Pages: [1] 2 3 4   Go Down
Author Topic: Operate from Blackberry/Android/Iphone-Ipad/Nokia/PC/Mac across the Globe W/O PC  (Read 9748 times)
Now New Arduino IDE 1.01 and New tinywebserver library Compatible with Sleek New UI with rounded toggles
Guys Home automation the simple but elegant way. Thanks to Tinywebserver library developer Ovidiu Predescu <ovidiu@gmail.com>.
« Last Edit: July 05, 2012, 12:23:25 pm by capper » Logged
Dear Friends this can be used standalone using
1. Arduino Uno
2. Standard wiznet chip based Ethernet shield with SD card.
3. Some Solid State Relays.
Tada ..
No PHP Server/PC required.
The User interface is very intuitive and its cross-platform ready.(also there is no need to install anything on the client-side.)
« Last Edit: July 05, 2012, 12:23:07 pm by capper » Logged
If you need code and supporting files just reply
and  you need to give it back to the forum
by adding something of your choice
Happy Hacking
Far too much wasted space in your GUI, which may translate into slower loading and wasted memory.
Edit: note that is just my opinion without seeing the code and such.
« Last Edit: March 23, 2012, 04:18:43 pm by zoomkat » Logged
put in key search words,
Dear Zoomkat
I have used CSS which adds mere 1 -2 sec more than the original code because everything render in browser itself. u can check that out and kudos for your positive comments.
attached code for your evaluation.
You need to Login first to see the file attached below
See 1ST POST Attached File for Code.
« Last Edit: June 17, 2012, 04:48:53 am by capper » Logged
I down loaded the code and took a quick look at the included files and the .pde file. The microSD card setup is interesting (but I don't have one to experiment with yet). I noticed the use of .js files. A while back (before I had an arduino) I tinkered with a slider.js file to make a sliding servo controller page (below) for an apache server setup. The same type of setup might be of interest with controlling lights and similar with an arduino.
http://web.comporium.net/~shb/eight2.htm
New York
Hi Capper,
I am interested in seeing the code with respect to your use of css. The functionality you are providing is really cool.
-John
me too.  smiley
Thanks Guys,  your appreciation is worth more than many sleepless night.
You can download the code and supporting files  from the  #4 post.
hey zoomkat can you guide me how can we dim  the light source to create a "Scene" using arduino. I am new for electronics as well as programming.
very nice graphics.
I wanted to add this to my website as a login from a mobile device. however the password feature does not seem to work, ive tried the password contained in the index file 8488480. it also asks two times for it.
can you help?
for a case of putting all this in a internet server, can cookies be added? is it simple? it would be nice not to have to enter the password each time.
thanks
* Si preguntas, pon el código de tu programa, hace mucho mas fácil ayudarte. Y me ahorro un mensaje pidiendo que lo hagas.
* Si consigues solucionar tu problema, dedica unos minutos a explicar en tu post como lo conseguiste para beneficio de todos.
* Cambia el 'Subject' de tu hilo y añade 'SOLUCIONADO' cuando hayas llegado a una solución al problema que planteaste.
* Utiliza un 'Subject' para tu hilo que explique de que va el hilo.
Si estas empezando:
* Comienza a usar Arduino
* Guías de iniciación a Arduino
* Ejemplos
* Referencia del Lenguaje
* Conceptos básicos
Guia de usuario de arduino
Tutoriales en Ingles
Si necesitas que alguien te escriba el código: http://www.freelancer.com/  o esta  http://www.guru.com/
dear guys
Actual Password is 4587
and its encrypted!!!! smiley-cool
Check this out for more explanation
http://www.dynamicdrive.com/dynamicindex9/password.htm
this is just  hyperlink to actual 4587.htm file in the programme, you can substitute your password and calculate the encrypted value from above link. ( you must change destination html file name with your password)
Isn't this Cool? smiley-cool
« Last Edit: April 02, 2012, 12:07:09 pm by capper » Logged
Nice idea (b.t.w. using bonjour it will work even better)...
I actually don't see the source but I might be confused.
See the post no 4 dude and the running arrow pointing downward there is an attachment.   you need to logint first to see the attached file. then Download and tinker it.
Btw what is "bonjour" and how could it help us
« Last Edit: April 28, 2012, 02:31:13 am by capper » Logged
Nice works!
Please, send me code!
Tx
What is the version of arduino you use ? I Try with arduino 1.0 and i receive many compilation error!
Thank you smiley-mr-green
Pages: [1] 2 3 4   Go Up
