« on: March 19, 2012, 05:05:26 am » |
HI i am working on a project regarding using ADXL345 eval board ( http://www.sparkfun.com/datasheets/Sensors/Accelerometer/ADXLEvalBoard%20User_Guide2009-09-14.pdf) and arduino Uno and few servo motors (as outputs) Now i met a bottleneck. The connection is direct connection from adxl 345eval board to arduino. So i need to get the value out from the register (0x32 till 0x37) in adxl345. In the first stage, i am using a LED to indicate whether i can read the register value or not..but it fail anyway. Anyone can please check the error for me? Btw noted that direct connection from adxl345 eval board to arduino is using USB connection. Arduino Uno -> ADXL345 eval board (USB connected) Here is my code: int ledPin = 2; // LED connected to digital pin 2 #include <Wire.h> #define DEVICE (0x53) //define the address for DEVICE
void setup() { Wire.begin(); // join i2c bus (address optional for master) Serial.begin(57600); // start serial for output writeTo(DEVICE, 0x2D, 0); //here is the part that I enable the bit in the register in 2D and 2E. for INT and Power configuration writeTo(DEVICE, 0x2D, 16); writeTo(DEVICE, 0x2D, 8); writeTo(DEVICE, 0x2E, 128); writeTo(DEVICE, 0x2E, 2); writeTo(DEVICE, 0x2E, 1); pinMode(ledPin, OUTPUT); // sets the digital pin as output }
The read and write function: void readfrom(int device, byte address) { int temp = 0; Wire.beginTransmission(device); //start transmission to device Wire.write(address); //sends address to read from Wire.endTransmission(); //end transmission
Wire.beginTransmission(device); Wire.requestFrom(device,1); while(Wire.available()) { int c = Wire.read(); if (c != temp){ digitalWrite(ledPin, HIGH); // sets the LED on delay(1000);} // waits for a second else{ digitalWrite(ledPin, LOW); // sets the LED off delay(1000); } // waits for a second temp =c; }//end while loop. Wire.endTransmission(); //end transmission }
void writeTo(int device, byte address, byte val) { Wire.beginTransmission(device); //start transmission to device Wire.write(address); // send register address Wire.write(val); // send value to write Wire.endTransmission(); //end transmission }
The loop function: readfrom (0x53, address);
Obviously i am using I2C library....now i am wondering that will this code works if i am using USB connection?any replied is highly appreciate...
« Last Edit: March 19, 2012, 07:57:11 am by tlslaj0417 »
Massachusetts, USA
« Reply #1 on: March 19, 2012, 07:34:52 am » |
In readFrom() you have an extra Wire.beginTransmission().
« Reply #2 on: March 19, 2012, 07:58:49 am » |
sorry i have a mistake just now, i correct my code already. it is not extra Wire.beginTransmission(). just i forgot to end the transmission since i begin another transmission again... Now the 1st consideration is that i am USB connection. so is that problem if i am using I2C for coding??
« Reply #4 on: March 19, 2012, 10:16:12 am » |
thanks so much...before that i noticed from schematic diagram, it seem like did not using I2C but SPI.I cant confirm..and i have no advanced people who can guide me on this...thanks...but i did try the source code but it is not arduino code...it is just normal C programming code regarding on this board..may i know what can i do on this code?and what software u can recommend me to compile it?... sorry for all these noob question. i am a beginner by the way. Thanks
Massachusetts, USA
« Reply #5 on: March 19, 2012, 11:56:56 am » |
Some of the functions can be adapted: #define ACCEL_CS A0 #define ACCEL_SCK A1 #define ACCEL_DI A2 #define ACCEL_DO A3
#define SELECT_ACCEL() digitalWrite(ACCEL_CS, LOW) #define UNSELECT_ACCEL() digitalWrite(ACCEL_CS, HIGH)
#define CLOCK_HIGH() digitalWrite(ACCEL_SCK, HIGH) #define CLOCK_LOW() digitalWrite(ACCEL_SCK, LOW)
