Topic: [SOLVED]Bunch of momentariesdata send ONLY on 2nd pushes need array shift-reg (Read 805 times) previous topic - next topic
ioflex
Here's what I need to do:
- have  4 momentry buttons hooked to digital inputs upon hitting the 2nd one the data is sent.
ADDITIONALLY:
- need reset button that allows me to start again if i hit the 1st button
and then decide i'd like to choose a different pair's 1st button. ie. starting over choosing a pair of buttons.
PaulS
-  if it's easily possible?
Yes. Set a value when the first switch is pressed, corresponding to the switch number (initial value should be 0).
Set another value when the second switch is pressed.
On each pass through loop, see if value1 and value2 are greater than 0. If so, send some data (value1 * 10 + value2 will say what to send). Reset both values to 0.
The reset switch you add (not the one on the Arduino) will reset both values to 0, to.
- if it needs more than a basic arduino, and any arduino? older ok?
It doesn't. Any Arduino will do.
ioflex
PaulS ... Wow!
hey, I've seen quite a few of your posts over the last few days of reading.
you sure have helped me as well!
[One Big Question: use digital pins for analog switch inputs?]
I'd like to use the 6 analog inputs for footpedals? And I'd like to use the
digital pins for the analog momentary switches?
Also trying to deduce if it would be better to use a mega 'cause it has 16 analog inputs?
PaulS
No. Analog pins are for reading analog data. Digital pins are for reading digital data. A momentary contact switch is a digital device. With the exception of some bouncing, they are either on or off.
I'd like to use the 6 analog inputs for footpedals.
Are these analog devices? That is, are they like potentiometers that have a varying output, or are they like light switches - on or off?
And I'd like to use the digital pins for the analog momentary switches
Momentary contact switches are not analog. They are either on or off.
No. See above.
