Topic: Use Arduino Mega 2560 as ISP (Bootloading ATMEGA328P-PU) (Read 14847 times) previous topic - next topic
Lentrave
Him I have problem using my Mega 2560 as ISP with the Included example in Arduino IDE 1.0. I want to upload boot loader to a ATMEGA328P-PU. I plugged it like this:
MEGA 2560                ATMEGA328
Pin 50 (MISO)  -->       Pin 18 (MISO)
Pin 51 (MOSI)  -->       Pin 17 (MOSI)
Pin 52 (SCK)   -->       Pin 19 (SCK)
Pin 53 (SS)     -->       Pin 1   (RESET)
5v                -->       Pin 7    (Vcc)
Gnd              -->       Pin 8,22 (Gnd)
The atmega328 in on a breadboard with 16 mhz crystal and 2x 22pF capacitor on pin 9 and 10.
I try to short the reset pin to 5v (on the mega 2560) with :110 ohm resistor= don't work give this error: avrdude: stk500_recv(): programmer is not responding
        :0,1 uF capacitor= don't work give this error: avrdude: stk500_recv(): programmer is not responding
        :100 uF capacitor= Seem to work but give me this error:
avrdude: Yikes!  Invalid device signature.
         Double check connections and try again, or use -F to override
         this check.
I try different atmega328 chip, different crystal, different capacitor and i always have this error.
Someone have an idea of what is wrong with this? I look everywhere on the net but i find almost nothing about ArduinoISP with a Atmega 2560.
Tanks !
Coding Badly
Did you connect the 100 uF capacitor right after uploading the ArduinoISP sketch?
Lentrave
Yes i upload the isp sketch and then i place the capacitor between reset and 5v.
Coding Badly
RESET and +5V?  Did you mean to write RESET and GND?  Or did you connect it incorrectly?
Lentrave
yes reset and 5v ? .... it supose to be between RESET and GND ?
Coding Badly
Yes.
Lentrave
#6
Mar 15, 2012, 08:52 pm Last Edit: Mar 15, 2012, 08:54 pm by Lentrave Reason: 1
Yes.
I'm a NoOb with arduino.... and to put reset to 5v can cause this error? .1 uf is a correct value ?
tanks to help me
nickgammon
After quite a bit of mucking around I go this to work. For a start, I had problems with the ArduinoISP sketch supplied with the IDE. However this one from Adafruit worked.
https://raw.github.com/adafruit/ArduinoISP/master/ArduinoISP2.pde
Install that, set the target board to Mega2560, and upload that to the Mega.
Next, I created a .hex file in the IDE (turn on verbose output to see its file name). At this stage the "target board" should be a Uno (or whatever it is). Copy the .hex file name to the clipboard.
Wire up the Mega to the chip to be programmed as per your diagram above. Now to stop the Mega resetting you need to put something like a 10 uF capacitor between reset (the + side of the cap) and the Gnd pin. Do this after you have uploaded the ArduinoISP2 sketch.
Next I went to the command line/console and typed in this:
avrdude -c avrisp -p m328p -P /dev/cu.usbmodemfd141 -U flash:w:Blink_Two_LEds.hex -b 19200 -v -v -v -v
The target board type was a Atmega328p (m328p). The protocol is avrisp. The port was (in my case) /dev/cu.usbmodemfd141 - you need to adjust that. The baud rate is 19200. And the -v -v -v -v is "very verbose" output, so you can see at what point it fails, if it fails. In my case the .hex file was Blink_Two_LEds.hex, but you would paste in whatever file name you got from the compile.
More info:
nickgammon
With -v -v -v (3 levels of verbosity) I see this output:
         Programmer Type : STK500
         Description     : Atmel AVR ISP
         Hardware Version: 2
         Firmware Version: 1.18
         Topcard         : Unknown
         Vtarget         : 0.0 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
Reading | ################################################## | 100% 0.12s
avrdude: Device signature = 0x1e950f
avrdude: safemode read 1, lfuse value: ff
avrdude: safemode read 2, lfuse value: ff
avrdude: safemode read 3, lfuse value: ff
avrdude: safemode: lfuse reads as FF
avrdude: safemode read 1, hfuse value: d6
avrdude: safemode read 2, hfuse value: d6
avrdude: safemode read 3, hfuse value: d6
avrdude: safemode: hfuse reads as D6
avrdude: safemode read 1, efuse value: 5
avrdude: safemode read 2, efuse value: 5
avrdude: safemode read 3, efuse value: 5
avrdude: safemode: efuse reads as 5
avrdude: NOTE: FLASH memory has been specified, an erase cycle will be performed
         To disable this feature, specify the -D option.
avrdude: erasing chip
avrdude: reading input file "Blink_Two_LEds.hex"
avrdude: input file Blink_Two_LEds.hex auto detected as Intel Hex
avrdude: writing flash (1218 bytes):
Writing | ################################################## | 100% 1.43s
avrdude: 1218 bytes of flash written
avrdude: verifying flash memory against Blink_Two_LEds.hex:
avrdude: load data flash data from input file Blink_Two_LEds.hex:
avrdude: input file Blink_Two_LEds.hex contains 1218 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 1.43s
avrdude: verifying ...
avrdude: 1218 bytes of flash verified
avrdude: safemode: Fuses OK
avrdude done.  Thank you.
