Topic: Timer interrupt and PWM (Read 838 times) previous topic - next topic
Mazen21
Mar 18, 2012, 04:47 pm Last Edit: Mar 18, 2012, 04:52 pm by Mazen21 Reason: 1
Hello,
can I use analogWrite() function and Timer interrupt in the same code?
Thank you.
robtillaart
which Timer, arduino has more....
Easiest way is just to try -
What is your goal?
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
Nick Gammon
Yes.
Please post technical questions on the forum, not by personal message. Thanks!
More info:
http://www.gammon.com.au/electronics
MarkT
If you change the setup of the timer it can affect analogWrite, but you can add an interrupt handler for timers 1 and 2.
timer0 already has an interrupt handler that maintains the millis(), micros() and delay() time information, so its not wise to use this interrupt.
timer0 is used for PWM pins 5 and 6,
timer1 is used for PWM pins 9 and 10,
timer2 is used for PWM pins 11 and 3
(Arduino Mega's are different, note)
Mazen21
Thank you all for your answers.
I'm using arduino mega adk, and already using analogWrite() in pin 2 and 3.
I'm trying to do some code with a 5ms periode, The best way, I think, is using the timer interrupt, but I don't want to affect the analogWrite function.
Please if you have any links or answers send it to me.
Nick Gammon
Here is a link:
http://gammon.com.au/forum/?id=11504
More info:
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
