Topic: How do I use a button to make sound? (conductive paint is involved) (Read 835 times) previous topic - next topic
Mossi
I'm new to Arduino and am doing a project with conductive paint. I have it all set up so that there is a space that doesn't complete the circuit (I have been told this will work as a pushbutton). There is a separate piece of paper covered with the conductive paint and when you put it down it should complete the circuit and make noise. At the moment it makes noise on a loop anyway. Below is the code for the sound but I think I need to add a button in there so it will work. I used the button example and it uploaded with the code underneath but the music still looped...
// Project 11 - Melody Player
int speakerPin = 9;
int length = 15; // the number of notes
char notes[] = "ccggaagffeeddc "; // a space represents a rest
int beats[] = { 1, 1, 1, 1, 1, 1, 2, 1, 1, 1, 1, 1, 1, 2, 4 };
int tempo = 300;
void playTone(int tone, int duration) {
  for (long i = 0; i < duration * 1000L; i += tone * 2) {
     digitalWrite(speakerPin, HIGH);
     delayMicroseconds(tone);
     digitalWrite(speakerPin, LOW);
void playNote(char note, int duration) {
  char names[] = { 'c', 'd', 'e', 'f', 'g', 'a', 'b', 'C' };
  int tones[] = { 1915, 1700, 1519, 1432, 1275, 1136, 1014, 956 };
  // play the tone corresponding to the note name for (int i = 0; i < 8; i++) {
    if (names[i] == note) {
      playTone(tones[i], duration);
  pinMode(speakerPin, OUTPUT);
  for (int i = 0; i < length; i++) {
    if (notes[i] == ' ') {
      delay(beats[i] * tempo); // rest
      playNote(notes[i], beats[i] * tempo);
    // pause between notes
    delay(tempo / 2);
Grumpy_Mike
Look at your code in the post, it is mangled.
Modify the post. Delete the code. Paste it in again and select it all. Then hit the #icon and save.
This will put the code in a box so others can copy and compile it and see if they can help.
Mossi
Grumpy_Mike
What do you mean by this?
There is no button code in the sketch you posted.
There is no underneath to put anything. When you upload a sketch it completely replaces what is there already.
You need to incorporate the "button"  in your loop. After setting up the button pin number in a variable called 'pin' then your loop would look something like this:-
if(digitalRead(pin) == LOW) {  // make the sound if you read LOW from the button.
    delay(tempo / 2);
