Topic: How to read register value from ADXL345 Eval board? (Read 7802 times) previous topic - next topic
tlslaj0417
Mar 19, 2012, 11:05 am Last Edit: Mar 19, 2012, 01:57 pm by tlslaj0417 Reason: 1
HI i am working on a project regarding using ADXL345 eval board (http://www.sparkfun.com/datasheets/Sensors/Accelerometer/ADXLEvalBoard%20User_Guide2009-09-14.pdf)
and arduino Uno and few servo motors (as outputs)
Now i met a bottleneck. The connection is direct connection from adxl 345eval board to arduino. So i need to get the value out from the register (0x32 till 0x37) in adxl345. In the first stage, i am using a LED to indicate whether i can read the register value or not..but it fail anyway. Anyone can please check the error for me?
Btw noted that direct connection from adxl345 eval board to arduino is using USB connection. Arduino Uno -> ADXL345 eval board (USB connected)
Here is my code:
Code: [Select]
int ledPin = 2;                 // LED connected to digital pin 2
#include <Wire.h>
#define DEVICE (0x53)   //define the address for DEVICE
  Wire.begin();        // join i2c bus (address optional for master)
  Serial.begin(57600);  // start serial for output
  writeTo(DEVICE, 0x2D, 0);         //here is the part that I enable the bit in the register in 2D and 2E. for INT and Power configuration
  writeTo(DEVICE, 0x2D, 16);
  writeTo(DEVICE, 0x2D, 8);
  writeTo(DEVICE, 0x2E, 128);
  writeTo(DEVICE, 0x2E, 2);
  writeTo(DEVICE, 0x2E, 1);
  pinMode(ledPin, OUTPUT);      // sets the digital pin as output
The read and write function:
Code: [Select]
void readfrom(int device, byte address)
  int temp = 0;
  Wire.beginTransmission(device); //start transmission to device
  Wire.write(address);        //sends address to read from
  Wire.endTransmission(); //end transmission
  Wire.requestFrom(device,1);
  while(Wire.available())
    int c = Wire.read();
    if (c != temp){
  digitalWrite(ledPin, HIGH);   // sets the LED on
  delay(1000);}              // waits for a second
  else{
  digitalWrite(ledPin, LOW);    // sets the LED off
  delay(1000); }                 // waits for a second
  temp =c;
  }//end while loop.
void writeTo(int device, byte address, byte val) {
   Wire.write(address);        // send register address
   Wire.write(val);        // send value to write
The loop function:
Code: [Select]
readfrom (0x53, address);
Obviously i am using I2C library....now i am wondering that will this code works if i am using USB connection?any replied is highly appreciate... :)
johnwasser
In readFrom() you have an extra Wire.beginTransmission().
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
tlslaj0417
sorry i have a mistake just now, i correct my code already. it is not extra Wire.beginTransmission(). just i forgot to end the transmission since i begin another transmission again...
Now the 1st consideration is that i am USB connection. so is that problem if i am using I2C for coding??
johnwasser
The schematic (http://www.sparkfun.com/datasheets/Sensors/Accelerometer/ADXL345_Eval_Board-v11.pdf) shows the ADXL345 is connected to A0,A1,A2,and A3 and appears to use Soft SPI.  Nothing is connected to the I2C bus so the Wire library won't help you any. Perhaps you should start with the source code from the product page (http://www.sparkfun.com/products/9814)
tlslaj0417
thanks so much...before that i noticed from schematic diagram, it seem like did not using I2C but SPI.I cant confirm..and i have no advanced people who can guide me on this...thanks...but i did try the source code but it is not arduino code...it is just normal C programming code regarding on this board..may i know what can i do on this code?and what software u can recommend me to compile it?...
sorry for all these noob question. i am a beginner by the way. Thanks
johnwasser
Some of the functions can be adapted:
Code: [Select]
#define ACCEL_CS A0
#define ACCEL_SCK A1
#define ACCEL_DI A2
#define ACCEL_DO A3
#define SELECT_ACCEL()        digitalWrite(ACCEL_CS, LOW)
#define UNSELECT_ACCEL()    digitalWrite(ACCEL_CS, HIGH)
#define CLOCK_HIGH()         digitalWrite(ACCEL_SCK, HIGH)
#define CLOCK_LOW() digitalWrite(ACCEL_SCK, LOW)
char adxl345_read(char register_address){
char read_address=0x80 | register_address;
char register_value=0;
CLOCK_HIGH();
SELECT_ACCEL(); //Lower CS pin.
for(int bit=7; bit>=0; bit--){
CLOCK_LOW();
                digitalWrite(DI, read_address & (1<<bit));
delayMicroseconds(1);
CLOCK_HIGH();
CLOCK_LOW();
CLOCK_HIGH();
register_value |= digitalRead(ADXL_DI)<<bit;
UNSELECT_ACCEL();
return register_value;
tlslaj0417
Code: [Select]
#define ACCEL_CS A0
#define ACCEL_DI A2
#define ACCEL_DO A3
CLOCK_HIGH();
CLOCK_LOW();
CLOCK_HIGH();
CLOCK_LOW();
CLOCK_HIGH();
UNSELECT_ACCEL();
from your advice, i notice that some are defined frm A0 - A3....may i know what i can use for this?is that for analog pin?because my intention is for usb connection..
