Hi
I have just started on Arduino
my project is to turn light when dark for 1hrs and turn off ,below is my code which dosent workway I want.instead on power LED is on and on dark after an hrs off.any help appriciated.
Thanks
CODE #define LDR 0 #define LED 13 #define LIGHTON 3600000
How do you have the LDR & LED wired up?
Sounds like maybe you want to look for
ldrValue<=912
to indicate dark?
And then add a flag so it does not come back until ldrValue has gone high to show it has been daylight again.
I could try using an multimeter on voltage mode to measure the voltage on the analog pin when you get dark on LDR.This way you will be chore about the value you have to expect on the if cicle. Like CrossRoads say you sould get a flag variable also
Maybe something instead of a multimeter , you could debug VIA serial monitor. Reading your Values. Just a thought
Seems the best way to get reading from your sensors reguardless of type,resistor and so forth
OK i hope you dont mind i changed some of your code. I put in some Debugging and i have a Resistor on the input side just to bring down the values and changed the time for checking
It maybe nothing like you want. But maybe it will be in the right direction
#define LDR A0
#define LED 13
#define LIGHTON 50
int LDR = A0;
int LED = 13;
int LIGHTON = 50;
unsigned long darkStart;
int ldrValue;
void setup(){
pinMode(LED, OUTPUT);
digitalWrite(LED, LOW);
pinMode(LDR, INPUT);
void loop(){
ldrValue = analogRead(LDR);
if (ldrValue <= 512){
digitalWrite(LED, HIGH);
darkStart = millis();
if ( millis()-darkStart > LIGHTON){
Serial.println(ldrValue);
Serial.println(LDR);
So where is something that indicates you have been on for an hour, and are now waiting for daylight to occur?
i.e.
if (ldrValue<=512 && waiting_for_day == 0){ // finally dark out, and has not been daylight yet
turn on LED, start darkStart timer
waiting_for_day = 1; // don't start 1 hour again until its daylight
if ( (darkStart +duration)>=millis() ) {
turn off LED
if ( ldrValue >=512){
waiting_for_day = 0; // daytime, can look for nighttime now
After reducing R from 10k to 5k &
darkStart=0;
it works
Pl. advise
Regards
