Topic: Arduino/GSM Communication - Capturing data (Read 4278 times) previous topic - next topic
wicket
Mar 19, 2012, 03:21 pm Last Edit: Mar 19, 2012, 03:29 pm by wicket Reason: 1
Hi!
I've successfully build a project like this - Old Sony Ericsson phone as GSM shield.
My goal is to send an SMS both ways - from my phone to Sony Ericsson, which is connected to Arduino and the other way around. And this works with no problem but I get stuck, when I have to read and further interprate incoming AT responses, so that I could control some relays or sth based on SMS content.
For example let's say I'm communicating through putty:
I make a call from my phone to SE and get a response "RING".
Now, when doing the same thing through Arduino, I'd have to store this "READ" into some string (?) variable, but can't figure out the way to do it. So further on I could do something like:
Code: [Select]
if (input == "RING") {
    digitalWrite...
The code I'm using atm is:
Code: [Select]
#include <SoftwareSerial.h>
// phone connected to pins 2,3 so it doesn't interfere with arduino
SoftwareSerial phone(2,3);
void setup ()
 // serial connection
 Serial.println("Arduino connected.");
 // phone serial connection
 phone.begin(9600);
 Serial.println("Ericsson T610 connected.");
 // za?etna inicializacija mobitela
 Serial.println("Initialization...");
 delay(100);
 phone.println("AT+CPMS=\"ME\",\"ME\""); // internal phone storage use
 phone.println("AT+CMGF=0"); // PDU mode
 phone.println("AT+CNMI=2,3,0,0,0"); // transfering incoming data directly to terminal
 Serial.println("Done.");
 phone.flush();
void loop ()
 // read phone response
 if (phone.available() > 0)
   char sms = phone.read();
   Serial.print(sms);
This way I get "RING" response, but it's not stored anywhere since it takes each char seperately.
Could I somehow use serialEvent()? I've tried, but no success.
Thanks.
mkwired
Use one or more of the Stream member functions.
http://arduino.cc/en/Reference/Stream
ea123
you have to build the string one character at a time by storing them in a temporary buffer. What you need to know is the end of transmission character (probably a new-line). Try a function like this:
Code: [Select]
/* Get a string from serial port until newline character */
void getSerialInput(char *buff, int buffSize )
   int i = 0;
   do
      while( !Serial.available() );
      if( (buff[i] = (char) Serial.read()) == 13 )
      i++;
   while( i < buffSize-1);
   buff[i] = '\0';
usage:
Code: [Select]
   const int N_CHAR = 16;
   char tmp[N_CHAR];
   getSerialInput(tmp, N_CHAR);
Note that the function blocks the loop execution until an end of line is received.
mkwired
#3
Mar 19, 2012, 04:27 pm Last Edit: Mar 19, 2012, 04:34 pm by mkwired Reason: 1
ea123, here's the same logic except that it doesn't block.
Code: [Select]
if (phone.available() > 0 && phone.find("\n"))
wicket
#4
Mar 19, 2012, 06:14 pm Last Edit: Mar 19, 2012, 06:19 pm by wicket Reason: 1
ea123, I tried your code and I get RING written, when i call tmp variable.
How do I make a condition now, sth like if (tmp == "RING") ... ?
Also, could I use serialEvent() similar way as used in this example:
Code: [Select]
  Serial Event example
When new serial data arrives, this sketch adds it to a String.
When a newline is received, the loop prints the string and
clears it.
A good test for this is to try it with a GPS receiver
that sends out NMEA 0183 sentences.
Created 9 May 2011
by Tom Igoe
This example code is in the public domain.
http://www.arduino.cc/en/Tutorial/SerialEvent
String inputString = "";         // a string to hold incoming data
boolean stringComplete = false;  // whether the string is complete
  // initialize serial:
  // reserve 200 bytes for the inputString:
  inputString.reserve(200);
  // print the string when a newline arrives:
  if (stringComplete) {
    Serial.println(inputString);
    // clear the string:
    inputString = "";
  SerialEvent occurs whenever a new data comes in the
hardware serial RX.  This routine is run between each
time loop() runs, so using delay inside loop can delay
response.  Multiple bytes of data may be available.
void serialEvent() {
  while (Serial.available()) {
    // get the new byte:
    char inChar = (char)Serial.read();
    // add it to the inputString:
    inputString += inChar;
    // if the incoming character is a newline, set a flag
    // so the main loop can do something about it:
    if (inChar == '\n') {
      stringComplete = true;
ea123
to compare two strings:
Code: [Select]
#include <string.h>
   if( !strcmp( tmp, "RING" ) )
The serialEvent function is simply called after loop() when a data is available on the receive buffer, so you can use it in the same way: save each received character in a char array and set to TRUE the "stringComplete" flag  when the end of string is detected.
wicket
Ok, that works, now I have another problem.
