cologne, germany
« on: March 17, 2012, 02:34:39 pm » |
Hi, I use the attached code to realise a VU-Meter with 11 LEDs connected to a TLC59116 LED-driver. The TLC59116 is connected to the ARDUINO via i2c. I switched the i2c bus to 400kHz frquency (by replacing "#define TWI_FREQ 100000L" with "#define TWI_FREQ 400000L" in "twi.h"). The strange thing is that the higher the values are that i choose for "BRIGHTNESS" (which sets the PWM-brightness of the LEDs and is sent via i2c) the worse are the analog-values ("sample") that I get! If I activate the "delay(10);" (it has to be at least a 10ms delay) after "Set_LED_NUM_PWM(s, BRIGHTNESS);" this behaviour is gone (and the A/D-values are good)! So it seems that the i2c bus transfer affects the a/d-converter although the Atmega doc says that i2c transfer should not affect the a/d-values!? #define BRIGHTNESS 50 #define ZERO 500 #define MAXAVG 250 #define NUMSAM 100 . . int i, s, sample; unsigned long sum; . . void loop() { sum = 0; for (i = 0; i < NUMSAM; i++) { sample = analogRead(A0); if (sample > ZERO) sample -= ZERO; else sample = ZERO - sample; sum += sample; } s = sum / NUMSAM * 11 / MAXAVG; if (s > 11) s = 11; Set_LED_NUM_PWM(s, BRIGHTNESS);//delay(10); } //-------------------------------------------------------------- void Set_LED_NUM_PWM(byte LED, byte PWM) { Wire.begin(); // I2C-Start Wire.beginTransmission(B1100000); // TLC59116 Slave Adress ->C0 hex Wire.write((byte)0x82); // Startregister 02h for (i = 1; i <= LED; i++) Wire.write(PWM); //set LEDs 1 to x to BRIGHTNESS for (; i < 12; i++) Wire.write((byte)0); //switch off LEDs x+1 to 11 Wire.endTransmission(); // I2C-Stop } . .
« Last Edit: March 18, 2012, 07:04:02 am by Joegi »
Melbourne, Australia
Shannon Member
Lua rocks!
« Reply #1 on: March 17, 2012, 11:45:28 pm » |
Please edit your post, select the code, and put it between [code] ... [/code] tags. You can do that by hitting the # button above the posting area.
To change the speed all you have to do is this: Wire.begin (); TWBR = 12;
Just do Wire.begin once (in setup), not like this: void Set_LED_NUM_PWM(byte LED, byte PWM) { Wire.begin(); // I2C-Start
I switched the i2c bus to 400kHz frquency ... Doesn't seem to be much point if you have to throw in a 10 mS delay. But I suppose that's what the question is about. In any case, isn't that over-egging the pudding? For a VU-meter, your eyes don't need the extra speed do they?
So it seems that the i2c bus transfer affects the a/d-converter although the Atmega doc says that i2c transfer should not affect the a/d-values!? Well, it's not is it? You are really saying that if you send one number it works, and if you send a different number it doesn't? This sounds electrical to me. Like, the higher brightness is consuming too much power, and reducing the operation of something else.
cologne, germany
« Reply #2 on: March 18, 2012, 07:00:31 am » |
You are right, but I'm just interested why I/one need(s) the delay! Well, it's not is it? You are really saying that if you send one number it works, and if you send a different number it doesn't? This sounds electrical to me. Like, the higher brightness is consuming too much power, and reducing the operation of something else.
You might be right, I will check this! -Thanks!
cologne, germany
« Reply #3 on: March 18, 2012, 08:47:28 am » |
...You are really saying that if you send one number it works, and if you send a different number it doesn't? This sounds electrical to me. Like, the higher brightness is consuming too much power, and reducing the operation of something else.
You are right! I previously connected the complete electronics (TLC59116 + lm386 as main components) to the USB-Powered ARDUINO. Now I connected the ARDUINO to a 2,2A power supply and everything works fine, even without delay! Should have come to the reason for the problems by myself!
« Reply #4 on: April 08, 2012, 10:18:51 pm » |
hey someone can helpme please?
i dont understand in this line Wire.write((byte)0);
especify why add "((byte) 0)" what does when i add "(byte)"?
Shannon Member
Lua rocks!
