« Reply #30 on: April 20, 2012, 10:52:02 am » |
Ok thank you. So enought a simply 220V - 5v Dc switching power converter and do i connect the "+" to the Vdd and the "-" to the Vss?
« Reply #31 on: April 20, 2012, 11:38:28 am » |
Do I need two independent power supply for this schematic??? The Vdd comes from arduino and the other supply 5v to Vss??? This way does the only?  The second supply is AC or DC? Now the powered from an USB connector.
« Last Edit: April 20, 2012, 11:40:34 am by myDuino »
Manchester (England England)
Solder is electric glue
« Reply #32 on: April 20, 2012, 04:32:16 pm » |
If you read the posts I told you how to connect the extra supply. The + to ground and the - to Vss. It should be 5V DC.
« Reply #33 on: April 21, 2012, 12:15:34 pm » |
Sorry Mike but I don't realy understand. Can you complete my schematic with your suggestion? I would be really helpful.
« Reply #34 on: April 21, 2012, 03:48:27 pm » |
Last chance to understand
« Reply #35 on: April 25, 2012, 02:54:38 am » |
Hello! I draw my second schematic, but now I can see you draw your own. Thank you. I have only some question! Do I need two independetn power supply or can I connect it to the supply what goes to the arduino? Can't do any crashes on my arduino if I connect 5v to the ground?
« Reply #36 on: April 25, 2012, 04:03:13 am » |
can I connect it to the supply what goes to the arduino No think about it. If you do you willbe putting a short circuit on your supply. You need a seprate power supply, like I have been telling you all along.
« Reply #37 on: May 02, 2012, 05:02:26 am » |
Now my circuit looks like you draw it. Are you sure I don't make any crash with my other part's to connect to arduino if I connect +5v to the arduino gnd pin???
« Reply #38 on: May 02, 2012, 05:55:48 am » |
You obviously do not believe me so look at this link http://www.kpsec.freeuk.com/powersup.htmUnder the Dual Supplies section. It shows two supplies in this case 9V with the +ve of one connected to the -ve of the other. This point is zero volts and corresponds to your arduino's ground. The free -ve output should be connected to the Vss pin, the free +ve end (if you have a 5v supply) should be connected to the 5V on your arduino.
« Reply #39 on: May 02, 2012, 06:51:34 am » |
I did it exactly what you suggested. Now when I connect the arduino to my pc and pluged the second supply into the ac line: The sound quality is so bad, always stay on same level, I can't switch on/off with 0 and 255 like before, and my IC is fire hot.
What happens???
UK
« Reply #40 on: May 02, 2012, 07:06:21 am » |
What happens? What happens now? You get hold of a copy of Horowitz and Hill, and you read it.
« Reply #41 on: May 02, 2012, 07:10:19 am » |
What happens? What happens now? You get hold of a copy of Horowitz and Hill, and you read it. Thank you for this fantastic suggestion! I have a great suggestion to you too...
« Last Edit: May 02, 2012, 07:29:15 am by myDuino »
« Reply #42 on: May 02, 2012, 07:30:46 am » |
Mike?
« Reply #43 on: May 02, 2012, 08:07:23 am » |
Wire it up correctly. If it gets hot you have not.
Can you post a picture of your setup?
« Reply #44 on: May 02, 2012, 08:18:20 am » |
Now I wired back to the prew state but at this time the IC is hot and doesnt work...  CAn I make any harm in my arduino? How can i test it? And I check again and again but my schematic looks like what you drew.
