Loading...
Pages: 1 2 [3] 4   Go Down
Author Topic: Simple Volume Control  (Read 2261 times)
Offline Offline
Newbie
View Profile
Ok thank you. So enought a simply 220V - 5v Dc switching power converter and do i connect the "+" to the Vdd and the "-" to the Vss?
Logged
Offline Offline
Newbie
View Profile
Do I need two independent power supply for this schematic??? The Vdd comes from arduino and the other supply 5v to Vss???
This way does the only? smiley-confuse
The second supply is AC or DC?
Now the powered from an USB connector.
« Last Edit: April 20, 2012, 11:40:34 am by myDuino » Logged
Manchester (England England)
Offline Offline
Brattain Member
Solder is electric glue
View Profile
WWW
If you read the posts I told you how to connect the extra supply. The + to ground and the - to Vss.
It should be 5V DC.
Logged
Offline Offline
Newbie
View Profile
Sorry Mike but I don't realy understand. Can you complete my schematic with your suggestion?
I would be really helpful.
Logged
Offline Offline
Brattain Member
View Profile
WWW
Last chance to understand
Logged
Offline Offline
Newbie
View Profile
Hello! I draw my second schematic, but now I can see you draw your own. Thank you.
I have only some question!
Do I need two independetn power supply or can I connect it to the supply what goes to the arduino?
Can't do any crashes on my arduino if I connect 5v to the ground?
Logged
Offline Offline
Brattain Member
View Profile
WWW
Quote
No think about it. If you do you willbe putting a short circuit on your supply. You need a seprate power supply, like I have been telling you all along.
Logged
Offline Offline
Newbie
View Profile
Now my circuit looks like you draw it. Are you sure I don't make any crash with my other part's to connect to arduino if I connect +5v to the arduino gnd pin???
Logged
Offline Offline
Brattain Member
View Profile
WWW
You obviously do not believe me so look at this link
http://www.kpsec.freeuk.com/powersup.htm
Under the Dual Supplies section.
It shows two supplies in this case 9V with the +ve of one connected to the -ve of the other. This point is zero volts and corresponds to your arduino's ground.
The free -ve output should be connected to the Vss pin, the free +ve end (if you have a 5v supply) should be connected to the 5V on your arduino.
Logged
Offline Offline
Newbie
View Profile
I did it exactly what you suggested. Now when I connect the arduino to my pc and pluged the second supply into the ac line:
The sound quality is so bad, always stay on same level, I can't switch on/off with 0 and 255 like before, and my IC is fire hot.
What happens???
Logged
Global Moderator
UK
Offline Offline
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
Quote
What happens?
What happens now?
You get hold of a copy of Horowitz and Hill, and you read it.
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
Offline Offline
Newbie
View Profile
Quote
What happens?
What happens now?
Thank you for this fantastic suggestion! I have a great suggestion to you too...
« Last Edit: May 02, 2012, 07:29:15 am by myDuino » Logged
Offline Offline
Newbie
View Profile
Mike?
Logged
Offline Offline
Brattain Member
View Profile
WWW
Wire it up correctly. If it gets hot you have not.
Can you post a picture of your setup?
Logged
Offline Offline
Newbie
View Profile
Now I wired back to the prew state but at this time the IC is hot and doesnt work...  smiley-cry
CAn I make any harm in my arduino? How can i test it?
And I check again and again but my schematic looks like what you drew.
Logged
Pages: 1 2 [3] 4   Go Up
Print
Jump to:
