Author Topic: Connect scanner to Arduino  (Read 1890 times)
Hello Everyone,
I want to connect scanner for exampe Epson Perfection V33 to arduino throught USB, I understand that need to use USB host shield, but not understand how to send commands to the scanner.
My goal is scanner have to scan paper and save image to SD card, so question - how can arduino do it?
« Last Edit: March 20, 2012, 08:25:12 am by Seatle » Logged
Massachusetts, USA
The first step would be to figure out the protocol used by the scanner you have.  Most are not published because the scanner usually only talks to the driver provided by the scanner vendor.
Good luck.
thanks for reply! I think use USB analyzers like this http://www.usblyzer.com/ or http://www.totalphase.com/products/
« Last Edit: March 20, 2012, 08:55:28 am by Seatle » Logged
Netherlands
Assuming it would succeed then a normal scanner would have scanlines of ~8inch x 600 dpi x 3 colors = 7200 bytes per scanline.
That is almost 4 times the total RAM of an UNO. So even at BW at 200 dpi you would have a RAM overflow in no time.
Unless your goal is different.... ????
Rob Tillaart
what?
You would have more chance of hacking into the linear CCD imager data lines and using arduino to control the stepper to move the image sensor
You could use spi external ram to overcome that limit have a look at this:
http://www.microchip.com/ParamChartSearch/chart.aspx?branchID=27012&mid=&lang=en
SE USA
@ssh0le
ok yes spi ram exist's but are you going to have enough speed to deal with a camera in its real time while also streaming that data to an external source without running out of memory on the MCU?
SPI ram is not ram that you plug in and it add's onto the arduino's internal memory, its more or less a tiny SD card
what?
At risk of repeating myself you could try hacking straight into the linear CCD bus, ones i have used output serial data and are clocked by the host mcu so you control the speed of scan but others are different and it would be easy to drive the stepper, have a look here, this isn't my site but just one i found https://github.com/chiva/Arduino-CCD-TSL214
