Topic: not in sync help-UNO board (Read 2044 times) previous topic - next topic
4x4_hank
UNO board, windows 7 ultimate 64 bit
i loaded all the drivers as per instructions on web site.  opened the blink file and uploaded it.  it works fine.  Then i tried to load the button file and got this message: avrdude: stk500_getsync(): not in sync: resp=0x00
I have since rebooted, changed com ports, usb ports, tried to update drivers.  reset the board and upload.
and just so you know i'm new to every aspect of this... to include posting on a forum!
4x4_hank
I've now switched usb cables.  ALso i've gone through the entire trouble shooting section and nothing is mentioned there
Coding Badly
#2
Mar 16, 2012, 05:18 am Last Edit: Mar 16, 2012, 09:00 am by Coding Badly Reason: 1
When you connect the Arduino to the computer does the operating system make the device insertion sound?
If anything other than the USB cable is connected to the Arduino disconnect it.
Edit: Typographical mistake corrected.
4x4_hank
yes i get the "chime" when it plugs in
nothing is connected to the board
Coding Badly
Does the board pass this test...
http://arduino.cc/forum/index.php/topic,73748.0.html
4x4_hank
don't know what this is
Start your favourite terminal application.  Serial Monitor will work fine.
Coding Badly
http://www.google.com/search?q=terminal+application
http://en.wikipedia.org/wiki/Terminal_emulator
Serial Monitor...
• Start the Arduino IDE
• Click the menu item Tools then Serial Port.  Ensure the correct serial port is selected.
• Click the menu item Tools then Serial Monitor
• Continue with the loop-back test
4x4_hank
it does not repeat what i'm sending
4x4_hank
also, it did not chime when i plugged it in with the jumpers installed
Coding Badly
That's odd.
You connected just two jumpers?  The first connects TX to RX?  The second connects RESET to GND?
Does the USB cable work with other devices?
4x4_hank
it worked with this one originally, i have tried other cables from printers that work.
i'm sure it doesn't matter which grnd i grnd the reset to. and yes tx to rx
Coding Badly
And with the jumpers removed the computer does chime?
4x4_hank
i just tried again with a different usb cable and didn't get the chime.  I pulled out the jumpers and plugged it in and got a chime.  then i reinstalled the jumpers and got the chime.  the plugged in chime sounds different than normal.  lower, possibly a sort of not good connection sound.  ran the serial monitor no echo
4x4_hank
this is what shows in my device manager for coms and ports.  nothing about an arduino being plugged in
http://screencast.com/t/LdAzy32bDK
Coding Badly
Try this...
• Disconnect the Arduino from the computer
• Remove the jumpers
• Open Device Manager.
? Are COM1, COM3, and COM4 listed under Ports?
? Are any Unknown devices present?
• Connect the Arduino.
? Did the computer chime?
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