char adxl345_read(char register_address){ char read_address=0x80 | register_address; char register_value=0; CLOCK_HIGH(); SELECT_ACCEL(); //Lower CS pin. for(int bit=7; bit>=0; bit--){ CLOCK_LOW(); digitalWrite(DI, read_address & (1<<bit)); delayMicroseconds(1); CLOCK_HIGH(); delayMicroseconds(1); } for(int bit=7; bit>=0; bit--){ CLOCK_LOW(); delayMicroseconds(1); CLOCK_HIGH(); delayMicroseconds(1); register_value |= digitalRead(ADXL_DI)<<bit; } UNSELECT_ACCEL(); return register_value; }
« Reply #6 on: March 20, 2012, 04:31:11 am » |
from your advice, i notice that some are defined frm A0 - A3....may i know what i can use for this?is that for analog pin?because my intention is for usb connection.. i had modify my code to be like this: setup: int ledPin = 2; // LED connected to digital pin 13 int ledPin1 = 3; int _spiPin; byte buff[6] ; #include <SPI.h> #define DEVICE 0x00 #define TO_READ (6)
void setup() { SPI.begin(); SPI.setDataMode(SPI_MODE3); Serial.begin(57600); // start serial for output writeTo(DEVICE, 0x2D, 0); writeTo(DEVICE, 0x2D, 16); writeTo(DEVICE, 0x2D, 8); writeTo(DEVICE, 0x2E, 128); writeTo(DEVICE, 0x2E, 2); writeTo(DEVICE, 0x2E, 1); pinMode(ledPin, OUTPUT); pinMode(ledPin1, OUTPUT); // sets the digital pin as output }
loop: void loop() { byte address = 0x32; int temp; int x,y,z; readfrom (DEVICE, address, TO_READ, buff); x = (((int)buff[1]) << 8) | buff[0]; if (x!=temp){ digitalWrite(ledPin, HIGH); // sets the LED on delay(1000);} // waits for a second else{ digitalWrite(ledPin, LOW); // sets the LED off delay(1000); } // waits for a second temp = x; }
read and write function: void readfrom(int device, byte address, int num, byte buff[]) { int temp = 0; address = 0x80 | address; if (num > 1) address = address | 0x40; digitalWrite(_spiPin, LOW); SPI.transfer(address); // sends address to read from for(int i = 0; i < num; i++) { buff[i] = SPI.transfer(0x00); } //if (!SPI.available())digitalWrite(ledPin1, HIGH); digitalWrite(_spiPin, HIGH); }
void writeTo(int device, byte address, byte val) { digitalWrite(_spiPin, LOW); SPI.transfer(address); // send register address SPI.transfer(val); // send value to write digitalWrite(_spiPin, HIGH); }
i change it to use SPI...and why still wont work??i use a temp variable...to test whether the value is changing or not..if changing, then the LED would light up...but still fail to work on it........thanks and so appreciate your time..
Massachusetts, USA
« Reply #7 on: March 20, 2012, 07:57:31 am » |
See reply #3. The accelerometer is NOT connected to the hardware SPI pins. It is connected to A0-A3 (Pins 14-17).
« Reply #8 on: March 20, 2012, 08:56:11 am » |
See reply #3. The accelerometer is NOT connected to the hardware SPI pins. It is connected to A0-A3 (Pins 14-17). A0-A3 u mean is ADC0 till ADC3??(pin 23-26)...because pins 14-17 is for SPI right?....correct me if i am wrong...thanks
Massachusetts, USA
« Reply #9 on: March 20, 2012, 10:22:24 am » |
ARDUINO pins 14-17 a.k.a. A0-A3. Yes, they are pins 23-26 on the ATmega chip. Hardware SPI is on ARDUINO pins 10-13 which are pins 16-19 on the ATmega. If you are going to use the Arduino libraries you should probably get used to calling the pins by their Arduino numbers to avoid confusion. You can learn more about the naming here: https://spreadsheets.google.com/spreadsheet/pub?key=0AtfNMvfWhA_ccnRId19SNmVWTDE0MEtTOV9HOEdQa0E&gid=0
« Reply #10 on: March 20, 2012, 10:49:50 am » |
ARDUINO pins 14-17 a.k.a. A0-A3. Yes, they are pins 23-26 on the ATmega chip. Hardware SPI is on ARDUINO pins 10-13 which are pins 16-19 on the ATmega. If you are going to use the Arduino libraries you should probably get used to calling the pins by their Arduino numbers to avoid confusion. You can learn more about the naming here: https://spreadsheets.google.com/spreadsheet/pub?key=0AtfNMvfWhA_ccnRId19SNmVWTDE0MEtTOV9HOEdQa0E&gid=0thanks for good reference..i will refer it when i calling the pins. and now i use the code u provided to me. as you said: #define ACCEL_CS A0 #define ACCEL_SCK A1 #define ACCEL_DI A2 #define ACCEL_DO A3 then which pins i should connect to with all these 4 pins?or because of soft connection. i no need to connect it through any hardware?i just define it with these four pins?