i had modify my code to be like this:
setup:
Code: [Select]
int ledPin = 2;                 // LED connected to digital pin 13
int ledPin1 = 3;
int _spiPin;
byte buff[6] ;
#include <SPI.h>
#define DEVICE 0x00
#define TO_READ (6)
  SPI.begin();
  SPI.setDataMode(SPI_MODE3);
  pinMode(ledPin1, OUTPUT);  // sets the digital pin as output
loop:
Code: [Select]
  byte address = 0x32;
  int temp;
  int x,y,z;
  readfrom (DEVICE, address, TO_READ, buff);
  x = (((int)buff[1]) << 8) | buff[0];
  if (x!=temp){
  else{
  temp = x;
Code: [Select]
void readfrom(int device, byte address, int num, byte buff[])
  int temp = 0;
  address = 0x80 | address;
  if (num > 1) address = address | 0x40;
  digitalWrite(_spiPin, LOW);
  SPI.transfer(address);             // sends address to read from
  for(int i = 0; i < num; i++)
    buff[i] = SPI.transfer(0x00);
  //if (!SPI.available())digitalWrite(ledPin1, HIGH);
  digitalWrite(_spiPin, HIGH);
  SPI.transfer(address);             // send register address
  SPI.transfer(val);                // send value to write
i change it to use SPI...and why still wont work??i use a temp variable...to test whether the value is changing or not..if changing, then the LED would light up...but still fail to work on it........thanks and so appreciate your time..
johnwasser
See reply #3.  The accelerometer is NOT connected to the hardware SPI pins.  It is connected to A0-A3 (Pins 14-17).
tlslaj0417
A0-A3 u mean is ADC0 till ADC3??(pin 23-26)...because pins 14-17 is for SPI right?....correct me if i am wrong...thanks
johnwasser
ARDUINO pins 14-17 a.k.a. A0-A3.  Yes, they are pins 23-26 on the ATmega chip.
Hardware SPI is on ARDUINO pins 10-13 which are pins 16-19 on the ATmega.
If you are going to use the Arduino libraries you should probably get used to calling the pins by their Arduino numbers to avoid confusion.  You can learn more about the naming here: https://spreadsheets.google.com/spreadsheet/pub?key=0AtfNMvfWhA_ccnRId19SNmVWTDE0MEtTOV9HOEdQa0E&gid=0
tlslaj0417
thanks for good reference..i will refer it when i calling the pins. and now i use the code u provided to me. as you said:
#define ACCEL_CS   A0
#define ACCEL_DI           A2
#define ACCEL_DO   A3
then which pins i should connect to with all these 4 pins?or because of soft connection. i no need to connect it through any hardware?i just define it with these four pins?
tlslaj0417
hi John....sorry for use up your time for this. In the progress i edit my code till like this:
setup:
Code: [Select]
char adxl345_read(char address);
int ledPin = 2;
#define ACCEL_CS A0
#define ACCEL_DI A2
#define ACCEL_DO A3
#define DATAX0 0x32 //X-Axis Data 0
#define DATAX1 0x33 //X-Axis Data 1
#define DATAY0 0x34 //Y-Axis Data 0
#define DATAY1 0x35 //Y-Axis Data 1
#define DATAZ0 0x36 //Z-Axis Data 0
#define DATAZ1 0x37 //Z-Axis Data 1
#include <SPI.h>
void setup(){
  SPI.begin();
read function:
Code: [Select]
        char temp = 0;
CLOCK_HIGH();
        if (register_value!=temp)
        else{
CLOCK_LOW();
                digitalWrite(ACCEL_DI, read_address & (1<<bit));
CLOCK_HIGH();
CLOCK_LOW();
CLOCK_HIGH();
register_value |= digitalRead(ACCEL_DI)<<bit;
UNSELECT_ACCEL();
        temp = register_value;
Loop:
Code: [Select]
void loop(){
  adxl345_read(DATAX0);
same i use ledpin to indicate the availability of the register_value....but still no given any response....following the reference that u gave:
i connect the A0-A3 to pin 11-13 (while pin 10 is not for SPI right?)...so is there any error?
Again, thanks for sparing your time on me. Appreciate so much :)
johnwasser
Probably need:
Code: [Select]
    pinMode(ACCEL_CS, OUTPUT);
    pinMode(ACCEL_SCK, OUTPUT);
    pinMode(ACCEL_DI, OUTPUT);
    pinMode(ACCEL_DO, INPUT);
You don't seem to include any output in your sketch so I don't understand how you detect if it is working or not.
You can remove references to the SPI library since the adxl345_read() function does software SPI.
tlslaj0417
#13
Mar 22, 2012, 02:33 pm Last Edit: Mar 22, 2012, 03:00 pm by tlslaj0417 Reason: 1
Probably need:
Code: [Select]
while i am testing my circuit...would u mind to tell me what is the exact of software SPI and hardware SPI???software is that mean that is not exact hardware connection???..thanks
Plus: i do output to test it is working or not..i test with light up a LED...:)
i test it if the register value change all the time thats mean register != temp (not equal to the value before) then the LED is light up.
Code: [Select]
tlslaj0417
Hi, i follow your advise, add all these
but still no giving any output.... :~...really stuck now...
