Pages: 1 [2]   Go Down
Author Topic: Serial print of arrays  (Read 579 times)
I believe Mikal Hart's Flash library supports storing float arrays in Flash memory:
http://arduiniana.org/libraries/flash/
So,if I got you right, I should save my Theta as a some compatible type in Flash, in.e. signed long, and after reading convert it to float. But how to save my values in range from 0 to 1 from truncating and rounding? Maybe to multiply them with in.e. 100000 before saving? Ok, this could work.. thanks man
UK
Not sure what you mean here.
What's wrong with
PROGMEM float Theta [1001...whatever] = {3.45,6.27};
well, libraty pgmspace.h does not support float type. And I could not find any function that reads it properly.. So i thought, before saving, adapt my data to intiger type, and the return it float, after reading.
UK
So, read it back as a type you can read, and cast the result to float.
OK, just to inform you guys, I finally made it. Seems like there is support for storing float type data in Flash. All you have to do is store it:
PROGMEM float Theta[]={1,2,3,4...};
and read it out:
float a;
a =(float) pgm_read_float(&Theta[i]); // i can be some constant or counter
Thank you all, cheers.
« Last Edit: March 20, 2012, 04:41:06 pm by Pero_2912 » Logged
Pages: 1 [2]   Go Up
