial Monitor?  If not, your 'a' will turn off the red LED and the line ending will immediately turn it back on.
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
lokefar
lokefar
For some reason I can turn it off now... Which as I see it should be the opposed of what should happen. But I can't turn it back on.
johnwasser
This 'for' loop does nothing at all which might explain why you can't turn the light back on.
Code: [Select]
Try it this way instead:
Code: [Select]
lokefar
I've asked for help for my entire project in this post:
http://arduino.cc/forum/index.php/topic,96268.0.html
Any help would be appreciated.
Grumpy_Mike
Quote
So how does the last comment:-
Quote
Ignore the question. Figured it all out a different way around.
Square with this?
Mungoo
#7
Mar 16, 2012, 06:41 am Last Edit: Mar 16, 2012, 06:50 am by Mungoo Reason: 1
Thank you. I had not come across that site and it helped a lot. You were right that I Led Light Accessories really needed to see how diodes worked and when I saw that understanding the LED was easy.
