Topic: bootloader callable from sketch? (Read 6746 times) previous topic - next topic
Claghorn
I don't suppose the standard bootloader can be directly entered from code in a sketch without resetting can it? Some magic address I could jump to perhaps? I'd like to (eventually) be able to update the sketch via bluetooth simply by sending a special command to the sketch, then invoking avrdude to do the actual upload. The timing is such on my Uno R3 with a bluetooth shield that by the time the bluetooth is talking again after a reset, the bootloader has already jumped back to my sketch, so there is never a timing window where it is possible to do an upload.
http://home.comcast.net/~tomhorsley/hardware/arduino/arduino.html
magagna
Sort of.
You can do this
Code: [Select]
void software_Reset() // Restarts program from beginning but does not reset the peripherals and registers
asm volatile ("  jmp 0");
but you'll have to manually take care of resetting your hardware.
Google "arduino software reset" for more details than you probably want to know.....
Good luck!
http://en.wiktionary.org/wiki/magagna <-- My last name.  Pretty apt.
westfw
Except the bootloader is NOT at location 0.  It's off at 0x7e00 (chip dependent), and it has built-in assumptions that will not be true if it is called from a sketch (all interrupts off, all IO devices in their reset configuration, etc...)
The preferred way to cause a reset from software is to turn on the watchdog timer and let THAT reset the chip, except that this will normally skip the bootloader when optiboot is used, because it is part of the sequence used to start the sketch...
magagna
My mistake -- I misread the post. Apologies.
Chris
westfw
It would probably be easier to create a custom bootloader with a longer timeout.  Up to 8s is an easy change.
Claghorn
Nah, that's what I'm doing now. Apparently doing the jmp 0 enters code that screws around with enough of the registers somehow that the bluetooth gets disconnected temporarily and that temporary is long enough to prevent the upload from working. In fact, I played around with binary searching the time delay and right at 73346 microseconds the error I get switches from ioctl errors on /dev/rfcomm0 to arduino not responding to avrdude :-). I need some way to jump to the bootloader code and have it use the existing rfcomm connection to do the upload. Either that, or a custom bootloader with a longer delay.
smeezekitty
Interrupts are easily disabled with
Code: [Select]
asm("cli");
The pins can easily all be reset to inputs as well.
Still, the effect is probably not what you desire.
Avoid throwing electronics out as you or someone else might need them for parts or use.
Solid state rectifiers are the only REAL rectifiers.
Resistors for LEDS!
SirNickity
Any reason to use the asm call rather than plain cli() or noInterrupts()?
tim7
Which bluetooth shield & module are you using?  I'm wondering why the bluetooth connection is being interrupted after a reset.  I'm not so familiar with Arduino + BT, but I'm doing remote sketch uploads via an Xbee link without any trouble.  The XBee radio modules transmit the reset signal to the Arduino, but are not reset themselves so there is no disruption to the communication link.
smeezekitty
No. But I am more familiar with using it in asm tags.
Resistors for LEDS!
Claghorn
It is an ITead studio bluetooth shield v2.2. I also wonder a bit why the jmp 0 seems to reset it, but it sure seems to, the /dev/rfcomm0 device gets nothing but ioctl errors right after the reset. Anyway, I'm resigned to just using USB during development. Its not that big a deal, just a bit irritating. If I get irritated enough maybe I'll build a parallel programmer and see if I can up the delay time in the bootloader.
tim7
That's odd.  The schematics seem to show the BT-module's reset clearly separated from the Arduino's reset circuitry.  Could it be trying to auto-baud?  Do you change bit-rates at any time?
As for running the bootloader... since you're using an Uno the bootloader will only try to upload a new sketch after an external reset (any other type of reset will cause it to restart the sketch immediately).  That means pulling the ATmega328's reset pin down to ground -- you can't do it in software.  I'd suggest using one of the Arduino's digital output to do this, though I haven't tried it myself.
Grumpy_Mike
The BT module is probbly reset as part of the startup() function in your code.
smeezekitty
Quote
I have heard mixed opinions on this because the pin will go high impedance during reset which may lead to an incomplete reset. It will probably work though.
Resistors for LEDS!
retrolefty
Quote
That is correct. The AVR datasheet cautions against trying to use that method.
Lefty
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
