Topic: Read this before posting a programming question ... (Read 209334 times) previous topic - next topic
PeterH
When posting code, rather than posting a complex sketch, aim to post the simplest sketch that shows the problem. As a courtesy to the people trying to help you, make sure the sketch actually compiles and demonstrates the problem before you post it, and format the code.
liuzengqiang
Nice post Nick! My suggestion: Add number to each bold title so I can tell a noob to say read number 6 on the sticky thread about "getting help" and follow the "posting code" suggestion. Or simply issue a 6-5.
Serial LCD keypad panel,phi_prompt user interface library,SDI-12 USB Adapter
nickgammon
Added this suggestion to the "how to post" list.
Now numbered each section.
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
Sacman
Jeremy Blum's tutorial series on Youtube is the single most helpful resource for anyone just getting started using the Arduino.
I watched all 14 videos twice before I even received my Arduino in the mail. I think everyone should be required to watch those videos before they post a thing:
http://www.youtube.com/playlist?list=PLA567CE235D39FA84&feature=plcp
maniacbug
Here's my contribution, a collection of common beginner trouble spots: http://www.cprogramming.com/tutorial/common.html
nickgammon
Thanks! And I'll add the C++ FAQ Lite:
http://www.parashift.com/c++-faq-lite/
JChristensen
I see there is also: http://www.parashift.com/c++-faq/
The few pages I checked appear identical between the two.  :~
Tom Carpenter
Another thing, if the code being posted is not properly indented, it is a pain to follow. Press "tools->auto format" in the IDE first as it makes it far easier to understand :D
~Tom~
dkl65
In section 5 of your link, it says that you have to declare the functions first. Why don't I have to do that in Arduino?
AWOL
#25
Jul 04, 2012, 06:51 pm Last Edit: Jul 04, 2012, 06:56 pm by AWOL Reason: 1
Because the Arduino pre-preprocessing does it for you, most of the time.
Sometimes, like functions with references as parameters, it doesn't work too well.
"Pete, it's a fool (who) looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
I speak for myself, not Arduino.
dkl65
I once did this:
Code: [Select]
void timer(unsigned long interval, void (*g)()){
and got compiler errors unless I write the function before it is used.
Coding Badly
Quote
Post your code!
Please change that to "Post your complete sketch!"  Too many people post snippets of code that have nothing to do with the actual problem.
nickgammon
Done. I added a clarification that a sketch is a program/code.
