Topic: integer save into single bytes (Read 6350 times) previous topic - next topic
GekoCH
Hy
I'm right now trying to convert an Integer ex. 115730 into
a 4 byte array.
So I tryed this but it doesn't work...
Code: [Select]
long number = 115730:
data[0] = (byte)(number >> 24);
data[1] = (byte)(number >> 16);
data[2] = (byte)(number >> 8);
data[3] = (byte)(number);
Can someone help me, it might be just a little mistake but where....
Andy
wildbill
Put an 'L' on the end of 115730. Substitute the : on that line for a ;
ea123
another solution is defining a union:
Code: [Select]
union Number
  long num;
  byte barray[4];
} NN;
then set the long field and get the byte array:
Code: [Select]
  NN.num = 123466L;
  byte b0 = NN.data[0];
  byte b1 = NN.data[1];
  byte b2 = NN.data[2];
  byte b3 = NN.data[3];
GekoCH
#3
Mar 23, 2012, 02:25 pm Last Edit: Mar 23, 2012, 02:34 pm by GekoCH Reason: 1
Code: [Select]
union Number
 long num;
 byte barray[4];
} NN;
Code: [Select]
 NN.num = 123466L;
Hmm I thought I'm not that stupid but can you help me to implement this.
What is in the data array?
EDIT:
Ok found something I cahnged the code to:
Code: [Select]
union Number
    long num;
    byte barray[4];
  NN;
  NN.num = 115730L;
  byte b0 = NN.barray[0];
  byte b1 = NN.barray[1];
  byte b2 = NN.barray[2];
  byte b3 = NN.barray[3];
Now it is working perfectly but how can I ad an 'L' to a long integer?
Thx
Andy
AWOL
Quote
Just like you did here
Code: [Select]
  NN.num = 123466L;
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
I speak for myself, not Arduino.
GekoCH
ok sorry did not ask the right way.
I got the number stored in a long variable eb.
long test = 150216;
and now how can I add an L...
GekoCH
hmmm
Code: [Select]
void in32bit(long number){
  union Number{
    long num;
    byte barray[4];
  NN;
  NN.num = number;
  Serial.println(b3, DEC);
  Serial.println(b2, DEC);
  Serial.println(b1, DEC);
  Serial.println(b0, DEC);
  int buffer[5];
  buffer[1] = b3;
  buffer[2] = b2;
  buffer[3] = b1;
  buffer[4] = b0;
  unsigned long b11 = buffer[1] * long(pow(256,3));
  unsigned long b22 = buffer[2] * long(pow(256,2));
  unsigned long b33 = buffer[3] * long(pow(256,1));
  unsigned long b44 = buffer[4] * long(pow(256,0));
  unsigned long val = b11 + b22 +b33 + b44;
  Serial.println(val);
I got now this code.
Why is it working without an 'L'???
AWOL
I don't recommend that you use "pow" for integer work.
PaulS
Quote
Why is it working with an L where? We can't see where you call that function.
GekoCH
It was suggested to add an 'L' behind my long number however it is also working without since I'm not
sure how I can add an 'L' behind a long variable....
AWOL
You can't add an L to a variable, the suffix is only used when specifying constants.
GekoCH
So how do you suggest to decode a 32bit value?
AWOL
Using bit shifts, multiplication/division, unions or pointers.
GekoCH
yes I tried bit shifts with:
Code: [Select]
  unsigned long b1 = buffer[1] * 1 << 32;
  unsigned long b2 = buffer[2] * 1 << 16;
  unsigned long b3 = buffer[3] * 1 << 8;
  unsigned long b4 = buffer[4] * 1 << 0;
  unsigned long val = b1 + b2 +b3 + b4;
but didn't worked therefore i switched to pow....
AWOL
0, 8, 16,...32?
Why do your buffer subscripts start at 1?