« Reply #11 on: March 20, 2012, 11:49:09 am » |
hi John....sorry for use up your time for this. In the progress i edit my code till like this: setup: char adxl345_read(char address); int ledPin = 2; #define ACCEL_CS A0 #define ACCEL_SCK A1 #define ACCEL_DI A2 #define ACCEL_DO A3 #define DATAX0 0x32 //X-Axis Data 0 #define DATAX1 0x33 //X-Axis Data 1 #define DATAY0 0x34 //Y-Axis Data 0 #define DATAY1 0x35 //Y-Axis Data 1 #define DATAZ0 0x36 //Z-Axis Data 0 #define DATAZ1 0x37 //Z-Axis Data 1 #define SELECT_ACCEL() digitalWrite(ACCEL_CS, LOW) #define UNSELECT_ACCEL() digitalWrite(ACCEL_CS, HIGH)
#define CLOCK_HIGH() digitalWrite(ACCEL_SCK, HIGH) #define CLOCK_LOW() digitalWrite(ACCEL_SCK, LOW) #include <SPI.h>
void setup(){ SPI.begin(); Serial.begin(57600); pinMode(ledPin, OUTPUT); }
read function: char adxl345_read(char register_address){ char read_address=0x80 | register_address; char register_value=0; char temp = 0; CLOCK_HIGH(); SELECT_ACCEL(); //Lower CS pin. if (register_value!=temp) { digitalWrite(ledPin, HIGH); // sets the LED on delay(1000); } else{ digitalWrite(ledPin, LOW); // sets the LED off delay(1000); } // waits for a second
for(int bit=7; bit>=0; bit--){ CLOCK_LOW(); digitalWrite(ACCEL_DI, read_address & (1<<bit)); delayMicroseconds(1); CLOCK_HIGH(); delayMicroseconds(1); } for(int bit=7; bit>=0; bit--){ CLOCK_LOW(); delayMicroseconds(1); CLOCK_HIGH(); delayMicroseconds(1); register_value |= digitalRead(ACCEL_DI)<<bit; } UNSELECT_ACCEL(); temp = register_value; return register_value; }
Loop: void loop(){ adxl345_read(DATAX0); }
same i use ledpin to indicate the availability of the register_value....but still no given any response....following the reference that u gave: https://spreadsheets.google.com/spreadsheet/pub?key=0AtfNMvfWhA_ccnRId19SNmVWTDE0MEtTOV9HOEdQa0E&gid=0i connect the A0-A3 to pin 11-13 (while pin 10 is not for SPI right?)...so is there any error? Again, thanks for sparing your time on me. Appreciate so much
Massachusetts, USA
« Reply #12 on: March 20, 2012, 12:01:57 pm » |
Probably need: pinMode(ACCEL_CS, OUTPUT); pinMode(ACCEL_SCK, OUTPUT); pinMode(ACCEL_DI, OUTPUT); pinMode(ACCEL_DO, INPUT);
You don't seem to include any output in your sketch so I don't understand how you detect if it is working or not. You can remove references to the SPI library since the adxl345_read() function does software SPI.
« Reply #13 on: March 22, 2012, 08:33:11 am » |
You don't seem to include any output in your sketch so I don't understand how you detect if it is working or not. You can remove references to the SPI library since the adxl345_read() function does software SPI. while i am testing my circuit...would u mind to tell me what is the exact of software SPI and hardware SPI???software is that mean that is not exact hardware connection???..thanks Plus: i do output to test it is working or not..i test with light up a LED...  i test it if the register value change all the time thats mean register != temp (not equal to the value before) then the LED is light up. if (register_value!=temp) { digitalWrite(ledPin, HIGH); // sets the LED on delay(1000); }
« Last Edit: March 22, 2012, 09:00:33 am by tlslaj0417 »
« Reply #14 on: March 22, 2012, 09:02:29 am » |
Hi, i follow your advise, add all these pinMode(ACCEL_CS, OUTPUT); pinMode(ACCEL_SCK, OUTPUT); pinMode(ACCEL_DI, OUTPUT); pinMode(ACCEL_DO, INPUT); but still no giving any output....  ...really stuck now...