I'm using 3 SMS commands: "LED ON" (turns the led on), "LED OFF" (turns the led off), "LED STATE" (tells me back the current state of the led).
When I send it "LED STATE", I get the reply, but it's always telling me that led is off, even if it's actually on. Am I not storing it's state in a variable properly, is it something wrong with those 2 if statement that include state == x, or why is this code (below) not working?
Please, help.
Code: [Select]
SoftwareSerial phone(2,3);       // phone connected to pins 2,3
const int ledPin = 13;
String input;
void setup ()
 // LED pin
 pinMode(ledPin, OUTPUT);
 digitalWrite(ledPin, LOW);
 // serial comm
 delay(200);
 //phone comm
 phone.begin(9600);
 // phone init
 Serial.println("Begin init...");
 phone.println("AT+CPMS=\"ME\",\"ME\""); // phone memory
 delay(2000);
 phone.println("AT+CMGF=0");             // PDU type
 delay(2000);
 phone.println("AT+CNMI=2,3,0,0,0");     // send data to terminal
 delay(2000);
 phone.flush();
 Serial.println("End of init, waiting for SMS...");
void loop ()
 while (phone.available() == 0);
 do
   input += String((char)phone.read());
 while (phone.available() > 0);
 Serial.println(input);                  // phone answer to commands
 boolean state = digitalRead(ledPin);   // reading the current state of the LED
 int index1 = input.indexOf("CC2211");
 int index2 = input.length() - 2;
 if (input.substring(index1,index2) == "CC2211645D329F50") digitalWrite(ledPin, HIGH);  // "LED ON"
 if (input.substring(index1,index2) == "CC221194D42E994F28") digitalWrite(ledPin, LOW); // "LED OFF"
 if ((input.substring(index1,index2) == "CC221134A5069DCA22") && (state == 1))         // "LED STATE" case: high
   phone.println("AT+CMGD=1");             // delete old SMS on memory place 0
   delay(2000);
   phone.println("AT+CMGW=37");            // write SMS in memory
   delay(2000);
   phone.print("07918346011033F301000B918336XXXXXXXX00001B4139B99E76BF7520669108529741F635FB0D67ABCBEEB00B"); // SMS in PDU
   delay(3000);
   phone.write(26);                        // Ctrl + Z
   delay(2000);
   phone.println("AT+CMSS=1");             // send SMS
   delay(2000);
 if ((input.substring(index1,index2) == "CC221134A5069DCA22") && (state == 0))         // "LED STATE" case: low
   delay(2000);
   phone.println("AT+CMGW=38");            // write SMS in memory
   delay(2000);
   phone.print("07918346011033F301000B918336XXXXXXXX00001C4139B99E76BF752066910852974169FD9AFD86B3D56577D805");
   delay(3000);
   delay(2000);
   delay(2000);
 input = "";                               // reset input variable
PS: I have no problems turning led on and off.
PaulS
Reading an output pin is not the best way to determine if the pin is on or off. You set the pin state. Remember what you set it to.
Code: [Select]
  do
Horridly inefficient to create an instance of the String class, then invoke the copy constructor and the append operator and the String destructor, to append a String, when the append operator knows how to append a char.
wicket
Tnx Paul, I didn't know I can't read the output pin. It works now.
About that String fail - I know it's a disaster, but it is the only way I could make it read and print out phones response. I tried everything suggested in recent replys, but could't get it to work OK.
Could you be a bit more specific with your proposed solution?
PaulS
phone is an instance of SoftwareSerial. SoftwareSerial::read() returns an int. But, the reason for returning an int is so that it can return an error condition. By calling phone.available() first (you aren't, by the way), you ensure that read() never needs to return an error condition. Therefore, the real data returned by read() can go in a byte or a char, whichever is appropriate for the type of data being read.
Code: [Select]
while(phone.available() > 0)
   char aChar = phone.read();
   input += aChar;
Notice that there is a big difference between while and do/while. Read up on the differences, if you need to.
wicket
Corrected.
Unfortunately, I got excited too fast. I'm still getting random response when asking about led status...
Code: [Select]
String input;
int state = 0;        // flag LED indicator
void setup ()
  // LED pin
  // serial comm
  delay(200);
  //phone comm
  phone.begin(9600);
  // phone init
  delay(2000);
  delay(2000);
  delay(2000);
  phone.flush();
void loop ()
    input += aChar;
     state = 1;   // set flag to "1"
     state = 0;  // set flag to "0"
    phone.println("AT+CMGD=1");             // delete old SMS on memory place 1
    delay(2000);
    delay(2000);
    delay(3000);
    delay(2000);
    delay(2000);
    delay(2000);
    delay(2000);
    delay(3000);
    delay(2000);
    delay(2000);
PaulS
Code: [Select]
If input does not contain "CC2211", what will be the value in index1?
