« Reply #15 on: March 22, 2012, 06:31:28 am » |
@Robtillaart
Thank you so much for helping me out here but actually your code is giving me similar results as I was getting before the problem is that I have to measure the pulse widths between 10 to 15 microseconds accurately but your code as well as my code gives 8 or 12 microsecond for a 10 microsecond width input pulse and similarly it gives either 12 or 16 for pulse widths between 12 and 16 so that is the problem which I have been facing. The counter takes about 4 microsecond so is there any way to improve from this?
Thanks again
Dubai, UAE
« Reply #16 on: March 22, 2012, 06:48:39 am » |
Hi, I keep meaning to look into it myself and never get the time, but isn't the input capture feature of hardware timer1 exactly what you need to measure these small intervals ? Duane B rcarduino.blogspot.com
« Reply #17 on: March 22, 2012, 07:01:36 am » |
yes I need to measure that and it will in turn give me pulse width
Dubai, UAE
« Reply #18 on: March 22, 2012, 07:08:16 am » |
Hi, Just to be clear, I am referring to the input capture functionality of the timer, this is a timer configuration which will copy the exact timer count into a dedicated register when the pin state changes, you can then read this captured hardware timer value from your code. As this is using the hardware timer directly, its not reliant on or effected by any code that may be running. Not sure if thats what you understood. Duane B rcarduino.blogspot.com
Netherlands
« Reply #19 on: March 22, 2012, 03:27:38 pm » |
Thank you so much for helping me out here but actually your code is giving me similar results as I was getting before the problem is that I have to measure the pulse widths between 10 to 15 microseconds accurately but your code as well as my code gives 8 or 12 microsecond The micros() was just a reference timing, find below a stripped pulsewidth meter for periods smaller than 24576 micros based on a tight software loop. One iteration takes 6/16 microsecond so we can 'measure" the following steps between 10 and 15 usec. So approx 15 steps. 26 9,750 27 10,125 28 10,500 29 10,875 30 11,250 31 11,625 32 12,000 33 12,375 34 12,750 35 13,125 36 13,500 37 13,875 38 14,250 39 14,625 40 15,000 41 15,375 // // FILE: PulseWidthMeter.pde // AUTHOR: Rob Tillaart // DATE: 2012-mar-20 // // LINK: http://arduino.cc/forum/index.php?action=post;topic=96971.0 //
unsigned int count = 0; void setup() { Serial.begin(9600); Serial.println("pulse width meter 0.2");
pinMode(3, INPUT); }
void loop() { count = 0; while ((PIND & B00001000) == B00000000); // wait for HIGH while ((PIND & B00001000) == B00001000) count++; // start counting until LOW
float usec = 1.0 * count * 6/16; Serial.print("CNT: "); Serial.println(count, DEC); Serial.print(" equals "); Serial.print(usec, 2); Serial.println(" microseconds.");
delay(1000); } With the hardware timer more accuracy should be possible.
« Reply #20 on: March 22, 2012, 04:08:21 pm » |
Thanks Robtillaart
I just want to ask that the values which you showed are the ones which you got after applying the pulse to arduino and the changing its width from 10 15 microseconds? is it so? actually I can't check this at this moment because I don't have arduino at this time but I am realy anxious to know this
Thanks again
Netherlands
« Reply #21 on: March 22, 2012, 05:07:15 pm » |
I just want to ask that the values which you showed are the ones which you got after applying the pulse to arduino and the changing its width from 10 15 microseconds? is it so? actually I can't check this at this moment because I don't have arduino at this time but I am realy anxious to know this The table was made by a spreadsheet the first column is the value of the counter and the second one is the number of microseconds the pulse was. As the units are in 6/16 of a micros this is an indication for the precision achievable this way (approx 1/3 micros) So you said you need to measure pulse of 10-15 micros. How precise do you want to measure? Is a whole value OK, [10,11,12,13,14,15] or do you need a decimal digit?
« Reply #22 on: March 22, 2012, 05:13:59 pm » |
ahaa that's very nice and yes the whole value is absolutely fine, means that if the input pulse width is 10.35 or so then even the value 10 would be perfect.
« Reply #23 on: March 22, 2012, 06:12:56 pm » |
@Robtillaart
one more thing I want to ask is can i get serial print messages directly in an excel file simultaneously while the time of printing?
Netherlands
« Reply #24 on: March 23, 2012, 12:50:56 am » |
one more thing I want to ask is can i get serial print messages directly in an excel file simultaneously while the time of printing? Yes, google for gobetwino
« Reply #25 on: March 23, 2012, 01:17:12 pm » |
@Robtillaart
Thanks and today I have checked the code output by applying different pulses from 10 microseconds to 15 microseconds so for 10 microsecond input pulse the output comes to be 7.13 or 7.50 and for 12 microsecond input pulse the output comes to be either 9.00 or 8.13 and so on. I don't know whether we could improve it or not so what do you think?
Thanks again
Netherlands
« Reply #26 on: March 23, 2012, 01:27:34 pm » |
what do you think? The ratio seems to be correct! 7.5 : 9 == 10 : 12 7.13 : 8.13 ~~ 10 : 12 Which version of the code do you use? - the one with the unsigned int? Can you post the actual output of the script? How did you connect the signal? Have you connected the GND's? Did you try a pull down/up resistor? Do you apply one pulse or a constant stream? There might be a problem with the synchronization at the start. So there is a lot to think about, I don't know whether we could improve
Dubai, UAE
« Reply #27 on: March 23, 2012, 01:32:44 pm » |
Hi, Sorry for the persistence, but why doesn't anyone ever use timer1 input capture for this type of thing ? I have not tried it yet myself and so if there is some fundamental reason why it wont work I would appreciate if someone could point me to it ? Thanks Duane B rcarduino.blogspot.com
« Reply #28 on: March 23, 2012, 01:52:23 pm » |
@Robtillaart yes I have used the code with unsigned int the output of the code is given below, I have applied constant pulse stream at 1Hz frequency and changed the input from 10 to 13 and then 15 microsecond. I have connected the ground as well but did not use pulldown/up resistor.
« Reply #29 on: March 24, 2012, 01:41:07 am » |
My suggestion a few posts back was exactly that!