« Reply #5 on: April 08, 2012, 10:21:06 pm » |
The compiler gets confused by the number 0, which might be a pointer or it might be a number. Putting (byte) there is a typecast which tells it which "version" of zero to use.
« Reply #6 on: April 08, 2012, 10:34:14 pm » |
i see thanks a lot. greetings.
« Reply #7 on: April 11, 2012, 01:46:14 pm » |
To change the speed all you have to do is this: Wire.begin (); TWBR = 12; Nick- where is this documented? I've recently posted a question in another forum about how to change the I2C bus speed.
Shannon Member
Lua rocks!
« Reply #8 on: April 11, 2012, 05:08:08 pm » |
Here: http://www.gammon.com.au/i2cBut I suppose you mean the "real" documentation? Datasheet, page 241: TWBR – TWI Bit Rate Register
TWBR selects the division factor for the bit rate generator. The bit rate generator is a frequency divider which generates the SCL clock frequency in the Master modes. In twi.c is this: TWBR = ((F_CPU / TWI_FREQ) - 16) / 2;
Where in twi.h is: #define TWI_FREQ 100000L Now normally for a CPU speed of 16000000 that will give: TWBR = ((16000000 / 100000) - 16) / 2 = 72 And from the datasheet: SCL frequency = CPU_FREQUENCY / (16 + 2(TWBR) * (PrescalerValue)) Where the prescaler happens to be 1 in this case. So substituting, we get the SCL frequency: 16000000 / (16 + 2 * 72) = 100000 But if we change TWBR to 12 we get: 16000000 / (16 + 2 * 12) = 400000 Thus, TWBR of 12 gives a clock four times as fast (400000 / 100000) compared to the default.
« Reply #9 on: April 11, 2012, 05:20:56 pm » |
Where in twi.h is: #define TWI_FREQ 100000L Now normally for a CPU speed of 16000000 that will give: TWBR = ((16000000 / 100000) - 16) / 2 = 72 And from the datasheet: SCL frequency = CPU_FREQUENCY / (16 + 2(TWBR) * (PrescalerValue)) Where the prescaler happens to be 1 in this case. So substituting, we get the SCL frequency: 16000000 / (16 + 2 * 72) = 100000 But if we change TWBR to 12 we get: 16000000 / (16 + 2 * 12) = 400000 Thus, TWBR of 12 gives a clock four times as fast (400000 / 100000) compared to the default. Thank you for all of that info. What I am looking for is- what values need to be written to TBR to select the three I2C transfer modes. You've answered that. I wonder why the Wire library wasn't written with a simple method to select the transfer mode. If I wanted to modify Wire to add such a method, where would I go to find out what the procedure is, such that my changes will be evaluated to be included on upcoming releases? Who is/are the maintainer(s) of Wire?
Shannon Member
Lua rocks!
« Reply #10 on: April 11, 2012, 05:27:23 pm » |
Wire is a core module - I suppose the Arduino team at GitHub would do that. However you might want to check out: http://dsscircuits.com/articles/arduino-i2c-master-library.htmlI haven't used it, but I believe it adds extra features.
« Reply #11 on: December 10, 2012, 01:47:07 am » |
Hi, I found something interesting when using the TLC59116. In the code above (1st post), the following line is given: Wire.beginTransmission(B1100000); // TLC59116 Slave Adress ->C0 hex However, the B1100000 is only 7 bits. If we make it 8 bits (B11000000), the TLC does not respond. Why is this?
Shannon Member
Lua rocks!
« Reply #12 on: December 10, 2012, 03:32:02 am » |
What do you mean "make it 8 bits?" The address is shifted left one by the Wire library. http://www.gammon.com.au/i2c
nr Bundaberg, Australia
« Reply #13 on: December 10, 2012, 05:26:13 am » |
I2C doesn't use the LSB for addressing, it's the R/W bit. Therefore the wire library takes your supplied address and left shifts it 1 bit, eg
address_used = your_addr << 1;
So B1100000 becomes B11000000 or B11000001 depending of it it's a read or write operation.
Similarly your B11000000 becomes B10000000 or B10000001 and you lose the upper bit.
______ Rob
« Reply #14 on: December 11, 2012, 11:26:54 am » |
@Graynomad, @Nick Gammon - Thanks! That clears things up.
