Pages: 1 2 3 [4]   Go Down
Author Topic: Operate from Blackberry/Android/Iphone-Ipad/Nokia/PC/Mac across the Globe W/O PC  (Read 10116 times)
Surabaya, Indonesia
Great Work,
where to download the code ?
dear guys
Actual Password is 4587
and its encrypted!!!! smiley-cool
Check this out for more explanation
http://www.dynamicdrive.com/dynamicindex9/password.htm
this is just  hyperlink to actual 4587.htm file in the programme, you can substitute your password and calculate the encrypted value from above link. ( you must change destination html file name with your password)
Isn't this Cool? smiley-cool
I'm not that good with HTML but isn't this extremely easy to hack? If you can see the root dir of the site you will see the html file in plain txt? how secure is this.
Anyone?
dear guys
Hi Foolix,
You can try "http basic authentication".
http://en.wikipedia.org/wiki/Basic_access_authentication
Regards,
Nic
Any ideas about how to display analogue values or variables in this platform?
Web / sms / bluetooth / arduino / android remote control. Home Automation projects.
http://www.power7.net
hi Capper
  Please help me i am not able to download the attached files of #4 and #34 which is attached by you it says "url not found".
Slovakia
I have same problem, can´t download any file.
Hi Capper.
Thank you for this great application.
I would like to replace one (the first) line into displaying an analog value e.g. a temperature.
Can you help me a bit how to display a value of "analogRead(i)" ?
Jes
Dear Veseo,
Thank you for being Torch-Bearer,
I must confess that I am not a good coder, but I am good at adaptation.
I was thinking to offload webpage from Arduino to any damn web-server as Arduino is not suitable for this kind of workload.
the Arduino sketch remains same for IDE 1.01 other than you have to substitute "Server" to "Ethernetserver" and "Client" to "EthernetClient".
Attached below Arduino sketch and  Htmlpart.zip.
1. Upload AjaxUI.ino to arduino
2. Extract htmlpart.zip to your Pc/Mac/Phone/Tablet
3. Open Index.htm in your browser give password 4587 and hit submit. (don't press enter/return)
4. connect LED on pin 9 and GND
5. Have Fun
Warm Regards
Capper
I am having some problems with this...After changing the ip address in the main.js script to my arduino's ip, now at least when I open the UI I can see the rx and tx led's flash on my ethernet shield so I believe I am close to getting this to work, my problem is the on/off toggle on the web page will not work it just stays off (greyed out). Any ideas as to what I am doing wrong here would be appreciated.
Thanks!
Slovakia
Hi Guys,
I´m trying and trying and still comes one message : "F" was not declared in this scope,(caused in line: web_server << F("Could not parse URL")smiley-wink what's wrong.
Please help I'm desperate.
THANKS
HI I adopted the code that was posted by @zoomkat and tried to extend it a bit by using adding a timed function.
My project in a nutshel, my aim is to control lights from the internet and put them in timed control as well. I will be switching between two modes using a physical button to start with. I have the timed control working separately and the webserver working separately. The problem I am having is combining the two codes. When the switch is high its supposed to go to the timed function and turn on/off the lights according to the set times, its not doing so at the moment. Please help any pointers?
The other problem is I can access the web page on my laptop but not on my phone pr any other laptop. The ES is stacked on to the UNO and the uno is connected to my laptop via ethernet cable and laptop is connect to a wireless network. The code is below:
I have attached the code
Pages: 1 2 3 [4]   Go Up