Code: [Select]
If input currently only contains 1 character (which is VERY possible), what will be in index2?
Code: [Select]
Do you suppose that it is smart to call substring with negative values for the start position or length?
If input IS "CC221134A5069DCA22", you have a lot of duplicate code. The tests involving this value should be nested, to reduce the amount of duplicate code:
Code: [Select]
if(input.substring(index1,index2) == "CC221134A5069DCA22")
   // Do some common stuff
   if(state == 1)
      // Do state 1 stuff
   else if(state == 0)
      // Do state 0 stuff
      // Do unknown state stuff
   // More common stuff
You have not shown us the output you are seeing on the Serial Monitor, so it's really hard to help you.
Code: [Select]
The comment is incorrect. The stuff in input is potentially only PART OF the phone's answer. Printing some identifying/bracketing information is usually quite useful.
Code: [Select]
Serial.print("Phone's (partial) response: [");
Serial.print(input);
Serial.println("]");
wicket
#12
Mar 27, 2012, 05:25 pm Last Edit: Mar 27, 2012, 05:31 pm by wicket Reason: 1
OK, I've taken some of your ideas into consideration and I've come up with this so far.
Problems remains the same - I can turn led on/off, but I always get the same response when asking about it's current state.
Code: [Select]
const int ledPin = 13;           // LED on pin 13
String input;                    // phones response is saved into this string
int state = 0;                   // current state of the LED
void setup ()
 // Serial connection
 delay(200);
 // phone connection
 phone.begin(9600);
 // LED pin init
 // phone init
 Serial.println("Start of phone init...");
 phone.println("AT+CPMS=\"ME\",\"ME\",\"ME\"");   // phone memory used for SMS storage
 delay(2000);
 phone.println("AT+CNMI=2,3,0,0,0");              // forward all received stuff into terminal window
 delay(2000);
 phone.flush();
 Serial.println("End of init. Waiting for command SMS...\n");
void loop ()
 while (phone.available() == 0);         // waiting for phones response
 while (phone.available() > 0)           // read incoming data from phone and save it into input string
   input += aChar;
 // phones (partial) response displayed in serial window
 // "decoding" received SMS
 // if received SMS "LED ON" turn on LED
 if (input.substring(index1,index2) == "CC2211F47402")
   state = 1;
 // if received SMS "LED OFF" turn off LED
 else if (input.substring(index1,index2) == "CC2211F4341A01")
   state = 0;
 // if received SMS "LED STATE" check for LED state and reply with SMS
 else if (input.substring(index1,index2) == "CC221134A506A945")
   phone.println("AT+CMGD=1");               // delete old SMS in memory place 1
   delay(2000);
   if (state == 1)                           // if LED is turned ON
     phone.println("AT+CMGW=36");            // SMS length in octets (PDU)
     delay(2000);
     phone.print("07918346011033F301000B918356613xxxxx00001A4139B99E76BF75206691084ACF41F4BADC5D26839E4E17"); // SMS "Arduino: LED is ON." in PDU format
     delay(3000);
   else if (state == 0)                      // if LED is turned OFF
     phone.println("AT+CMGW=37");            // SMS length in octets (PDU)
     delay(2000);
     phone.print("07918346011033F301000B918356613xxxxx00001B4139B99E76BF75206691084ACF41F4BADC5D26839E46A30B"); // SMS "Arduino: LED is OFF." in PDU format
     delay(3000);
   delay(2000);
   phone.println("AT+CMSS=1");               // send SMS stored in memory place 1
   delay(2000);
 input = "";                                 // reset input string
Image shows, how the conversation is made.
Yellow font shows what's happening with LED.
Step 1&2: I send LED STATE and get reply: LED is turned OFF.
Step 3: I send LED ON and led turns on.
Step 4&5: I send LED STATE again and get the same reply as before, evendo variable state changed it's value to 1 (I've checked).
So I definitely step into other if loop. This could only mean, something unexpected is going on inside the phone itself. Now I've noticed that I'm not getting a response from AT+CMGD=1 command back into Serial, but it should respond OK. This is supposed to delete old SMS in memory place #1, so next time I could save another content in that same place. Also a part of PDU message, which appears after > is missing, but that doesn't matter since I do get the SMS with full content back. I have no idea why isn't it working, since I have no problem using the same series of AT commands from terminal (putty) directly.
Serial window:
zember
First of all: Why do you use PDU mode??
SE T610 supports text mode.
To start text mode, send: AT+CMGF=1
And then to send SMS:
AT+CMGS="<phone number>"
This is sample SMS content<Ctrl+z>
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