More info:
Lentrave
Tanks for the response .... but i upload the ArduinoISP2 and after this you lost me ..... i want to burn the bootloader.... how i make a .hex file and why? Im noob with arduino. By the way i try to put capacitor between reset and ground and i have the same error
Lentrave
After uploading ArduinoISP2 on my mega 2560 and activate verbose mode,i try to upload the bootloader and gave me this:
/Applications/Arduino1,0.app/Contents/Resources/Java/hardware/tools/avr/bin/avrdude -C/Applications/Arduino1,0.app/Contents/Resources/Java/hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega328p -cstk500v1 -P/dev/tty.usbmodemfd111 -b19200 -e -Ulock:w:0x3F:m -Uefuse:w:0x05:m -Uhfuse:w:0xde:m -Ulfuse:w:0xff:m
avrdude: Version 5.11, compiled on Sep  2 2011 at 18:52:52
         Copyright (c) 2007-2009 Joerg Wunsch
         System wide configuration file is "/Applications/Arduino1,0.app/Contents/Resources/Java/hardware/tools/avr/etc/avrdude.conf"
         User configuration file is "/Users/lentrave/.avrduderc"
         User configuration file does not exist or is not a regular file, skipping
         Using Port                    : /dev/tty.usbmodemfd111
         Using Programmer              : stk500v1
         Overriding Baud Rate          : 19200
avrdude: Send: 0 [30]   [20]
avrdude: Recv: . [14]
avrdude: Recv: . [10]
         AVR Part                      : ATMEGA328P
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Description     : Atmel STK500 Version 1.x firmware
avrdude: Send: A [41] . [80]   [20]
avrdude: Recv: . [02]
avrdude: Send: A [41] . [81]   [20]
avrdude: Recv: . [01]
avrdude: Send: A [41] . [82]   [20]
avrdude: Recv: . [12]
avrdude: Send: A [41] . [98]   [20]
avrdude: Recv: . [00]
         Hardware Version: 2
         Topcard         : Unknown
avrdude: Send: A [41] . [84]   [20]
avrdude: Send: A [41] . [85]   [20]
avrdude: Send: A [41] . [86]   [20]
avrdude: Send: A [41] . [87]   [20]
avrdude: Send: A [41] . [89]   [20]
         Vtarget         : 0.0 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
avrdude: Send: B [42] . [86] . [00] . [00] . [01] . [01] . [01] . [01] . [03] . [ff] . [ff] . [ff] . [ff] . [00] . [80] . [04] . [00] . [00] . [00] . [80] . [00]   [20]
avrdude: Send: E [45] . [05] . [04] . [d7] . [c2] . [00]   [20]
avrdude: Send: P [50]   [20]
Reading | avrdude: Send: V [56] 0 [30] . [00] . [00] . [00]   [20]
avrdude: Send: V [56] 0 [30] . [00] . [01] . [00]   [20]
################avrdude: Send: V [56] 0 [30] . [00] . [02] . [00]   [20]
avrdude: Device signature = 0x000000
         this check.
avrdude: Send: Q [51]   [20]
nickgammon
-cstk500v1
I was using -c avrisp.
The bootloader file will be in your "bootloaders" folder, eg. optiboot_atmega328.hex
Try locating that file, and then using the avrdude command with it.
Looks like your device is: -P/dev/tty.usbmodemfd111
More info:
Lentrave
-cstk500v1
Ok i wrote this in Therminal (Mac OS X):
/Applications/Arduino1,0.app/Contents/Resources/Java/hardware/tools/avr/bin/avrdude -C/Applications/Arduino1,0.app/Contents/Resources/Java/hardware/tools/avr/etc/avrdude.conf -c avrisp -p m328p -P /dev/cu.usbmodemfd111 -U flash:w:optiboot_atmega328.hex -b 19200 -v -v -v -v
and i receive the same error
         Using Port                    : /dev/cu.usbmodemfd111
         Using Programmer              : avrisp
         PAGEL                         : PD7
         BS2                           : PC2
         RETRY pulse                   : SCK
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
         Hardware Version: 2
         Topcard         : Unknown
         Vtarget         : 0.0 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
Reading |                                                    | 0% 0.00savrdude: Send: V [56] 0 [30] . [00] . [00] . [00]   [20]
Reading | #################                                  | 33% 0.08savrdude: Send: V [56] 0 [30] . [00] . [02] . [00]   [20]
         this check.
Any idea? i have always the " avrdude: Device signature = 0x000000 " error.
nickgammon
After uploading ArduinoISP2 on my mega 2560 ...
I was getting that when using the ArduinoISP that came with the IDE. Where exactly did you get yours from?
More info:
Lentrave
the one you post before
