Topic: SD Card Initialization Help (Read 2909 times) previous topic - next topic
rptort
I purchased this shield:  http://iteadstudio.com/store/index.php?main_page=product_info&cPath=18&products_id=232
Right now all I'm trying to do is initialize it, and I can't seem to get it to work. I have some experience with arduino, but I am completely new to the SD stuff and reading/writing files.  This is the code I got from the arduino website:
Code: [Select]
#include <SD.h>
// SD Card Test
  Serial.begin(57600);
  SD.begin(10);
  Serial.print("Initializing SD card...");
  pinMode(10, OUTPUT);
  if (!SD.begin(10)) {
    Serial.println("initialization failed!");
    return;
  Serial.println("initialization done.");
Please help me out. Thanks.
PaulS
Quote
OK.
Quote
Please help me out.
OK. The door's over that way...
Do you have a problem that you need help with? If so, what is it?
rptort
Quote
Yes...the card won't initialize. From what I've read, if it worked, the SD.begin() would return "true" but it's returning "false"
PaulS
Code: [Select]
  SD.begin(10);
Perhaps you should investigate just how often to call SD.begin(). Hint: Once. Only once. Exactly once. Not twice. Not more than once. Not less than once.
rptort
I erased the first SD.begin and just called it ONCE in the if statement, and it still returns false. Any other ideas?
SurferTim
Does it have a formatted microSD card in the slot?
rptort
Not micro...just a regular SD card. And I followed these instruction for formatting the card on OSX:  http://arduino.cc/en/Reference/SDCardNotes
SurferTim
This is mounted on an Uno, not a Mega, correct?
Other than that, I would suspect maybe it was not formatted correctly.
rptort
Yes Uno. Are the directions from that website correct?
Also, someone told me that modern SD cards cannot be used with the Arduino software...no idea why or where they got that information, but is that a possibility?
MushfiqSarker
You need to use a SD card that is less than or equal to 2GB. Next, I could not get Mac to format properly so I did it on a PC. The formatting is different on a PC.
Follow this tutorial: http://www.ladyada.net/products/microsd/
Should be roughly the same for your application.
P18F4550
It's a bit hit and miss, sandisk 2gb micro sd seem to work for me but neither a sandisk 256 or 512mb work, also they should be formatted as FAT not FAT16
neilk
I had a lot of trouble getting an SD Card interface to work. There is a long series of postings about it on Element14
1. I assume the interface board includes 5v to 3.3v conversion on the SD Card signals? The documentation doesn't mention it.
2. I can't justify this, but maybe the Serial should be intitialised at 9600 and your serial monitor speed adjusted accordingly.
3. YES YES YES it matters which SD card you use..........I can't give you any very firm guidelines except that for me a San Disk Extreme III 1.0 GB works fine but a Transcend 2GB micro SD doesn't work. A whole host of other makes of cards won't work either (reported by other posters), especially some cheap unlabelled ones.
If you are confident that the hardware is good and your (corrected) program looks OK, keep trying different SD cards.
